Updating my MagicMirror using @sdetweil's script.
@manu85340 if you had used my backup/restore I would have put your custom.css in the right place
@sdetweil Yes, you’re right—I tried to go too fast. I’ll know for next time. Thanks again for your help.
@manu85340 back up now, and when you make changes . Be ready in case
@sdetweil I just updated MM using your script and it won’t start anymore; it stays on the Raspberry Pi desktop. Please help!
@manu85340 are you using pm2?
can you do
pm2 statusand
pm2 stop xxwhere xx is the number of the row of the application (MagicMirror)
usually 0
you can use either the name or the numberthen
go to the MagicMirror foldercan you also do
lsb_release -ado you know if the OS is running Wayland or x11 desktop
we changed the wayland startup , so…
i just updated to 2.38 via your script. Electron starts, but is only shown for a few seconds in fullscreen, then minimzed to the taskbar:
Latest PiOS (trixie) with wayland. Log doesn’t show anything after “launching electron” -
@rabbit83ka If you click on that does it come on screen?
@sdetweil no
@sdetweil I installed Debian Bookworm; I’m not sure if that’s what you’re asking for.
@manu85340 ok, lets try this
pm2 stop all cd ~/MagicMirror npm run start:x11 -
@sdetweil figured it out, nothing related to wayland. Somehow the udpated messed up the npm, removing it
rm -rf node_modules package-lock.jsonand reinstalling withnpm installfixed it -
@rabbit83ka can you send the the
~/MagicMirror/installers/upgrade.logsame userid as here at gmail
messed up nvm? I should only updated node version if required…
nvm or n (node version of nvm) -
@sdetweil just sent the log
@sdetweil Someone told me to skip this line and it worked.```
cd ~/MagicMirror && npm install electron@43 --save-exact -
@manu85340 where is that line? not in either of my scripts…
@sdetweil My apologies, but he didn’t tell me to “skip” it, but to execute it.
Sorry, but the translator interpreted it that way. -
@manu85340 ah. Thanks. My script does thst for 32 bit systems. But not for 64. Looks like we are all fighting electron issues
I’ve updated my scripts to install an updated electron to fix this problem…
during install or upgrade
