    MagicMirror Module Sandbox
    2 Posts 2 Posters 1.7k Views 2 Watching
    • A
      angeldeejay
      Hi everyone!
      I wanted to share something that came from my own frustration developing MagicMirror modules.
      For years, testing a module meant either setting up a full MagicMirror installation (overkill for just iterating on one module), or developing blind and hoping it works when you finally deploy.
      I built MagicMirror Module Sandbox to change that. It’s a lightweight dev tool that spins up a local testing environment for your module in seconds — no full MagicMirror install, no Docker, just your module and a browser window.
      What you get:
      • 🚀 Zero setup — Run npx @angeldeejay/magicmirror-module-sandbox from inside your module folder and you’re done
      • ⚡ Live reload — Changes to your config or module files reload instantly
      • 🎛️ Visual config editor — Edit your module’s config through a browser UI instead of hand-editing JSON
      • 🔄 Full MagicMirror lifecycle — Simulates start(), notificationReceived(), updateDom(), and all real lifecycle hooks
      • 🔌 Real node_helper.js support — Socket.io communication works exactly like production
      • 🐛 Debug panel — Inspect both helper logs (server-side) and browser console in one place
      • 📡 Notifications inspector — Send frontend notifications, monitor socket traffic in real time
      • ✅ Module quality check — Quick analysis against MagicMirror’s third-party module standards
      How to use it:
      One-off test (no install needed)
      Then open http://localhost:3010 and start hacking.
      Works great for:
      • Rapid iteration while developing
      • Validating config changes before deploying to your Pi
      • Testing in CI pipelines (Playwright integration test support included)
      • Debugging why a module behaves differently on the actual MagicMirror
      GitHub: https://github.com/angeldeejay/magicmirror-module-sandbox
      npm: https://www.npmjs.com/package/@angeldeejay/magicmirror-module-sandbox
      This is v1.1.0, tested across real third-party modules. Stable and ready to use.
      If you’re a module developer, I’d love to hear what you think — open issues if something doesn’t behave as expected, or let me know what you’d like to see next.
      H 1 Reply Last reply Reply Quote 3
      • H
        HeikoGr @angeldeejay
        @angeldeejay that looks great! I will test it and maybe use it instead of or together with my DevContainer https://github.com/HeikoGr/MMM-DevContainer
