    MMM-HomeAssistant
    23 Posts 10 Posters 12.5k Views 8 Watching
    • A
      adamambarus @Snille
      @Snille Wow, I am so glad to hear it. I made a test with my real MagicMirror, and a dummy one running on a linux laptop. At this point I added a real uniqueID for the HA device config jsons.
      @Snille said in MMM-HomeAssistant:
      Update: I did some cleaning in the MQTT-queue (with MQTT Explorer) and now it all works. I got to have had my config(s) mixed at some point during my testing. So, now it’s all good. :)
      Hmm, alright!! I will try to think of a handling in case two MM instances want to connect with the same device name. That is the only attribute left on the user.
        schlomm
        I’m just here to say “Thank you” - installed the module yesterday and after some struggling with my MQTT Backend all is working :)
        • UncleRogerU
          UncleRoger
          Just to be clear, this is meant to allow you to control the MM from HA, not display HA info on the MM, right?
            sdetweil @UncleRoger
            @UncleRoger correct MMM-HomeAssistantDisplay
            will display info from ha
              mirrorlover270
              Would you see a chance to include a “sensor” that shows whether an update for a module is available? Right now the sensor on updates can only “hide” the update message on the mirror.
              With an update sensor, I could get a message on my phone and at least trigger the update remotely with the MMM-Remote module.
              Thanks anyway for this great module.
                raymonvdm @mirrorlover270
                I found a display (touchscreen) to setup a family dashboard and i`m making babysteps to get it going again after a long time of trying out MagicMirror
                I did get this module to work and most of the buttons in HomeAssistant work, but since i`m using a GigabyteBrix debian12 pc the screen off and on does not work.
                This however is working to get the screen on/off
                apt install vbetool
                root@debian:~# sudo vbetool dpms off
                root@debian:~# sudo vbetool dpms on
                root@debian:~# cat /etc/sudoers.d/magicmirror
                magicmirror ALL=(ALL) NOPASSWD: /usr/bin/vbetool
                root@debian:~#
                So i changed the on off command to
                /usr/bin/sudo /usr/bin/vbetool dpms off
                /usr/bin/sudo /usr/bin/vbetool dpms on
                But it stops working as soon as i start the MagicMirror using PM2 and i`m not sure why.
                Are there any other options?
                • L
                  Lateadapter
                  I was directed from [MagicMirror Forum] Digest for 1/11/2026 to that discussion and I can show you some kind of alternative regarding Home Assistant controlled MagicMirror. It is using TouchKIO as a mirror client.
                  Recently I did upgrade my many years existing setup and I did summarize it here:
                  https://github.com/Lateadapter/TouchKIO-as-Kiosk-Application-for-MagicMirror
                    sdetweil @raymonvdm
                    @raymonvdm can you show the log?
                    I always recommend testing with manual start after you make a module change
                    pm2 stop all
                    npm start
                    if it comes up ok, ctrl-q, or alt-spacebar, c
                    then pm2 status
                    and pm2 start xxxx
                    where xxxx is the name or number on the row for your application
                      raymonvdm @sdetweil
                      I found out that it stil asked for the user password when performing sudo. I had this statement in /etc/sudoers
                      magicmirror ALL=(ALL:ALL) ALL
                      And this in /etc/sudoers.d/magicmirror
                      For now i removed the line in /etc/sudoers
                      • O
                        onkelbobby
                        I just found this awesome module and installed on our all newly installed MagicMirror.
                        After integrating it to HomeAssistant everything is working just fine. There is one downside:
                        If I switch the screen off via Home Assistant
                        it turns ‘off’ but switches back ‘on’ on its own after 3-5sec.
                        I checked the MQTT vie MQTT Explorer but I just see the commands coming from the MachiMirror
                        any I deal what is wrong?
                        here is the config I’m using:
                            		module: 'MMM-HomeAssistant',
                                		mqttServer: 'mqtt://192.168.178.100',
                                		mqttPort: 1883,
                                		username: 'mqtt-client',
                                		password: 'PASSWORD',
                                		deviceName: 'MagicMirror',
                                		autodiscoveryTopic: 'homeassistant',
                                		monitorControl: true,
                                		brightnessControl: true,
                                		moduleControl: true,
                        				/***** for xandr
                                		monitorStatusCommand: 'xrandr --query | awk \'/Screen/ {print ($8 > 320) ? "true" : "false"}\'',
                                		monitorOnCommand: 'xrandr -d :0 --output HDMI-1 --auto --rotate right',
                                		monitorOffCommand: 'xrandr -d :0 --output HDMI-1 --off',
                        				/***** for Wayland Display Steuerung  */
                        				monitorStatusCommand: 'wlr-randr | awk \'/HDMI-A-1/ {found=1} found && /Enabled:/ {print ($2 == "yes") ? "true" : "false"; exit} END {if(!found) print "false"}\'',
                                		monitorOnCommand: 'wlr-randr --output HDMI-A-1 --on',
                                		monitorOffCommand: 'wlr-randr --output HDMI-A-1 --off',
                                		pm2ProcessName: 'mm',
                                		refreshBrowser: true,
                                		customCommands: [
                                        		name: 'Update MagicMirror',
                                        		command: 'bash ~/MagicMirror/modules/MMM-HomeAssistant/custom_commands/update_MM.sh'
                        any Idea what is wrong?
                        Thank you
                        S O 2 Replies Last reply Reply Quote 0
                          sdetweil @onkelbobby
                          @onkelbobby generally you should post a message to the author in the module github issues section
                          • O
                            onkelbobby @onkelbobby
                            Thank you @sdetweil for notifying me.
                            I opened an issue and was eventually able to identify the solution.
                            For anyone experiencing the same issue, please refer to the link below:
                            https://github.com/ambarusa/MMM-HomeAssistant/issues/13#issuecomment-4502382457
