    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 19.0k Views 8 Watching
      sdetweil @angeliKITTYx
      @angeliKITTYx you are on node 22.19, and we need 22.21.1
      If you use my scripted install or update then it will take care of that.
      Because you did part of the install (git pull), the new version code is loaded
      But not its dependencies, so MagicMirror won’t run correctly
      You could run my upgrade script with force instead of apply
      As it won’t let you install/upgrade over the current level.
      See
        angeliKITTYx @sdetweil
        @sdetweil thanks for the quick reply. I did the first line under the Update section and got the same results. All of the modules are working except CalEXT3 - it shows, but no events populate and I get all of those “not a function” errors.
        I also tried running the second command in that section and got the same results. I’m probably missing a step somewhere…
        kittypi@KITTYpi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        update log will be in /home/kittypi/MagicMirror/installers/upgrade.log
        Minimum Node version: v22.21.1
        Installed Node version: v22.19.0
        Node should be upgraded.
        Node.js upgrade defered, doing test run
        Minimum npm version: V10.9.4
        Installed npm version: V11.13.0
        No npm upgrade necessary.
        upgrading from version 2.35.0 to 2.35.0
        bash: line 772: pm2: command not found
        fetching latest revisions
        updating dependencies for active modules with package.json files
        	processing for module MMM-CalendarExt3 please wait
        	skipped processing for MMM-CalendarExt3, doing test run
        	processing complete for module MMM-CalendarExt3
        	processing for module MMM-Jokes please wait
        	skipped processing for MMM-Jokes, doing test run
        	processing complete for module MMM-Jokes
        	processing for module MMM-Todoist2 please wait
        	skipped processing for MMM-Todoist2, doing test run
        	processing complete for module MMM-Todoist2
        	processing for module MMM-ISS-Live please wait
        	skipped processing for MMM-ISS-Live, doing test run
        	processing complete for module MMM-ISS-Live
        moving css contents to config
          @angeliKITTYx correct. It says doing test run , no changes will be made
          The doc says this is a 2 part update process
          Test, advise any issues , no changes
          The second part, Do
          The second line to copy ends with the word
          apply
          Which I want you to change to
          force
            I fear I have made it even worse…
            kittypi@KITTYpi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            doing test run = false
            installing correct version of node and npm, please wait
            sudo: n: command not found
            Installing Node.js ...
            using sudo n v22.21.1
            force: line 446: sudo n  v22.21.1 : command not found
            node version is
            Node.js installation Done! version=v22.19.0
            want /var/swap=512MByte, checking existing: keeping it
            force: line 772: pm2: command not found
            npm error code EBADENGINE
            npm error engine Unsupported engine
            npm error engine Not compatible with your version of node/npm: magicmirror@2.35.0
            npm error notsup Not compatible with your version of node/npm: magicmirror@2.35.0
            npm error notsup Required: {"node":">=22.21.1 <23 || >=24"}
            npm error notsup Actual:   {"node":"v22.19.0","npm":"11.13.0"}
            npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T00_48_25_147Z-debug-0.log
            npm warn "install" is being parsed as a normal command line argument.
            npm warn Unknown cli config "--audit --no-fund --no-update-notifier". This will stop working in the next major version of npm.
            > mmm-calendarext3@1.12.4 postinstall
            > git submodule update --init --recursive
            Submodule path 'CX3_Shared': checked out 'c097e31c073007cf16e86f695bed1c807f581aef'
            up to date, audited 1 package in 1s
            found 0 vulnerabilities
            npm warn deprecated har-validator@5.1.5: this library is no longer supported
            npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            added 50 packages, and audited 51 packages in 6s
            4 packages are looking for funding
              run `npm fund` for details
            6 vulnerabilities (4 moderate, 2 critical)
            Some issues need review, and may require choosing
            a different dependency.
            Run `npm audit` for details.
