    Strava weekinbike & lastactivitymap
    5 Posts 5 Posters 321 Views 5 Watching
      JMac
      super basic question, both modules are from the same developer, but both are missing the most basic info of how to install.
      in instances like this how do I find the first bit of info to put in terminal to start pulling down the info needed for a module?
      Cheers.
      B karsten13K 2 Replies Last reply
        bwente @JMac
        @JMac For simple modules you should be able to clone it from github.
        cd ~/MagicMirror/modules
        git clone https://github.com/bwente/MMM-KitchenTimer.git
        • karsten13K
          karsten13 @JMac
          @JMac
          Regarding Strava: They’ve tightened their API terms of use; in practice, this means that only paying users can access the API. So, if you aren’t a paying Strava user, you can save yourself the trouble of installing any Strava modules…
            malvinas
            git clone https:///github.com/tylerstambaugh/MMM-StravaWeekInBike
            cd ~/MagicMirror/modules/MMM-StravaWeekInBike
            npm install
            git clone https://github.com/tylerstambaugh/MMM-Strava-Last-Activity-Map
            cd ~/MagicMirror/modules/MMM-Strava-Last-Activity-Map
            npm install
            I did install both modules, but was’nt able to make them functional.
            The discription in Note is a mysterie to me. I can need al little help from my friends to tackle that problem.
            • Note: The access token and refresh tokens are kept in a file in the directory above the module. This is for the case where you are running both of my Strava MM modules, they’ll share the token data between them allowing them to stay in sync and avoid “Unauthorized” errors
            T 1 Reply Last reply
            • T
              tylerstambaugh @malvinas
              @malvinas I have updated the README files in the repos to detail how the token file gets created and stored. You shouldn’t have to do anything for it’s creation, you should just need to make sure your module config has valid values and the file will get generated automatically. I hope this helps.
