    MMM-WorldCup2026 - FIFA World Cup 2026 Live Scores, Groups & Stadiums
    12 Posts 4 Posters 4.6k Views 4 Watching
    • Dentrass 0D Offline
      Dentrass 0
      MMM-WorldCup2026
      A modern MagicMirror² module for following the FIFA World Cup 2026 in real time.
      Track upcoming fixtures, latest results, group standings, live matches, stadium information and your favorite team directly from your MagicMirror.
      Features
      • Upcoming matches
      • Favorite team tracking
      • Group standings
      • Latest results
      • Live match detection
      • Stadium information
      • Country flags
      • Automatic updates
      Favorite Team
      Choose any World Cup team:
          module: "MMM-WorldCup2026",
              favoriteTeam: "England"
      Examples:
      • Sweden
      • England
      • Germany
      • Brazil
      • Argentina
      • Netherlands
      • France
      • Spain
      Screenshots
      Installation
      cd ~/MagicMirror/modules
      git clone https://github.com/dentrass/MMM-WorldCup2026.git
      cd MMM-WorldCup2026
      npm install
      Configuration
              favoriteTeam: "Sweden",
              updateInterval: 300000,
              rotateInterval: 20000,
              maxMatches: 5
      GitHub
      License
      MIT License
      Feedback, bug reports and suggestions are welcome.
      C T 2 Replies Last reply Reply Quote 0
        chris47803 @Dentrass 0
        @Dentrass-0
        Hello.
        I see only Loading World Cup Data.
        I have Nodejs v18.20.8
        My config.js:
        favoriteTeam: "Germany",
        maxMatches: 5
        Chris`
        S Dentrass 0D 2 Replies Last reply Reply Quote 0
          sdetweil @chris47803
          @chris47803 please try to use code block around logs and config
          in this message editor
          paste the text, blank line above and below
          select the text you just pasted
          hit the </> button above in the editor toolbar
          or, manually
          on a blank line above the text, three backticks, left of the 1 on the US keyboard
          on a blank line below the test, three backticks
          you can have multiple wrapped sections in a message
          the code block must be the only thing on its line and be at the beginning
            Dentrass 0 @chris47803
            @chris47803
            I’ll see if I can find a solution to the problem of the module not loading correctly.
            In the meantime, you can try reloading Magic Mirror. It worked for me.
              @Dentrass-0
              Hello.
              Thanks for your reply.
              I have already restarted it many times.
              Here are the details again.
              Raspberry Pi 3B+
              Raspbian Buster
              MagicMirror 2.16.0
                @chris47803 can you look in the messages put out from the npm start, the module produces an error message in certain cases
                  chris47803 @sdetweil
                  @sdetweil ```
                  pi@Magic-Mirror:~/MagicMirror $ npm start
                  magicmirror@2.16.0 start
                  [21.06.2026 16:14.59.575] [LOG] Starting MagicMirror: v2.16.0
                  [21.06.2026 16:14.59.584] [LOG] Loading config …
                  [21.06.2026 16:14.59.610] [LOG] Loading module helpers …
                  [21.06.2026 16:14.59.614] [LOG] No helper found for module: alert.
                  [21.06.2026 16:14.59.617] [LOG] No helper found for module: clock.
                  [21.06.2026 16:14.59.619] [LOG] No helper found for module: MMM-Multimonth.
                  [21.06.2026 16:15.00.041] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.00.043] [LOG] Module helper loaded: calendar
                  [21.06.2026 16:15.00.051] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.00.053] [LOG] Module helper loaded: currentweather
                  [21.06.2026 16:15.00.070] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.00.075] [LOG] Module helper loaded: weatherforecast
                  [21.06.2026 16:15.00.078] [LOG] No helper found for module: MMM-Regenradar.