            > mmm-iss-live@2.3.1 prepare
            > simple-git-hooks || true
            sh: 1: simple-git-hooks: not found
            up to date, audited 1 package in 967ms
            kittypi@KITTYpi:~/MagicMirror $ npm run start
            > magicmirror@2.35.0 start
            > node --run start:wayland
            /bin/sh: 1: ./node_modules/.bin/electron: not found
              @angeliKITTYx another fun time
              Do
              sudo npm install -g n
              sudo n 22.21.1
              hash -r
              node -v
              If it says 22.21.1
              Then do
              npm run install-mm
              If it says successful then
              npm run start:x11
                kittypi@KITTYpi:~/MagicMirror $ sudo npm install -g n
                sudo n 22.21.1
                hash -r
                node -v
                sudo: npm: command not found
                v22.19.0
                  @angeliKITTYx ok
                  sudo apt update
                  sudo apt install nodejs
                  If that ends ok
                  node -v
                    still no luck :(
                    I’m logging off for the evening, but I’ll check back in tomorrow. Thank you for all the help you provide!
                    kittypi@KITTYpi:~/MagicMirror $ sudo apt update
                    Hit:1 http://deb.debian.org/debian bookworm InRelease
                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                    Reading package lists... Done
                    Building dependency tree... Done
                    All packages are up to date.
                      libbasicusageenvironment1 libgroupsock8 liblivemedia77 linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.25+rpt-rpi-2712
                      linux-headers-6.12.25+rpt-rpi-v8 linux-image-6.12.25+rpt-rpi-2712 linux-image-6.12.25+rpt-rpi-v8 linux-kbuild-6.12.25+rpt
                      python3-v4l2
                    Use 'sudo apt autoremove' to remove them.
                    The following additional packages will be installed:
                      libc-ares2 libnode108 libuv1 node-acorn node-busboy node-cjs-module-lexer node-undici node-xtend nodejs-doc
                    Suggested packages:
                      npm
                    The following NEW packages will be installed:
                      libc-ares2 libnode108 libuv1 node-acorn node-busboy node-cjs-module-lexer node-undici node-xtend nodejs nodejs-doc
                    0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 14.2 MB of archives.
                    After this operation, 66.5 MB of additional disk space will be used.
                    Do you want to continue? [Y/n] y
                    Get:1 http://deb.debian.org/debian bookworm/main arm64 libc-ares2 arm64 1.18.1-3 [99.2 kB]
                    Get:2 http://deb.debian.org/debian bookworm/main arm64 libuv1 arm64 1.44.2-1+deb12u1 [130 kB]
                    Get:3 http://deb.debian.org/debian bookworm/main arm64 node-xtend all 4.0.2-3 [3,932 B]
                    Get:4 http://deb.debian.org/debian bookworm/main arm64 nodejs arm64 18.20.4+dfsg-1~deb12u1 [319 kB]
                    Get:5 http://deb.debian.org/debian bookworm/main arm64 node-acorn all 8.8.1+ds+~cs25.17.7-2 [128 kB]
                    Get:6 http://deb.debian.org/debian bookworm/main arm64 node-cjs-module-lexer all 1.2.2+dfsg-5 [30.1 kB]
                    Get:7 http://deb.debian.org/debian bookworm/main arm64 node-busboy all 1.6.0+~cs2.6.0-2 [16.9 kB]
                    Get:8 http://deb.debian.org/debian bookworm/main arm64 node-undici all 5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4 [285 kB]
                    Get:9 http://deb.debian.org/debian bookworm/main arm64 libnode108 arm64 18.20.4+dfsg-1~deb12u1 [9,565 kB]
                    Get:10 http://deb.debian.org/debian bookworm/main arm64 nodejs-doc all 18.20.4+dfsg-1~deb12u1 [3,579 kB]
                    Fetched 14.2 MB in 4s (3,796 kB/s)
                    Selecting previously unselected package libc-ares2:arm64.
                    (Reading database ... 171415 files and directories currently installed.)
                    Preparing to unpack .../0-libc-ares2_1.18.1-3_arm64.deb ...
                    Unpacking libc-ares2:arm64 (1.18.1-3) ...
                    Selecting previously unselected package libuv1:arm64.
                    Preparing to unpack .../1-libuv1_1.44.2-1+deb12u1_arm64.deb ...
                    Unpacking libuv1:arm64 (1.44.2-1+deb12u1) ...
