    MMM-HomeAssistant
    23 Posts 10 Posters 12.9k Views 8 Watching
    • O
      onkelbobby
      I just found this awesome module and installed on our all newly installed MagicMirror.
      After integrating it to HomeAssistant everything is working just fine. There is one downside:
      If I switch the screen off via Home Assistant
      it turns ‘off’ but switches back ‘on’ on its own after 3-5sec.
      I checked the MQTT vie MQTT Explorer but I just see the commands coming from the MachiMirror
      any I deal what is wrong?
      here is the config I’m using:
          		module: 'MMM-HomeAssistant',
              		mqttServer: 'mqtt://192.168.178.100',
              		mqttPort: 1883,
              		username: 'mqtt-client',
              		password: 'PASSWORD',
              		deviceName: 'MagicMirror',
              		autodiscoveryTopic: 'homeassistant',
              		monitorControl: true,
              		brightnessControl: true,
              		moduleControl: true,
      				/***** for xandr
              		monitorStatusCommand: 'xrandr --query | awk \'/Screen/ {print ($8 > 320) ? "true" : "false"}\'',
              		monitorOnCommand: 'xrandr -d :0 --output HDMI-1 --auto --rotate right',
              		monitorOffCommand: 'xrandr -d :0 --output HDMI-1 --off',
      				/***** for Wayland Display Steuerung  */
      				monitorStatusCommand: 'wlr-randr | awk \'/HDMI-A-1/ {found=1} found && /Enabled:/ {print ($2 == "yes") ? "true" : "false"; exit} END {if(!found) print "false"}\'',
              		monitorOnCommand: 'wlr-randr --output HDMI-A-1 --on',
              		monitorOffCommand: 'wlr-randr --output HDMI-A-1 --off',
              		pm2ProcessName: 'mm',
              		refreshBrowser: true,
              		customCommands: [
                      		name: 'Update MagicMirror',
                      		command: 'bash ~/MagicMirror/modules/MMM-HomeAssistant/custom_commands/update_MM.sh'
      any Idea what is wrong?
      Thank you
      S O 2 Replies Last reply
        sdetweil @onkelbobby
        @onkelbobby generally you should post a message to the author in the module github issues section
        • O
          onkelbobby @onkelbobby
          Thank you @sdetweil for notifying me.
          I opened an issue and was eventually able to identify the solution.
          For anyone experiencing the same issue, please refer to the link below:
          https://github.com/ambarusa/MMM-HomeAssistant/issues/13#issuecomment-4502382457
