    Default weather module not displaying forecast
    5 Posts 2 Posters 149 Views 2 Watching
      DarrenO 0
      Since updating MM to 2.35 from 2.34, the default weather module is no longer displaying the forecast.
      I use :
      “openweathermap” option for the weatherProvider: key;
      “forecast” option for the type: key; and
      “/forecast” option for the weatherEndpoint: key
      Other than updating the apiVersion from 2.5 to 3.0 in the config, no other changes have been made to any other keys within the module’s config and the module only shows “WEATHER FORECAST” as per the header: key, and then only displays Loading … where the forecast should be displayed.
      My config for the module is as follows:
          module: "weather",
          header: "WEATHER FORECAST",
              // General Options
              type: "forecast",
              roundTemp: true,
              degreeLabel: true,
              updateInterval: 300000,
              showPeriod: true,
              showPeriodUpper: false,
              appendLocationNameToHeader: false,
              // Forecast Options
              tableClass: "xsmall",
              colored: true,
              fade: false,
              maxNumberOfDays: 5,
              // OpenWeatherMap Options
              apiVersion: "3.0",
              apiBase: "https://api.openweathermap.org/data/",
              weatherEndpoint: "/forecast",
              apiKey: "xxxxx",
      What am i missing in this latest release in the config of this module in MM 2.35?
        sdetweil @DarrenO 0
        @DarrenO-0 get the new apikey, requires a credit card
        Remove apiVersion, apiBase, weatherEndpoint,
        Let those default
        Remove location
        Add lat, lon
          sdetweil @DarrenO 0
          @DarrenO-0 see
          https://forum.magicmirror.builders/post/122915
            sdetweil @DarrenO 0
            Let those default
            Remove location
            Add lat, lon
              DarrenO 0 @sdetweil
              @sdetweil thanks, but i don’t think i’ll be providing my credit card details to a service for them just to keep it on file for the unlikely possibility that i’d make 1000+ API calls a day.
              I’ll just comment out or remove that section of my config.js file.
              • D DarrenO 0 has marked this topic as solved
                sdetweil @DarrenO 0
                @DarrenO-0 I understand. You might be able to switch to a different provider on the weather module, depending on where you are. Not all providers are world wide
