    NewsFeed - how to adjust the description text size?
    5 Posts 3 Posters 165 Views 3 Watching
    • T Offline
      thartley
      I would like to increase the text size for the Description text in the default NewsFeed module. I have checked the newsfeed.css file but there doesn’t seem to be a section for the Description text that I can add to my custom.css file to modify.
      Regards,
      Tom
      • R Online
        rkorell Module Developer @thartley
        @thartley
        The text size of the newsfeed description is controlled via the global CSS class .small which the template assigns to the element.
        Defined in ~/MagicMirror/css/main.css:
        .small { font-size: var(--font-size-small); }
        If I see it right::
        • default/newsfeed/newsfeed.css does not contain a font-size for the description — only list and layout rules.
        • The description-specific class .newsfeed-desc does exist, but it does not set a font size.
        If you want to change the description size independently of other .small elements , the cleanest approach would be an override in css/custom.css:
        .newsfeed  .newsfeed-desc { font-size: your_desired_font_size_as_number)
        (do not alter the global .small).
        HTH.
        Warm regards,
        Ralf
        • T Offline
          thartley @rkorell
          @rkorell - Your suggestion took care of the text size. My desired size was 35 in pixels, so ‘35px’.
          This post can be marked as Solved.
          Thank you.
          S R 2 Replies Last reply Reply Quote 0
            sdetweil @thartley
            @thartley you can mark it solved
            find the post that best describes the fix,
            click the 3 dot bottom right, click mark this post as the correct answer
            • T thartley has marked this topic as solved
            • R Online
              @thartley cool.
              Happy that it works.
              Have fun!
              Warm regards,
              Ralf
