    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 7.3k Views 2 Watching
    • 1 Offline
      1a2a3a @1a2a3a
      @sdetweil can we fix the pm2 please?
        sdetweil @1a2a3a
        @1a2a3a use my mm.sh
        #!/bin/bash
        if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
           # if WAYLAND_DISPLAYis set, use it, else set to -0
           export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
           npm run start:wayland
        else
           DISPLAY=:0 npm run start:x11
        fi
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1a2a3a @sdetweil
          hsa@HSA:~ $ find ~/MagicMirror/modules -type d | grep punycode | sort
          /home/hsa/MagicMirror/modules/MMM-Jast/node_modules/punycode
          • 1 Offline
            1a2a3a @sdetweil
            @sdetweil it doesnt work still unfortunately. it goes into a black screen then back to wallpaper and keep looping in this manner…
              sdetweil @1a2a3a
              @1a2a3a yep, its a dependency 3 layers down…
              “node_modules/yahoo-finance2”
              only thing is to open an issue on the module github page and see if the author can/will fix it
              • 1 Offline
                1a2a3a @sdetweil
                @sdetweil ok got it. thanks. since the punycode is not material lets ignore it for now and focus on the pm2 haha.
                  sdetweil @1a2a3a
                  • 1 Offline
                    1a2a3a @sdetweil
                    @sdetweil i did. i copied your code as suggest and paste it into my mm.sh and it the same issue.
                      sdetweil @1a2a3a
                      @1a2a3a which issue?
                      the punycode will still be reported…
                      it should start mm with the appropriate start command
                      1 2 Replies Last reply Reply Quote 0
                      • 1 Offline
                        1a2a3a @sdetweil
                        @sdetweil the pm2 issue.
                        im not able to pm2 start magicmirror
                        • 1 Offline
                          1a2a3a @sdetweil
                          @sdetweil i use your mm.sh code.
                          then i ran pm2 start MagicMirror
                          then i get this
                          (node:1995398) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
                          (Use `node --trace-deprecation ...` to show where the warning was created)
                          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                          [PM2] [MagicMirror](0) ✓
                          [PM2] Process successfully started
                          and the mirror just go into a blackscreen then loop back to wallpaper then loop back again to blackscreen and it keeps going back and forth
                            sdetweil @1a2a3a
                            @1a2a3a ok, lets test
                            pm2 stop all
                            bash -x mm.sh
                            where ever mm.sh is, mine is usually in ~/MagicMirror/installers
                            pm2 status
                            pm2 info xx
                            where xx is the line number of the MagicMirror instance you are starting
                            to see which mm.sh it is using , for example
                            │ script path       │ /home/sam/MagicMirror/installers/mm.sh
                            • 1 Offline
                              1a2a3a @sdetweil
                              @sdetweil mm.sh is the same location as yours. this is the bash result
                              hsa@HSA:~/MagicMirror/installers $ bash -x mm.sh
                              + cd /home/hsa/MagicMirror
                              ++ ps -ef
                              ++ grep -v grep
                              ++ wc -l
                              ++ grep -i -e xway -e labwc
                              + '[' 1 -ne 0 ']'
                              + export WAYLAND_DISPLAY=wayland-1
                              + WAYLAND_DISPLAY=wayland-1
                              + npm run start:wayland
                              > magicmirror@2.36.0 start:wayland
                              > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --ozone-platform=wayland
                              [2026-05-02 01:18:20.742] [LOG]   [app] Starting MagicMirror: v2.36.0
                              [2026-05-02 01:18:20.750] [LOG]   [utils] Loading config ...
                              [2026-05-02 01:18:20.754] [INFO]  [utils] Checking config file /home/hsa/MagicMirror/config/config.js ...
                              [2026-05-02 01:18:20.822] [INFO]  [utils] Your configuration file doesn't contain syntax errors :)
                              [2026-05-02 01:18:20.822] [INFO]  [utils] Checking modules structure configuration ...
