    Scaling issues with MM 2.35 using NPM Run Start:x11
    7 Posts 2 Posters 335 Views 2 Watching
      DDE12
      I am having to use NPM Run Start:x11 to get MM 2.35 to run. NPM start was working in 2.34. Now I am having scaling and text issues and would greatly appreciate some help with troubleshooting this. Here is some info about my machine:
      [2026-04-11 21:12:18.020] [INFO] [systeminformation]
      System Information
      • SYSTEM: manufacturer: libre-computer; model: aml-s905x-cc-v2; virtual: false; MM: v2.35.0
      • OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.1.92-15907-gf36fd2695db3
      • VERSIONS: electron: 41.1.0; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
      • ENV: XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
        WAYLAND_DISPLAY: undefined; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
      • RAM: total: 1944.19 MB; free: 969.87 MB; used: 974.32 MB
        I posted pictures comparing 2.34 and 2.35. Please let me know if I can provide additional info that would be helpful. Thanks!2.34.png 2.35.png
        sdetweil @DDE12
        @DDE12 did your css/custom.css file get moved to the config folder?
          sdetweil @DDE12
          @DDE12 we changed the default for npm start to be Wayland as we documented in the release notes
          That is why you have to use npm run start:x11
          We also moved user files to the config folder
          And moved the default modules to their own folder away from the modules folder
          As I posted about a month ago.
          How did you upgrade? git pull or my scripted upgrade?
            DDE12 @sdetweil
            I used your script to upgrade. It was the custom css. custom.css was moved but I had other custom files and folders in /css. I moved all the contents of /css to /config and everything seems to be back to what I had before. Great catch! Thank you so much!
              sdetweil @DDE12
              @DDE12 when did you run the script?
              I thought I fixed it to move everything but the 4 default files
                if you don’t push the change, it doesn’t change!!.. doah… thanks for the report upgrade fixed now
                • D DDE12 has marked this topic as solved on
                  DDE12 @sdetweil
                  Great! I’m glad I helped you while you were helping me. :)
