    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 20.2k Views 8 Watching
      sdetweil @angeliKITTYx
      @angeliKITTYx another fun time
      Do
      sudo npm install -g n
      sudo n 22.21.1
      hash -r
      node -v
      If it says 22.21.1
      Then do
      npm run install-mm
      If it says successful then
      npm run start:x11
      A 1 Reply Last reply
      • A
        angeliKITTYx @sdetweil
        kittypi@KITTYpi:~/MagicMirror $ sudo npm install -g n
        sudo n 22.21.1
        hash -r
        node -v
        sudo: npm: command not found
        sudo: n: command not found
        v22.19.0
          @angeliKITTYx ok
          sudo apt update
          sudo apt install nodejs
          If that ends ok
          node -v
          • A
            still no luck :(
            I’m logging off for the evening, but I’ll check back in tomorrow. Thank you for all the help you provide!
            kittypi@KITTYpi:~/MagicMirror $ sudo apt update
            Hit:1 http://deb.debian.org/debian bookworm InRelease
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
            Reading package lists... Done
            Building dependency tree... Done
            All packages are up to date.
              libbasicusageenvironment1 libgroupsock8 liblivemedia77 linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.25+rpt-rpi-2712
              linux-headers-6.12.25+rpt-rpi-v8 linux-image-6.12.25+rpt-rpi-2712 linux-image-6.12.25+rpt-rpi-v8 linux-kbuild-6.12.25+rpt
              python3-v4l2
            Use 'sudo apt autoremove' to remove them.
            The following additional packages will be installed:
              libc-ares2 libnode108 libuv1 node-acorn node-busboy node-cjs-module-lexer node-undici node-xtend nodejs-doc
            Suggested packages:
              npm
            The following NEW packages will be installed:
              libc-ares2 libnode108 libuv1 node-acorn node-busboy node-cjs-module-lexer node-undici node-xtend nodejs nodejs-doc
            0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
            Need to get 14.2 MB of archives.
            After this operation, 66.5 MB of additional disk space will be used.
            Do you want to continue? [Y/n] y
            Get:1 http://deb.debian.org/debian bookworm/main arm64 libc-ares2 arm64 1.18.1-3 [99.2 kB]
            Get:2 http://deb.debian.org/debian bookworm/main arm64 libuv1 arm64 1.44.2-1+deb12u1 [130 kB]
            Get:3 http://deb.debian.org/debian bookworm/main arm64 node-xtend all 4.0.2-3 [3,932 B]
            Get:4 http://deb.debian.org/debian bookworm/main arm64 nodejs arm64 18.20.4+dfsg-1~deb12u1 [319 kB]
            Get:5 http://deb.debian.org/debian bookworm/main arm64 node-acorn all 8.8.1+ds+~cs25.17.7-2 [128 kB]
            Get:6 http://deb.debian.org/debian bookworm/main arm64 node-cjs-module-lexer all 1.2.2+dfsg-5 [30.1 kB]
            Get:7 http://deb.debian.org/debian bookworm/main arm64 node-busboy all 1.6.0+~cs2.6.0-2 [16.9 kB]
            Get:8 http://deb.debian.org/debian bookworm/main arm64 node-undici all 5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4 [285 kB]
            Get:9 http://deb.debian.org/debian bookworm/main arm64 libnode108 arm64 18.20.4+dfsg-1~deb12u1 [9,565 kB]
            Get:10 http://deb.debian.org/debian bookworm/main arm64 nodejs-doc all 18.20.4+dfsg-1~deb12u1 [3,579 kB]
            Fetched 14.2 MB in 4s (3,796 kB/s)
            Selecting previously unselected package libc-ares2:arm64.
            (Reading database ... 171415 files and directories currently installed.)
            Preparing to unpack .../0-libc-ares2_1.18.1-3_arm64.deb ...
            Unpacking libc-ares2:arm64 (1.18.1-3) ...
            Selecting previously unselected package libuv1:arm64.
            Preparing to unpack .../1-libuv1_1.44.2-1+deb12u1_arm64.deb ...
            Unpacking libuv1:arm64 (1.44.2-1+deb12u1) ...
            Selecting previously unselected package node-xtend.
            Preparing to unpack .../2-node-xtend_4.0.2-3_all.deb ...
            Unpacking node-xtend (4.0.2-3) ...
            Selecting previously unselected package nodejs.
            Preparing to unpack .../3-nodejs_18.20.4+dfsg-1~deb12u1_arm64.deb ...
            Unpacking nodejs (18.20.4+dfsg-1~deb12u1) ...
            Selecting previously unselected package node-acorn.
            Preparing to unpack .../4-node-acorn_8.8.1+ds+~cs25.17.7-2_all.deb ...
            Unpacking node-acorn (8.8.1+ds+~cs25.17.7-2) ...
            Selecting previously unselected package node-cjs-module-lexer.
            Preparing to unpack .../5-node-cjs-module-lexer_1.2.2+dfsg-5_all.deb ...
