    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 20.1k Views 8 Watching
    • A
      angeliKITTYx @sdetweil
      all the same terminal window. i don’t have anything else open. i know it says 22.21.1, but then node version says 19… very odd.
      kittypi@KITTYpi:~/MagicMirror $ hash -r
      kittypi@KITTYpi:~/MagicMirror $ which node
      /usr/local/node/bin/node
      kittypi@KITTYpi:~/MagicMirror $ node --version
      v22.19.0
        sdetweil @angeliKITTYx
        @angeliKITTYx ok, close that window and open another and
        try the node --version again
        A 1 Reply Last reply
        • A
          closed the terminal, opened a new terminal…
          kittypi@KITTYpi:~ $ node --version
          v22.19.0
          kittypi@KITTYpi:~ $ cd MagicMirror
          v22.19.0
            @angeliKITTYx weird
            Do
            which node
            Go to that folder
            sudo mv node onode
            hash -r
            which node
            node —version
            • A
              kittypi@KITTYpi:~/MagicMirror $ cd ..
              kittypi@KITTYpi:~ $ which node
              kittypi@KITTYpi:/ $ cd usr
              kittypi@KITTYpi:/usr $ cd local
              kittypi@KITTYpi:/usr/local $ cd node
              kittypi@KITTYpi:/usr/local/node $ cd bin
              kittypi@KITTYpi:/usr/local/node/bin $ cd node
              bash: cd: node: Not a directory
              kittypi@KITTYpi:/usr/local/node/bin $ sudo mv node onode
              hash -r
              which node
              node —version
              /usr/local/bin/node
              node:internal/modules/cjs/loader:1386
                throw err;
              Error: Cannot find module '/usr/local/node/bin/—version'
                  at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                  at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                  at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                  at Function._load (node:internal/modules/cjs/loader:1192:37)
                  at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                  at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                  at node:internal/main/run_main_module:36:49 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              Node.js v22.21.1
                @angeliKITTYx i hate this editor on my phone changing the characters
                do
                node --version
                it should report 22.21.1
                then
                npm run install-mm
                • A
                  it’s booting now! hurray! however, now I’m getting the package lock error when i try to complete the calendarext3 update and none of my events are populating. I have a thread up on someone else’s trouble shooting but I’m out of time this morning. I be back at it this afternoon. thank you again for all your help.
                    @angeliKITTYx awesome. Thanks for the feedback
                    package-lock? Erase that file then do the update
                    There is a known bug affecting modules that have functions in their config like ext3. We are discussing ways to distribute these fixes.
                      Did you get the npm run install-mm done after verifying node version was correct?
                      • A
                        yes I did the npm run install-mm successfully.
                        i got it updated, but now it’s angry again
                        [2026-04-29 18:51:43.521] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                        [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "Ortho": ical.expandRecurringEvent is not a function
                        [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                        [2026-04-29 18:51:43.523] [ERROR] [calendar] Could not expand event "HVAC DUCTING FIX": ical.expandRecurringEvent is not a function
                        [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Injection appt time TBD": ical.expandRecurringEvent is not a function
                        [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Env. Regulations": ical.expandRecurringEvent is not a function
                        [2026-04-29 18:51:43.525] [ERROR] [calendar] Could not expand event "Z4 training": ical.expandRecurringEvent is not a function
                        [2026-04-29 18:51:43.526] [ERROR] [calendar] Could not expand event "Jury Duty ": ical.expandRecurringEvent is not a function
                        [2026-04-29 18:51:43.527] [ERROR] [calendar] Could not expand event "MATH 260: Linear Algebra ": ical.expandRecurringEvent is not a function
                        [2026-04-29 18:51:43.527] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/axxxxx/basic.ics.
                        [2026-04-29 18:52:09.449] [LOG]   [electron] Shutting down server...
                        [2026-04-29 18:52:09.452] [LOG]   [node_helper] Stopping module helper: updatenotification
                        [2026-04-29 18:52:09.462] [LOG]   [node_helper] Stopping module helper: calendar
                        [2026-04-29 18:52:09.464] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
                        [2026-04-29 18:52:09.469] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
                        [2026-04-29 18:52:09.470] [LOG]   [node_helper] Stopping module helper: weather
                        [2026-04-29 18:52:09.473] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
                        [2026-04-29 18:52:09.478] [LOG]   [app] Node_helpers stopped ...