                    Selecting previously unselected package node-xtend.
                    Preparing to unpack .../2-node-xtend_4.0.2-3_all.deb ...
                    Unpacking node-xtend (4.0.2-3) ...
                    Selecting previously unselected package nodejs.
                    Preparing to unpack .../3-nodejs_18.20.4+dfsg-1~deb12u1_arm64.deb ...
                    Unpacking nodejs (18.20.4+dfsg-1~deb12u1) ...
                    Selecting previously unselected package node-acorn.
                    Preparing to unpack .../4-node-acorn_8.8.1+ds+~cs25.17.7-2_all.deb ...
                    Unpacking node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                    Selecting previously unselected package node-cjs-module-lexer.
                    Preparing to unpack .../5-node-cjs-module-lexer_1.2.2+dfsg-5_all.deb ...
                    Unpacking node-cjs-module-lexer (1.2.2+dfsg-5) ...
                    Selecting previously unselected package node-busboy.
                    Preparing to unpack .../6-node-busboy_1.6.0+~cs2.6.0-2_all.deb ...
                    Unpacking node-busboy (1.6.0+~cs2.6.0-2) ...
                    Selecting previously unselected package node-undici.
                    Preparing to unpack .../7-node-undici_5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4_all.deb ...
                    Unpacking node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                    Selecting previously unselected package libnode108:arm64.
                    Preparing to unpack .../8-libnode108_18.20.4+dfsg-1~deb12u1_arm64.deb ...
                    Unpacking libnode108:arm64 (18.20.4+dfsg-1~deb12u1) ...
                    Selecting previously unselected package nodejs-doc.
                    Preparing to unpack .../9-nodejs-doc_18.20.4+dfsg-1~deb12u1_all.deb ...
                    Unpacking nodejs-doc (18.20.4+dfsg-1~deb12u1) ...
                    Setting up node-cjs-module-lexer (1.2.2+dfsg-5) ...
                    Setting up libc-ares2:arm64 (1.18.1-3) ...
                    Setting up libuv1:arm64 (1.44.2-1+deb12u1) ...
                    Setting up nodejs-doc (18.20.4+dfsg-1~deb12u1) ...
                    Setting up node-xtend (4.0.2-3) ...
                    Setting up node-busboy (1.6.0+~cs2.6.0-2) ...
                    Setting up node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                    Setting up node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                    Setting up libnode108:arm64 (18.20.4+dfsg-1~deb12u1) ...
                    Setting up nodejs (18.20.4+dfsg-1~deb12u1) ...
                    update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                    Processing triggers for man-db (2.11.2-2) ...
                    Processing triggers for libc-bin (2.36-9+rpt2+deb12u13) ...
                    kittypi@KITTYpi:~/MagicMirror $ node -v
                    v22.19.0
                    sudo n 22.21.1
                    hash -r
                    node -v
                    v22.19.0
                      @angeliKITTYx so much fun. I hate when the tools only do half a job
                      sudo apt install npm
                      Then
                      npm -v
                      Then
                      sudo n 22.21.1
                      hash -r
                      node -v
                        it is just refusing to take 22.21.1
                        Setting up node-es-abstract (1.20.4+~cs26.27.47-1) ...
                        Setting up node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
                        Setting up node-util (0.12.5+~1.0.10-1) ...
                        Setting up node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
                        Setting up node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
                        Setting up node-assert (2.0.0+~cs3.9.8-2) ...
                        Setting up webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
                        Setting up node-parse-json (5.2.0+~cs5.1.7-1) ...
                        Setting up node-read-pkg (5.2.0-2) ...
                        Setting up node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
                        Setting up node-tape (5.6.1+~cs8.20.19-1) ...
                        Setting up node-css-loader (6.7.2+~cs14.0.11-1) ...
                        Setting up node-tap (16.3.2+ds1+~cs50.8.16-1+deb12u1) ...
                        Setting up node-deep-equal (2.1.0+~cs31.12.80-1) ...
                        Setting up npm (9.2.0~ds1-1) ...