                              [2026-05-02 01:18:20.880] [INFO]  [utils] Your modules structure configuration doesn't contain errors :)
                              [2026-05-02 01:18:20.883] [LOG]   [app] Loading module helpers ...
                              [2026-05-02 01:18:20.883] [LOG]   [app] No helper found for module: alert.
                              [2026-05-02 01:18:20.887] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:20.887] [LOG]   [node_helper] Module helper loaded: updatenotification
                              [2026-05-02 01:18:20.888] [LOG]   [app] No helper found for module: clock.
                              [2026-05-02 01:18:21.199] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:21.206] [LOG]   [node_helper] Module helper loaded: MMM-Jast
                              [2026-05-02 01:18:21.682] [INFO]  [systeminformation]
                              ####  System Information  ####
                              - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.0; virtual: false; MM: v2.36.0
                              - OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.47+rpt-rpi-2712
                              - VERSIONS: electron: 41.3.0; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
                              - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                                          WAYLAND_DISPLAY:  wayland-1; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
                              - RAM:      total: 8059.14 MB; free: 6835.58 MB; used: 1223.56 MB
                              - OTHERS:   uptime: 201889 minutes; timeZone: Asia/Singapore
                              [2026-05-02 01:18:22.054] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:22.054] [LOG]   [node_helper] Module helper loaded: MMM-GoogleDocs-Notes
                              [2026-05-02 01:18:22.080] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:22.081] [LOG]   [node_helper] Module helper loaded: newsfeed
                              [2026-05-02 01:18:22.087] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:22.087] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-NewsAPI' - Minimum version: 2.21.0 - Current version: 2.36.0
                              [2026-05-02 01:18:22.087] [LOG]   [app] Version is ok!
                              [2026-05-02 01:18:22.088] [LOG]   [node_helper] Module helper loaded: MMM-NewsAPI
                              [2026-05-02 01:18:22.089] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:22.089] [LOG]   [node_helper] Module helper loaded: MMM-MyScoreboard
                              [2026-05-02 01:18:22.096] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:22.097] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-SoccerLiveScore' - Minimum version: 2.1.0 - Current version: 2.36.0
                              [2026-05-02 01:18:22.097] [LOG]   [app] Version is ok!
                              [2026-05-02 01:18:22.097] [LOG]   [node_helper] Module helper loaded: MMM-SoccerLiveScore
                              [2026-05-02 01:18:22.192] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:22.193] [LOG]   [node_helper] Module helper loaded: MMM-OneDrive
                              [2026-05-02 01:18:22.193] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:22.194] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3Agenda
                              [2026-05-02 01:18:22.265] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:22.265] [LOG]   [node_helper] Module helper loaded: calendar
                              [2026-05-02 01:18:22.266] [LOG]   [node_helper] Initializing new module helper ...
                              [2026-05-02 01:18:22.266] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
                              [2026-05-02 01:18:22.266] [LOG]   [app] All module helpers loaded.
                              [2026-05-02 01:18:22.270] [LOG]   [server] Starting server on port 8080 ...
                              [2026-05-02 01:18:22.280] [ERROR] [unknown] (node:1996838) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                              (Use `electron --trace-deprecation ...` to show where the warning was created)
                              [2026-05-02 01:18:22.394] [LOG]   [app] Server started ...
                              [2026-05-02 01:18:22.395] [LOG]   [node_helper] Connecting socket for: updatenotification
                              [2026-05-02 01:18:22.396] [LOG]   [node_helper] Starting module helper: updatenotification
                              [2026-05-02 01:18:22.397] [LOG]   [node_helper] Connecting socket for: MMM-Jast
                              [2026-05-02 01:18:22.397] [LOG]   [MMM-Jast] MMM-Jast helper method started...