                  [21.06.2026 16:15.00.098] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.00.101] [LOG] Module helper loaded: MMM-MysqlQuery
                  [21.06.2026 16:15.00.113] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.00.114] [LOG] Module helper loaded: MMM-WorldCup2026
                  [21.06.2026 16:15.00.253] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.00.256] [LOG] Module helper loaded: MMM-ServerStatus
                  [21.06.2026 16:15.00.522] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.00.525] [LOG] Module helper loaded: MMM-Pinfo
                  [21.06.2026 16:15.01.148] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.01.149] [LOG] Module helper loaded: MMM-FRITZ-Box-Callmonitor
                  [21.06.2026 16:15.01.158] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.01.160] [LOG] Module helper loaded: MMM-ioBroker2
                  [21.06.2026 16:15.01.171] [LOG] Initializing new module helper …
                  [21.06.2026 16:15.01.173] [LOG] Module helper loaded: MMM-ioBroker
                  [21.06.2026 16:15.01.174] [LOG] All module helpers loaded.
                  [21.06.2026 16:15.01.504] [LOG] Starting server on port 8080 …
                  [21.06.2026 16:15.01.532] [LOG] Server started …
                  [21.06.2026 16:15.01.537] [LOG] Connecting socket for: calendar
                  [21.06.2026 16:15.01.541] [LOG] Starting node helper for: calendar
                  [21.06.2026 16:15.01.542] [LOG] Connecting socket for: currentweather
                  [21.06.2026 16:15.01.544] [WARN] The module ‘currentweather’ is deprecated in favor of the ‘weather’-module, please refer to the documentation for a migration path
                  [21.06.2026 16:15.01.547] [LOG] Connecting socket for: weatherforecast
                  [21.06.2026 16:15.01.549] [WARN] The module ‘weatherforecast’ is deprecated in favor of the ‘weather’-module, please refer to the documentation for a migration path
                  [21.06.2026 16:15.01.551] [LOG] Connecting socket for: MMM-MysqlQuery
                  [21.06.2026 16:15.01.553] [LOG] Starting module helper: MMM-MysqlQuery
                  [21.06.2026 16:15.01.557] [LOG] Connecting socket for: MMM-WorldCup2026
                  [21.06.2026 16:15.01.561] [LOG] MMM-WorldCup2026 node_helper v1.1 started
                  [21.06.2026 16:15.01.564] [LOG] Connecting socket for: MMM-ServerStatus
                  [21.06.2026 16:15.01.567] [LOG] Ping helper started; waiting for requests…
                  [21.06.2026 16:15.01.569] [LOG] Connecting socket for: MMM-Pinfo
                  [21.06.2026 16:15.01.576] [LOG] Connecting socket for: MMM-FRITZ-Box-Callmonitor
                  [21.06.2026 16:15.01.577] [LOG] Starting module: MMM-FRITZ-Box-Callmonitor
                  [21.06.2026 16:15.01.579] [LOG] Connecting socket for: MMM-ioBroker2
                  [21.06.2026 16:15.01.580] [LOG] Connecting socket for: MMM-ioBroker
                  [21.06.2026 16:15.01.582] [LOG] Sockets connected & modules started …
                  [21.06.2026 16:15.02.179] [ERROR] Whoops! There was an uncaught exception…
                  [21.06.2026 16:15.02.196] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                  at Server.setupListenHandle [as _listen2] (net.js:1313:16)
                  at listenInCluster (net.js:1361:12)
                  at GetAddrInfoReqWrap.doListen [as callback] (net.js:1498:7)
                  at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8) {
                  code: ‘EADDRINUSE’,
                  errno: ‘EADDRINUSE’,
                  syscall: ‘listen’,
                  address: ‘127.0.0.1’,
                  port: 8080
                  [21.06.2026 16:15.02.205] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [21.06.2026 16:15.02.209] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [21.06.2026 16:15.02.343] [LOG] Launching application.