                        kittypi@KITTYpi:~/MagicMirror $ npm -v
                        11.13.0
                        sudo n 22.21.1
                        hash -r
                        node -v
                        added 1 package in 2s
                          installing : node-v22.21.1
                               mkdir : /usr/local/n/versions/node/22.21.1
                               fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-arm64.tar.xz
                             copying : node/22.21.1
                           installed : v22.21.1 (with npm 10.9.4)
                        Note: the node command changed location and the old location may be remembered in your current shell.
                                 old : /usr/bin/node
                                 new : /usr/local/bin/node
                        If "node --version" shows the old version then start a new shell, or reset the location hash with:
                        hash -r  (for bash, zsh, ash, dash, and ksh)
                        rehash   (for csh and tcsh)
                        v22.19.0
                        kittypi@KITTYpi:~/MagicMirror $ node --version
                        v22.19.0
                        kittypi@KITTYpi:~/MagicMirror $ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                        bash: $: command not found
                          @angeliKITTYx
                          The last command you have an extra leading $
                          When you copy/paste you only need to hit the little rectangle button at the en
                          But you dont need all that . The code is downloaded
                          Just do
                          npm run install-mm
                            how do i do percussive maintenance on code xD
                            kittypi@KITTYpi:~/MagicMirror $ cd ~/MagicMirror
                            npm run install-mm
                            > magicmirror@2.35.0 install-mm
                            > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                            npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T20_16_16_675Z-debug-0.log
                              @angeliKITTYx the end of your prior log post says 22.21.1 is installed
                                 installed : v22.21.1 (with npm 10.9.4)  <-----
                              are you in the same terminal window??
                              if so, you need
                              hash -r
                              to capture the path change
                              do
                              which node
                              so we can see where it it located…
                              @angeliKITTYx
                                all the same terminal window. i don’t have anything else open. i know it says 22.21.1, but then node version says 19… very odd.
                                kittypi@KITTYpi:~/MagicMirror $ hash -r
                                kittypi@KITTYpi:~/MagicMirror $ which node
                                /usr/local/node/bin/node
                                v22.19.0
                                  @angeliKITTYx ok, close that window and open another and
                                  try the node --version again
                                    closed the terminal, opened a new terminal…
                                    kittypi@KITTYpi:~ $ node --version
                                    v22.19.0
                                    kittypi@KITTYpi:~ $ cd MagicMirror
                                    v22.19.0
                                      @angeliKITTYx weird
                                      Do
                                      which node
                                      Go to that folder
                                      sudo mv node onode
                                      hash -r
                                      which node
                                      node —version
                                        kittypi@KITTYpi:~/MagicMirror $ cd ..
                                        kittypi@KITTYpi:~ $ which node
                                        kittypi@KITTYpi:/ $ cd usr
                                        kittypi@KITTYpi:/usr $ cd local
                                        kittypi@KITTYpi:/usr/local $ cd node
                                        kittypi@KITTYpi:/usr/local/node $ cd bin
                                        kittypi@KITTYpi:/usr/local/node/bin $ cd node
                                        bash: cd: node: Not a directory
                                        kittypi@KITTYpi:/usr/local/node/bin $ sudo mv node onode
                                        hash -r
                                        which node
                                        node —version
                                        /usr/local/bin/node
                                        node:internal/modules/cjs/loader:1386
                                          throw err;
                                        Error: Cannot find module '/usr/local/node/bin/—version'
                                            at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                            at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                            at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                            at Function._load (node:internal/modules/cjs/loader:1192:37)
                                            at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                                            at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                                            at node:internal/main/run_main_module:36:49 {
                                          code: 'MODULE_NOT_FOUND',
                                          requireStack: []
                                        Node.js v22.21.1
                                          @angeliKITTYx i hate this editor on my phone changing the characters
                                          do
                                          node --version
                                          it should report 22.21.1
                                          then
                                          npm run install-mm
                                            it’s booting now! hurray! however, now I’m getting the package lock error when i try to complete the calendarext3 update and none of my events are populating. I have a thread up on someone else’s trouble shooting but I’m out of time this morning. I be back at it this afternoon. thank you again for all your help.
                                            • 3 / 4
