Weather, how to remove GB-ENG from the header?
Using openmeteo, weather display, header line commented out.
MM shows “city, GB-ENG”How do I remove, disable the GB-ENG bit?
@Richard238 there is a weather module property
appendLocationToHeader
Set it to false,
Check the spelling in the module documentation
module: "weather", ---->appendLocationNameToHeader: false //header: 'Current My_City weather: ', position: "top_right", config: { weatherProvider: "openmeteo", ----> appendLocationNameToHeader: false type: "current", lat: 51.12345 lon: -0.12345 }Spelling shown in docs is appendLocationNameToHeader
Neither of the two position above work, mirror fails to load. -
@Richard238 parameters TO module always go inside the config:{} section
parameters to MagicMirror runtime are outside the config sectionmodule position header ...and, like always, javascript demands a trailing comma on lines when there are more lines following… (comma means more to follow)
config: { weatherProvider: "openmeteo", appendLocationNameToHeader: false, //<---add comma type: "current", lat: 51.12345 //<--- missing comma (there is more to follow this line) lon: -0.12345 }