                    @chris47803 cant start it again if already running…
                    if using pm2 to launch
                    pm logs --lines=xxx
                    xxx is number of most recent lines, default 15
                    or
                    pm2 stop all
                    then
                    npm start
                    to see the output
                    ctrl-q to close MM window
                    pm2 status
                    then
                    pm2 start xx
                    where xx is the name or number on the row of the app from the status output
                      pi@Magic-Mirror:~ $ pm2 logs --lines=15
                      [TAILING] Tailing last 15 lines for [all] processes (change the value with --lin                                                          es option)
                      /home/pi/.pm2/pm2.log last 15 lines:
                      PM2        | 2026-06-22T12:13:48: PM2 log: Node.js version      : 10.24.1
                      PM2        | 2026-06-22T12:13:48: PM2 log: Current arch         : arm
                      PM2        | 2026-06-22T12:13:48: PM2 log: PM2 home             : /home/pi/.pm2
                      PM2        | 2026-06-22T12:13:48: PM2 log: PM2 PID file         : /home/pi/.pm2/                                                          pm2.pid
                      PM2        | 2026-06-22T12:13:48: PM2 log: RPC socket file      : /home/pi/.pm2/                                                          rpc.sock
                      PM2        | 2026-06-22T12:13:48: PM2 log: BUS socket file      : /home/pi/.pm2/                                                          pub.sock
                      PM2        | 2026-06-22T12:13:48: PM2 log: Application log path : /home/pi/.pm2/                                                          logs
                      PM2        | 2026-06-22T12:13:48: PM2 log: Worker Interval      : 30000
                      PM2        | 2026-06-22T12:13:48: PM2 log: Process dump file    : /home/pi/.pm2/                                                          dump.pm2
                      PM2        | 2026-06-22T12:13:48: PM2 log: Concurrent actions   : 2
                      PM2        | 2026-06-22T12:13:48: PM2 log: SIGTERM timeout      : 1600
                      PM2        | 2026-06-22T12:13:48: PM2 log: =====================================                                                          ==========================================
                      PM2        | 2026-06-22T12:13:49: PM2 log: [Watch] Start watching MagicMirror
                      PM2        | 2026-06-22T12:13:49: PM2 log: App [MagicMirror:0] starting in -fork                                                           mode-
                      PM2        | 2026-06-22T12:13:49: PM2 log: App [MagicMirror:0] online
                      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                      0|MagicMir | [30.04.2026 11:06.55.604] [ERROR] Got error: connect ECONNREFUSED 1                                                          92.168.2.73:8088
                      0|MagicMir | [30.04.2026 11:06.55.609] [ERROR] Got error: connect ECONNREFUSED 1                                                          92.168.2.73:8088
                      0|MagicMir | [30.04.2026 11:06.55.613] [ERROR] Got error: connect ECONNREFUSED 1                                                          92.168.2.73:8088
                      0|MagicMir | [30.04.2026 11:06.55.621] [ERROR] Got error: connect ECONNREFUSED 1                                                          92.168.2.73:8088
                      0|MagicMir | [30.04.2026 11:06.56.561] [ERROR] Got error: connect ECONNREFUSED 1                                                          92.168.2.73:8088
                      0|MagicMir | [30.04.2026 11:06.56.569] [ERROR] Got error: connect ECONNREFUSED 1                                                          92.168.2.73:8088
                      0|MagicMir | npm notice
                      0|MagicMir | npm notice New major version of npm available! 7.9.0 -> 11.13.0
                      0|MagicMir | npm notice Changelog: <https://github.com/npm/cli/releases/tag/v11.                                                          13.0>
                      0|MagicMir | npm notice Run `npm install -g npm@11.13.0` to update!