            Unpacking node-cjs-module-lexer (1.2.2+dfsg-5) ...
            Selecting previously unselected package node-busboy.
            Preparing to unpack .../6-node-busboy_1.6.0+~cs2.6.0-2_all.deb ...
            Unpacking node-busboy (1.6.0+~cs2.6.0-2) ...
            Selecting previously unselected package node-undici.
            Preparing to unpack .../7-node-undici_5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4_all.deb ...
            Unpacking node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
            Selecting previously unselected package libnode108:arm64.
            Preparing to unpack .../8-libnode108_18.20.4+dfsg-1~deb12u1_arm64.deb ...
            Unpacking libnode108:arm64 (18.20.4+dfsg-1~deb12u1) ...
            Selecting previously unselected package nodejs-doc.
            Preparing to unpack .../9-nodejs-doc_18.20.4+dfsg-1~deb12u1_all.deb ...
            Unpacking nodejs-doc (18.20.4+dfsg-1~deb12u1) ...
            Setting up node-cjs-module-lexer (1.2.2+dfsg-5) ...
            Setting up libc-ares2:arm64 (1.18.1-3) ...
            Setting up libuv1:arm64 (1.44.2-1+deb12u1) ...
            Setting up nodejs-doc (18.20.4+dfsg-1~deb12u1) ...
            Setting up node-xtend (4.0.2-3) ...
            Setting up node-busboy (1.6.0+~cs2.6.0-2) ...
            Setting up node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
            Setting up node-acorn (8.8.1+ds+~cs25.17.7-2) ...
            Setting up libnode108:arm64 (18.20.4+dfsg-1~deb12u1) ...
            Setting up nodejs (18.20.4+dfsg-1~deb12u1) ...
            update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
            Processing triggers for man-db (2.11.2-2) ...
            Processing triggers for libc-bin (2.36-9+rpt2+deb12u13) ...
            kittypi@KITTYpi:~/MagicMirror $ node -v
            v22.19.0
            sudo n 22.21.1
            hash -r
            node -v
            v22.19.0
              @angeliKITTYx so much fun. I hate when the tools only do half a job
              sudo apt install npm
              Then
              npm -v
              Then
              sudo n 22.21.1
              hash -r
              node -v
              • A
                it is just refusing to take 22.21.1
                Setting up node-es-abstract (1.20.4+~cs26.27.47-1) ...
                Setting up node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
                Setting up node-util (0.12.5+~1.0.10-1) ...
                Setting up node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
                Setting up node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
                Setting up node-assert (2.0.0+~cs3.9.8-2) ...
                Setting up webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
                Setting up node-parse-json (5.2.0+~cs5.1.7-1) ...
                Setting up node-read-pkg (5.2.0-2) ...
                Setting up node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
                Setting up node-tape (5.6.1+~cs8.20.19-1) ...
                Setting up node-css-loader (6.7.2+~cs14.0.11-1) ...
                Setting up node-tap (16.3.2+ds1+~cs50.8.16-1+deb12u1) ...
                Setting up node-deep-equal (2.1.0+~cs31.12.80-1) ...
                Setting up npm (9.2.0~ds1-1) ...
                kittypi@KITTYpi:~/MagicMirror $ npm -v
                11.13.0
                sudo n 22.21.1
                hash -r
                node -v
                added 1 package in 2s
                  installing : node-v22.21.1
                       mkdir : /usr/local/n/versions/node/22.21.1
                       fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-arm64.tar.xz
                     copying : node/22.21.1
                   installed : v22.21.1 (with npm 10.9.4)
                Note: the node command changed location and the old location may be remembered in your current shell.
                         old : /usr/bin/node
                         new : /usr/local/bin/node
                If "node --version" shows the old version then start a new shell, or reset the location hash with:
                hash -r  (for bash, zsh, ash, dash, and ksh)
                rehash   (for csh and tcsh)
                v22.19.0
                kittypi@KITTYpi:~/MagicMirror $ node --version
                v22.19.0
                kittypi@KITTYpi:~/MagicMirror $ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                bash: $: command not found
                  @angeliKITTYx
                  The last command you have an extra leading $
                  When you copy/paste you only need to hit the little rectangle button at the en
                  But you dont need all that . The code is downloaded
                  Just do
                  npm run install-mm
                  • A
                    how do i do percussive maintenance on code xD
                    kittypi@KITTYpi:~/MagicMirror $ cd ~/MagicMirror
                    npm run install-mm
                    > magicmirror@2.35.0 install-mm
                    > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                    npm error code EBADENGINE
                    npm error engine Unsupported engine
                    npm error engine Not compatible with your version of node/npm: magicmirror@2.35.0
                    npm error notsup Not compatible with your version of node/npm: magicmirror@2.35.0
                    npm error notsup Required: {"node":">=22.21.1 <23 || >=24"}
                    npm error notsup Actual:   {"node":"v22.19.0","npm":"11.13.0"}
                    npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T20_16_16_675Z-debug-0.log
                      @angeliKITTYx the end of your prior log post says 22.21.1 is installed
                         installed : v22.21.1 (with npm 10.9.4)  <-----
                      are you in the same terminal window??
                      if so, you need
                      hash -r
                      to capture the path change
                      do
                      which node
                      so we can see where it it located…
                      @angeliKITTYx
                      • A
                        all the same terminal window. i don’t have anything else open. i know it says 22.21.1, but then node version says 19… very odd.