                              [2026-05-02 01:18:22.397] [LOG]   [node_helper] Connecting socket for: MMM-GoogleDocs-Notes
                              [2026-05-02 01:18:22.398] [LOG]   [node_helper] Connecting socket for: newsfeed
                              [2026-05-02 01:18:22.398] [LOG]   [newsfeed] Starting node helper for: newsfeed
                              [2026-05-02 01:18:22.399] [LOG]   [node_helper] Connecting socket for: MMM-NewsAPI
                              [2026-05-02 01:18:22.399] [LOG]   [MMM-NewsAPI] Starting node_helper for module: MMM-NewsAPI
                              [2026-05-02 01:18:22.399] [LOG]   [node_helper] Connecting socket for: MMM-MyScoreboard
                              [2026-05-02 01:18:22.399] [LOG]   [MMM-MyScoreboard] Starting node_helper for module [MMM-MyScoreboard]
                              [2026-05-02 01:18:22.491] [LOG]   [node_helper] Connecting socket for: MMM-SoccerLiveScore
                              [2026-05-02 01:18:22.492] [LOG]   [MMM-SoccerLiveScore] Starting node helper for: MMM-SoccerLiveScore
                              [2026-05-02 01:18:22.492] [LOG]   [node_helper] Connecting socket for: MMM-OneDrive
                              [2026-05-02 01:18:22.493] [INFO]  [MMM-OneDrive] [MMM-OneDrive] [node_helper] Starting module helper
                              [2026-05-02 01:18:22.494] [INFO]  [lib] [DiskCaching] Initialized in directory: /home/hsa/MagicMirror/modules/MMM-OneDrive/cache/photos
                              [2026-05-02 01:18:22.495] [INFO]  [MMM-OneDrive] [MMM-OneDrive] [node_helper] Started
                              [2026-05-02 01:18:22.495] [LOG]   [node_helper] Connecting socket for: MMM-CalendarExt3Agenda
                              [2026-05-02 01:18:22.496] [LOG]   [node_helper] Connecting socket for: calendar
                              [2026-05-02 01:18:22.497] [LOG]   [calendar] Starting node helper for: calendar
                              [2026-05-02 01:18:22.497] [LOG]   [node_helper] Connecting socket for: MMM-CalendarExt3
                              [2026-05-02 01:18:22.498] [LOG]   [app] Sockets connected & modules started ...
                              [2026-05-02 01:18:22.508] [LOG]   [electron] Launching application.
                              /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
                                which means it THINKS you are running wayland…
                                crtl-c in that window just to make sure its stopped
                                if you do
                                npm run start:x11
                                does MM come up?
                                if so, change the
                                to
                                npm run start:x11
                                and then pm2 start MagicMirror
                                • 1 Offline
                                  1a2a3a @sdetweil
                                  @sdetweil i have change mm.sh to
                                     npm run start:x11
                                  else
                                  fi
                                  pm2 start Magicmirror does not start still
                                    sdetweil @1a2a3a
                                    @1a2a3a ok, lets reboot once
                                    • 1 Offline
                                      1a2a3a @sdetweil
                                      @sdetweil ok done. same. black screen with mouse > wall paper > continue looping
                                      the funny thing is that when i do the bash, it works. just pm2 start doesnt.
                                        sdetweil @1a2a3a
                                        @1a2a3a ok, can you show the output of
                                        pm2 logs --lines=100
                                        • 1 Offline
                                          1a2a3a @sdetweil
                                          /home/hsa/.pm2/pm2.log last 100 lines:
                                          PM2        | 2026-05-02T01:40:40: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                          PM2        | 2026-05-02T01:40:40: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                          PM2        | 2026-05-02T01:40:40: PM2 log: App [MagicMirror:0] online
                                          PM2        | 2026-05-02T01:40:40: PM2 log: Script /home/hsa/MagicMirror/installers/mm.sh had too many unstable restarts (16). Stopped. "errored"
                                          PM2        | 2026-05-02T01:41:05: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                          PM2        | 2026-05-02T01:41:05: PM2 log: App [MagicMirror:0] online
                                          PM2        | 2026-05-02T01:41:05: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                          PM2        | 2026-05-02T01:41:05: PM2 log: Script /home/hsa/MagicMirror/installers/mm.sh had too many unstable restarts (16). Stopped. "errored"
                                          PM2        | 2026-05-02T01:44:14: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                          PM2        | 2026-05-02T01:44:14: PM2 log: App [MagicMirror:0] online
                                          PM2        | 2026-05-02T01:44:37: PM2 log: Stopping app:MagicMirror id:0
                                          PM2        | 2026-05-02T01:44:52: PM2 error: Error: EIO: i/o error, write
                                          PM2        | 2026-05-02T01:44:52: PM2 log: pid=4701 msg=failed to kill - retrying in 100ms
                                          PM2        | 2026-05-02T01:44:53: PM2 log: pid=4701 msg=failed to kill - retrying in 100ms
                                          PM2        | 2026-05-02T01:44:53: PM2 log: Process with pid 4701 still alive after 1600ms, sending it SIGKILL now...