                      0|MagicMir | [01.05.2026 13:25.18.947] [WARN]  The module 'currentweather' is de                                                          precated in favor of the 'weather'-module, please refer to the documentation for                                                           a migration path
                      0|MagicMir | [01.05.2026 13:25.18.950] [WARN]  The module 'weatherforecast' is d                                                          eprecated in favor of the 'weather'-module, please refer to the documentation fo                                                          r a migration path
                      0|MagicMir | [22.06.2026 12:14.02.445] [WARN]  The module 'currentweather' is de                                                          precated in favor of the 'weather'-module, please refer to the documentation for                                                           a migration path
                      0|MagicMir | [22.06.2026 12:14.02.454] [WARN]  The module 'weatherforecast' is d                                                          eprecated in favor of the 'weather'-module, please refer to the documentation fo                                                          r a migration path
                      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                      0|MagicMir | [22.06.2026 12:14.02.478] [LOG]   Connecting socket for: MMM-ioBrok                                                          er2
                      0|MagicMir | [22.06.2026 12:14.02.481] [LOG]   Connecting socket for: MMM-ioBrok                                                          er
                      0|MagicMir | [22.06.2026 12:14.02.484] [LOG]   Sockets connected & modules start                                                          ed ...
                      0|MagicMir | [22.06.2026 12:14.04.439] [LOG]   Launching application.
                      0|MagicMir | [22.06.2026 12:14.23.068] [LOG]   Create new calendarfetcher for ur                                                          l: https://outlook.live.com/owa/calendar/6c99173e-dacd-49dd-96ea-5a3e411d78e4/52                                                          8c0d07-d4d5-4407-9063-263319f80b1f/cid-7629F9D2FD840E3F/calendar.ics - Interval:                                                           300000
                      0|MagicMir | [22.06.2026 12:14.24.364] [LOG]   Received config for MMM-FRITZ-Box                                                          -Callmonitor
                      0|MagicMir | [22.06.2026 12:14.24.371] [LOG]   MMM-FRITZ-Box-Callmonitor is wait                                                          ing for incoming calls.
                      0|MagicMir | [22.06.2026 12:14.34.980] [INFO]  Calendar-Fetcher: Broadcasting 14                                                          2 events.
                      0|MagicMir | [22.06.2026 12:19.41.727] [INFO]  Calendar-Fetcher: Broadcasting 14                                                          2 events.
                      0|MagicMir | [22.06.2026 12:24.45.041] [INFO]  Calendar-Fetcher: Broadcasting 14                                                          2 events.
                      0|MagicMir | [22.06.2026 12:29.48.571] [INFO]  Calendar-Fetcher: Broadcasting 14                                                          2 events.
                      0|MagicMir | [22.06.2026 12:34.52.678] [INFO]  Calendar-Fetcher: Broadcasting 14                                                          2 events.
                      0|MagicMir | [22.06.2026 12:39.55.682] [INFO]  Calendar-Fetcher: Broadcasting 14                                                          2 events.
                      0|MagicMir | [22.06.2026 12:44.58.496] [INFO]  Calendar-Fetcher: Broadcasting 14                                                          2 events.
                      0|MagicMir | [22.06.2026 12:50.02.031] [INFO]  Calendar-Fetcher: Broadcasting 14                                                          2 events.
                      0|MagicMirror  | [22.06.2026 12:55.06.772] [INFO]
                      0|MagicMirror  | Calendar-Fetcher: Broadcasting 142 events.
                        @chris47803
                        I think this
                        • T Offline
                          Thekk @Dentrass 0
                          @Dentrass-0
                          Hello, thanks for your very nice module. I have 2 requests: will the module also support the knock-out stages of the world cup? Some teams have already placed and displaying the group matches for them doesn’t add too much anymore.
                          Can you make showing the stadium information toggle-able?
                          Thanks!
                          Dentrass 0D 1 Reply Last reply Reply Quote 0
                            Dentrass 0 @Thekk
                            @Thekk This project is no longer actively maintained as I am on vacation and therefore do not have the time to work on the module.
                            No new features or bug fixes are planned.
                            Sorry I do not have the time to fulfill your requests. :(
