    Default weather module not displaying forecast
    3 Posts 2 Posters 15 Views 2 Watching
      DarrenO 0
      Since updating MM to 2.35 from 2.34, the default weather module is no longer displaying the forecast.
      I use :
      “openweathermap” option for the weatherProvider: key;
      “forecast” option for the type: key; and
      “/forecast” option for the weatherEndpoint: key
      Other than updating the apiVersion from 2.5 to 3.0 in the config, no other changes have been made to any other keys within the module’s config and the module only shows “WEATHER FORECAST” as per the header: key, and then only displays Loading … where the forecast should be displayed.
      My config for the module is as follows:
          module: "weather",
          header: "WEATHER FORECAST",
              // General Options
              type: "forecast",
              roundTemp: true,
              degreeLabel: true,
              updateInterval: 300000,
              showPeriod: true,
              showPeriodUpper: false,
              appendLocationNameToHeader: false,
              // Forecast Options
              tableClass: "xsmall",
              colored: true,
              fade: false,
              maxNumberOfDays: 5,
              // OpenWeatherMap Options
              apiVersion: "3.0",
              apiBase: "https://api.openweathermap.org/data/",
              weatherEndpoint: "/forecast",
              apiKey: "xxxxx",
      What am i missing in this latest release in the config of this module in MM 2.35?
        sdetweil @DarrenO 0
        @DarrenO-0 see
        https://forum.magicmirror.builders/post/122915
          sdetweil @DarrenO 0
          @DarrenO-0 get the new apikey, requires a credit card
          Remove apiVersion, apiBase, weatherEndpoint,
          Let those default
          Remove location
          Add lat, lon