                        kittypi@KITTYpi:~/MagicMirror $ hash -r
                        kittypi@KITTYpi:~/MagicMirror $ which node
                        /usr/local/node/bin/node
                        v22.19.0
                          @angeliKITTYx ok, close that window and open another and
                          try the node --version again
                          • A
                            closed the terminal, opened a new terminal…
                            kittypi@KITTYpi:~ $ node --version
                            v22.19.0
                            kittypi@KITTYpi:~ $ cd MagicMirror
                            v22.19.0
                              @angeliKITTYx weird
                              Do
                              which node
                              Go to that folder
                              sudo mv node onode
                              hash -r
                              which node
                              node —version
                              • A
                                kittypi@KITTYpi:~/MagicMirror $ cd ..
                                kittypi@KITTYpi:~ $ which node
                                kittypi@KITTYpi:/ $ cd usr
                                kittypi@KITTYpi:/usr $ cd local
                                kittypi@KITTYpi:/usr/local $ cd node
                                kittypi@KITTYpi:/usr/local/node $ cd bin
                                kittypi@KITTYpi:/usr/local/node/bin $ cd node
                                bash: cd: node: Not a directory
                                kittypi@KITTYpi:/usr/local/node/bin $ sudo mv node onode
                                hash -r
                                which node
                                node —version
                                /usr/local/bin/node
                                node:internal/modules/cjs/loader:1386
                                  throw err;
                                Error: Cannot find module '/usr/local/node/bin/—version'
                                    at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                    at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                    at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                    at Function._load (node:internal/modules/cjs/loader:1192:37)
                                    at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                                    at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                                    at node:internal/main/run_main_module:36:49 {
                                  code: 'MODULE_NOT_FOUND',
                                  requireStack: []
                                Node.js v22.21.1
                                  @angeliKITTYx i hate this editor on my phone changing the characters
                                  do
                                  node --version
                                  it should report 22.21.1
                                  then
                                  npm run install-mm
                                  • A
                                    it’s booting now! hurray! however, now I’m getting the package lock error when i try to complete the calendarext3 update and none of my events are populating. I have a thread up on someone else’s trouble shooting but I’m out of time this morning. I be back at it this afternoon. thank you again for all your help.
                                      @angeliKITTYx awesome. Thanks for the feedback
                                      package-lock? Erase that file then do the update
                                      There is a known bug affecting modules that have functions in their config like ext3. We are discussing ways to distribute these fixes.
                                        Did you get the npm run install-mm done after verifying node version was correct?
                                        • A
                                          yes I did the npm run install-mm successfully.
                                          i got it updated, but now it’s angry again
                                          [2026-04-29 18:51:43.521] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                                          [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "Ortho": ical.expandRecurringEvent is not a function
                                          [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                                          [2026-04-29 18:51:43.523] [ERROR] [calendar] Could not expand event "HVAC DUCTING FIX": ical.expandRecurringEvent is not a function
                                          [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Injection appt time TBD": ical.expandRecurringEvent is not a function
                                          [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Env. Regulations": ical.expandRecurringEvent is not a function
                                          [2026-04-29 18:51:43.525] [ERROR] [calendar] Could not expand event "Z4 training": ical.expandRecurringEvent is not a function
                                          [2026-04-29 18:51:43.526] [ERROR] [calendar] Could not expand event "Jury Duty ": ical.expandRecurringEvent is not a function
                                          [2026-04-29 18:51:43.527] [ERROR] [calendar] Could not expand event "MATH 260: Linear Algebra ": ical.expandRecurringEvent is not a function
                                          [2026-04-29 18:51:43.527] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/axxxxx/basic.ics.
                                          [2026-04-29 18:52:09.449] [LOG]   [electron] Shutting down server...
                                          [2026-04-29 18:52:09.452] [LOG]   [node_helper] Stopping module helper: updatenotification
                                          [2026-04-29 18:52:09.462] [LOG]   [node_helper] Stopping module helper: calendar
                                          [2026-04-29 18:52:09.464] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
                                          [2026-04-29 18:52:09.469] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
                                          [2026-04-29 18:52:09.470] [LOG]   [node_helper] Stopping module helper: weather
                                          [2026-04-29 18:52:09.473] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
                                          [2026-04-29 18:52:09.478] [LOG]   [app] Node_helpers stopped ...
                                          v22.21.1
                                            @angeliKITTYx looks like you didn’t do that in the MagicMirror folder
                                            npm run install-mm
                                            • 3 / 4
