    zIndex configs interfere with SOME other modules
    2 Posts 2 Posters 1.4k Views 2 Watching
    • A
      amanzimdwini
      Re: Global module positioning
      zIndex config option is not applied — containers always render at z-index: 9999
      Description
      The README documents a zIndex field per module entry (and references it in the Troubleshooting section: “Adjust zIndex in your module config”), but setting it has no effect. Positioned containers are always rendered with z-index: 9999 regardless of the configured value.
      Steps to reproduce
      1. Configure a module with an explicit zIndex:
          module: "MMM-GlobalPositioner",
            debug: false,
            delay: 1000,
            maxAttempts: 5,
              { name: "MMM-GoogleSheets", position: { top: 160, left: 20 }, zIndex: 1 }
      2. Restart MagicMirror.
      3. Inspect the generated container in DevTools.
      Expected behavior
      The container’s inline style should reflect z-index: 1.
      Actual behavior
      The container is still rendered with z-index: 9999, e.g.:
      <div id="mm-global-container-MMM-GoogleSheets"
           style="position: fixed; z-index: 9999; pointer-events: none; left: 20px; top: 160px;">
      Impact
      This makes it impossible to layer GlobalPositioner-managed modules underneath other overlay-based modules — for example, screen-dimming modules like MMM-AutoDimmer/MMM-Dimmer, which apply opacity via a fullscreen_above overlay. Because GlobalPositioner’s containers are hardcoded to z-index: 9999, modules repositioned by it always render above such overlays and never get dimmed, even though dimming works correctly for all normally-positioned modules.
      Workaround
      Forcing the z-index via a custom stylesheet (config/custom.css) with !important, since the module sets it as an inline style:
      div[id^="mm-global-container-"] {
        z-index: 1 !important;
      This resolves the visual conflict, but it would be better if the documented zIndex config option actually worked, so this kind of override isn’t necessary.
      Environment
      • MagicMirror²: v2.36.0 (commit fb41d24ef522e91e802e2a623ff6afbddeb3c9d8)
      • Node.js: v22.21.1
      • OS: Raspberry Pi OS
      Otherwise, GREAT module!
      Karl
        sdetweil @amanzimdwini
        @amanzimdwini typically you would open an issue on the module GitHub page to engage the author. As most dont visit the forum regularly