                        v22.21.1
                          @angeliKITTYx looks like you didn’t do that in the MagicMirror folder
                          npm run install-mm
                          • A
                            I did it originally in the MM folder, but I ran it again and still getting the same errors
                            I did catch this before the entire terminal filled up with “: ical.expandRecurringEvent is not a function”
                            [2026-04-29 19:59:54.445] [LOG]   [server] Starting server on port 8080 ...
                            [2026-04-29 19:59:54.499] [ERROR] [unknown] (node:58997) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                            (Use `electron --trace-deprecation ...` to show where the warning was created)
                            [2026-04-29 19:59:54.855] [LOG]   [app] Server started ...
                            [2026-04-29 19:59:54.858] [LOG]   [node_helper] Connecting so```
                              @angeliKITTYx that means the install-mm did not work
                              Please do again and show the output
                              • A
                                kittypi@KITTYpi:~ $ cd ~/MagicMirror
                                npm run install-mm
                                > magicmirror@2.35.0 install-mm
                                > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                                > magicmirror@2.35.0 postinstall
                                > git clean -df fonts vendor modules/default
                                > magicmirror@2.35.0 prepare
                                > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                                no husky installed.
                                up to date in 3s
                                  @angeliKITTYx ok then, one more time
                                  rm package-lock.json
                                  rm -rf node_modules
                                  npm run install-mm
                                  • A
                                    rm -rf node_modules
                                    npm run install-mm
                                    rm: cannot remove 'package-lock.json': No such file or directory
                                    no husky installed.
                                    added 389 packages in 6m
                                      @angeliKITTYx ok, now start MagicMirror
                                      • A
                                        it’s booted again and no update notifs (:
                                        …but none of my calendar events are populating. this morning, it took about 20m and they eventually showed up. I’ve had it open for about 10m already and don’t see anything. I’ll keep an eye on it.
                                        update - I backed out and saw that I got all of these errors still…
                                        ssignment -July 4th [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.831] [ERROR] [calendar] Could not expand event "Introductory Speech Written Submission [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.832] [ERROR] [calendar] Could not expand event "PHI 100 Quiz 4": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.833] [ERROR] [calendar] Could not expand event "Persuasive Ad Analysis  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.834] [ERROR] [calendar] Could not expand event "Discussion 1  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.834] [ERROR] [calendar] Could not expand event "Final Discussion  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.835] [ERROR] [calendar] Could not expand event "Introductory Speech Video (Recorded Audio and Video)  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.836] [ERROR] [calendar] Could not expand event "Submit Persuasive Speech [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.837] [ERROR] [calendar] Could not expand event "PHI 100 QUIZ 2": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.838] [ERROR] [calendar] Could not expand event "Homework [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.839] [ERROR] [calendar] Could not expand event "My Listening Skills [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.840] [ERROR] [calendar] Could not expand event "PHI 100 Discussion": ical.expandRecurringEvent is not a function
                                        [2026-04-29 21:45:07.841] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/2adcc5394a749909a5fbe4e93d3673b2e0ff6fd91551d1977ecc7dfb84dde87a%40group.calendar.google.com/private-b562d8f04caac264bc19d634d4bfcee0/basic.ics.
                                        [2026-04-29 21:45:09.852] [LOG]   [electron] Shutting down server...
                                        [2026-04-29 21:45:09.853] [LOG]   [node_helper] Stopping module helper: updatenotification
                                        [2026-04-29 21:45:09.854] [LOG]   [node_helper] Stopping module helper: calendar
                                        [2026-04-29 21:45:09.854] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
                                        [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
                                        [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: weather
                                        [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
                                        [2026-04-29 21:45:09.856] [LOG]   [app] Node_helpers stopped ...
                                        S KristjanESPERANTOK 2 Replies Last reply
                                          @angeliKITTYx thanks
                                          @kristjanesperanto what do you think of this?
                                          We’ve made sure to erase node_modules and start fresh
                                          KristjanESPERANTOK S 2 Replies Last reply
                                          • KristjanESPERANTOK
                                            Hmm… I didn’t expect something like that in the current release. But I won’t be able to take a closer look at it right away. It would be interesting to see if this also happens in the develop branch.
                                            • 3 / 4
