    How to upgrade a Linux "server" with minimal modules?
    29 Posts 2 Posters 10.6k Views 2 Watching
    • E Offline
      ember1205 @ember1205
      Update…
      Updating the modules crashes the server. So, I’m going to have to get the main server updated… I had to revert to a prior snapshot to get the MM server running again.
        sdetweil @ember1205
        @ember1205 said:
        package-lock.json
        package.json
        erase those and git pull again
        • E Offline
          ember1205 @sdetweil
          @sdetweil I’ll have to try again a little later today maybe… I had to revert the snapshot (removing the module updates) to get it running again.
            sdetweil @ember1205
            @ember1205 understand… please advise your results when you can
            • E Offline
              ember1205 @sdetweil
              @sdetweil I did an OS upgrade to move to Leap 16. I had a couple of quirky issues with that and corrected them. Post-upgrade, I added node24 packages but Leap 16 no longer supports the node18 packages (so, those are gone).
              I updated the modules and then MM and now it throws an error claiming that it can’t locate node18 executable. I tried searching for some sort of symbolic link, but I’m not finding anything.
                sdetweil @ember1205
                @ember1205 did you redo the MM npm install after upgrading node? to make sure any dependencies with node version requirements are resolved?
                • E Offline
                  ember1205 @sdetweil
                  @sdetweil Yep.
                  The only thing is puts on the screen of any potential interest is
                  [ -f node_modules/.bin/husky ] && husky || echo no husky installed
                    sdetweil @ember1205
                    @ember1205 what MM version is this?
                    • E Offline
                      ember1205 @sdetweil
                      @sdetweil I reverted back again (Leap 15.6)
                      I recall seeing a 36 or something somewhere if that helps.
                      I had even moved the MM folder off and tried starting again, re-installed npm 22 and 24, and the errors were exactly the same. Something is out-of-whack somewhere and I haven’t had the time to dig deep enough to understand if it’s MM, my linux machine, or a combo.
                      I’m considering trying a fresh Leap 16 build and seeing what happens. If that works without an issue, then at least I know “it’s possible.”
                        sdetweil @ember1205
                        @ember1205 mm version is in package.json
                        2.35/2.36
                        all custom.css stuff moved to config folder (user managed files go here)
                        default modules moved from modules/default to defaultmodules
                        • E Offline
                          ember1205 @sdetweil
                          @sdetweil As mentioned, I reverted… back to whatever I was previously running.
                          Working on a fresh Leap 16 install, fresh MM install. Running into problems with inability to connect to display (running serveronly, no display connected). Seems that the serverOnly config setting may not get used any more? I have to start the server with “node --run server” to get past the display errors.
                          BTW… fresh install, there is no ‘default’ directory under modules… Thoughts?
                            sdetweil @ember1205
                            default modules moved from modules/default to MagicMirror/defaultmodules
                            “server”: “node ./serveronly”
                            looks like a bug in 2.36 , fixed in 2.37-develop
                            3 more weeks til 2.37
                            you could get develop branch
                            https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                            • E Offline
                              ember1205 @sdetweil
                              @sdetweil The bug may have been around for a while… my mm.sh script is launching the mirror via “npm run server” and that script is what pm2 uses to launch the mirror. I’ve been doing it that way for a long time, likely because the serverOnly config setting wasn’t working.
                              If I actively run “npm run server” and then do “ps aux |grep node” I do not see anything related to node18 in the process list.
                                sdetweil @ember1205
                                the serverOnly config only works with my run-start.sh script,
                                and was removed from the sample config.js a good while back.
                                for the node 18 thing,
                                if you disable the extra modules (make a new config.js, or use the sample, and use the env variable
                                export MM_CONFIG_FILE=config/filename
                                to test
                                do you ses the same message?
                                • E Offline
                                  ember1205 @sdetweil
                                  @sdetweil I don’t believe it’s the modules.
                                  Leap 16 fresh install is fine with a fresh MM install as well. I upgraded the server again from Leap 15 to Leap16. Before the upgrade, I removed node and npm modules linked to version 18 and MM was running fine in all mannners.
                                  After the upgrade, I made a couple of system-level changes (like disabling the firewall that it forces on you) and added the node/npm modules for version 24 and wasn’t able to start the mirror with pm2 like normal… it continues to throw errors about node18 being missing. However, running the mm.sh script manually or launching the mirror via either npm start server or node --run server works fine.
                                  Did more digging around and found that the issue lies solely in the hands of pm2… the back-end environment was created back in the node/npm 18 days and that was saved in the configuration. The only way to find it was to do a “pm2 dump” and scan the file.
                                  Once I knew it was pm2 for sure, the actual fix was pretty simple:
                                  pm2 save
                                  npm install pm2 -g
                                  pm2 update
                                  pm2 unstartup
                                  pm2 startup
                                  If MM wasn’t still configured as a process…
                                  cd ~
                                  pm2 start mm.sh
                                  pm2 save
                                  I’m running on Leap 16, latest patches, node/npm 18 is uninstalled, mirror is properly auto-launching. Now, I can update the modules and the mirror… But not before I do a snapshot! lol
                                    sdetweil @ember1205
                                    @ember1205 awesome info!! Thanks for the update
                                    • E Offline
                                      ember1205 @sdetweil
                                      Do any of your scripts check for pm2 and update the version during any installs or upgrades? Seems like, for the latter at least, that would be helpful.
                                      My original mirror was obviously built quite a long time ago as the node18 variable was linked to the startup process. No idea how many MM revisions I went through between then and now and was always running on the much older version of node no matter what I did to upgrade the main system.
                                        sdetweil @ember1205
                                        @ember1205 the upgrade script does
                                        • E Offline
                                          ember1205 @sdetweil
                                          I don’t see anything in the script to do the pm2 save or a “pm2 start mm --udpate-env” so that it would use the new version of node. Not sure if your script is already gracefully handling those kinds of updates for the MM startup.
                                          Also, since the script seems to assume Debian-based distro’s, dpkg doesn’t execute on my system and I’m not entirely sure if the script would effectively update my system for me. Thoughts on that?
                                            sdetweil @ember1205
                                            @ember1205 it is Debian based for sure.
                                            Doesn’t work in lxc’s, or other container types, docker
                                            The upgrade-script, starting on line 496 is the code for pm2 upgrade
                                            That was also extracted to upgradepm2.sh
                                            If you wanted to do it separately
