    Magic Mirror Dynamic Calendar and Pirate Sky Forecast Questions
    8 Posts 4 Posters 3.4k Views 4 Watching
      miriamburrell
      I know there have been a lot of questions about dynamic calendars, but I wanted to ask again based on what I’ve found. From my research, it seems like MagicMirror usually functions only as a display and doesn’t natively support input (even with some third-party modules). Has anyone managed to set up a system where you can add events directly to Google Calendar?
      Also, I’m trying to get my weather forecast to display horizontally across the week instead of vertically. I’m currently using the Pirate Sky Forecast module (which I really like), but it only seems to support a vertical layout. Does anyone have suggestions for achieving a horizontal view? I’d prefer to avoid paying for an API key, so I’m open to alternatives that fit that requirement.
        sdetweil @miriamburrell
        @miriamburrell there was a user who created a modified ext3 wall calendar to add entries to a calendar.
        He never published his module
        Weather uses the njk templates to create the web content
        You could create a new version of forecast.njk to change the layout. Not something you can do w css
          miriamburrell
          Thanks for your suggestion.
            @miriamburrell a place to start is the browser developers window, elements tab
            You can copy/paste the module generated html
            And work on how you might want it to be for your layout requirements
            Make a small html file to load and test
            Then adjust/rewrite the njk to match it
            AI might be able to help with that
            • O
              OliWer @sdetweil
              Something like this?:
              left hourly and right daily forecast, using openweathermap as API provider, but that should not make a difference.
              Is this something that could be build into the default module? I’m currently testing it with a configurable layout option and could provide my changes if that makes sense.
              S karsten13K 2 Replies Last reply Reply Quote 0
                sdetweil @OliWer
                @OliWer possibly. You are the first to want this kind of layout.
                You could submit a pr and see what happens.
                • karsten13K
                  karsten13 @OliWer
                  we introduced Themes for this use case with the lastest mm release
                  O 1 Reply Last reply Reply Quote 2
                  • O
                    OliWer @karsten13
                    @karsten13 Oh, somehow missed that. Will look into that, looks promising, thanks!
