    Weather, how to remove GB-ENG from the header?
    5 Posts 2 Posters 65 Views 2 Watching
      Richard238
      Using openmeteo, weather display, header line commented out.
      MM shows “city, GB-ENG”
      How do I remove, disable the GB-ENG bit?
        sdetweil @Richard238
        @Richard238 there is a weather module property
        appendLocationToHeader
        Set it to false,
        Check the spelling in the module documentation
          Richard238 @sdetweil
          			module: "weather",
          			---->appendLocationNameToHeader: false
          			//header: 'Current My_City weather: ',
          				weatherProvider: "openmeteo",
          				----> appendLocationNameToHeader: false
          				type: "current",
          				lat: 51.12345
          				lon: -0.12345
          Spelling shown in docs is appendLocationNameToHeader
          Neither of the two position above work, mirror fails to load.
            @Richard238 parameters TO module always go inside the config:{} section
            parameters to MagicMirror runtime are outside the config section
               module
               position
               header
            and, like always, javascript demands a trailing comma on lines when there are more lines following… (comma means more to follow)
            				appendLocationNameToHeader: false, //<---add comma
            				type: "current",
            				lat: 51.12345 //<--- missing comma (there is more to follow this line)
            				lon: -0.12345
              The comma, it’s always the comma. Thank you.