                                          PM2        | 2026-05-02T01:44:53: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                                          PM2        | 2026-05-02T01:44:54: PM2 log: pid=4701 msg=process killed
                                          /home/hsa/.pm2/logs/MagicMirror-error.log last 100 lines:
                                          0|MagicMir | /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
                                          0|MagicMir | [2026-05-01 22:58:12.952] [ERROR] [unknown] (node:1972286) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
                                          0|MagicMir | [2026-05-01 22:59:26.457] [ERROR] [unknown] (node:1972654) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-01 23:00:45.581] [ERROR] [unknown] (node:1972996) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-01 23:00:51.435] [ERROR] [unknown] (node:1973259) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-01 23:02:41.213] [ERROR] [unknown] (node:1973622) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-01 23:02:47.007] [ERROR] [unknown] (node:1973926) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-01 23:48:30.795] [ERROR] [unknown] (node:1978494) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-01 23:56:37.164] [ERROR] [unknown] (node:1979751) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-01 23:57:50.550] [ERROR] [unknown] (node:1980093) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 00:35:18.202] [ERROR] [unknown] (node:1986797) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 00:36:30.821] [ERROR] [unknown] (node:1987135) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 00:37:43.066] [ERROR] [unknown] (node:1987721) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 00:38:56.786] [ERROR] [unknown] (node:1988072) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 00:40:10.172] [ERROR] [unknown] (node:1988442) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 00:41:23.991] [ERROR] [unknown] (node:1988801) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 00:42:37.723] [ERROR] [unknown] (node:1989164) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 00:43:50.993] [ERROR] [unknown] (node:1989673) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:01:40.022] [ERROR] [unknown] (node:1991891) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:02:52.189] [ERROR] [unknown] (node:1992235) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:04:42.831] [ERROR] [unknown] (node:1992608) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:04:48.383] [ERROR] [unknown] (node:1992913) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:06:00.472] [ERROR] [unknown] (node:1993256) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:07:12.592] [ERROR] [unknown] (node:1993598) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:08:25.975] [ERROR] [unknown] (node:1993969) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:09:39.688] [ERROR] [unknown] (node:1994320) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:10:53.313] [ERROR] [unknown] (node:1994688) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:13:18.207] [ERROR] [unknown] (node:1995430) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:14:30.831] [ERROR] [unknown] (node:1995781) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:27:17.967] [ERROR] [unknown] (node:1998078) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:31:48.948] [ERROR] [unknown] (node:1998975) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:31:54.952] [ERROR] [unknown] (node:1999283) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:36:40.810] [ERROR] [unknown] (node:2153) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:36:53.372] [ERROR] [unknown] (node:3319) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:38:13.968] [ERROR] [unknown] (node:3697) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | [2026-05-02 01:39:57.114] [ERROR] [unknown] (node:4016) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          0|MagicMir | /home/hsa/MagicMirror/installers/mm.sh: line 2: $'\r': command not found
                                          0|MagicMir | /home/hsa/MagicMirror/installers/mm.sh: line 3: cd: $'/home/hsa/MagicMirror\r': No such file or directory
                                          0|MagicMir | [2026-05-02 01:44:16.815] [ERROR] [unknown] (node:4725) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          • 1 Offline
                                            1a2a3a @sdetweil
                                            @sdetweil does this needs to be fix?
                                            (node:5692) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
                                            • 2 / 4
