Display modules in a carousel
@PointPubMedia
I like @barnabycolby 's version (ie exempting all but the ones you want to rotate) a lot.
But here is something KirAsh4 made for me a while ago
https://forum.magicmirror.builders/topic/373/alternating-modules-to-save-on-real-estate/3
that will do the job too - and it will let you learn a bit java along the wayEnjoy
@amanzimdwini Really like the version of @KirAsh4 …
But how to rotate the “same” module ? I’m using the iframe module more than one time, and I would like to rotate all of them…
@PointPubMedia
Sorry - what are you trying to ask me? I can send you “my” module (basically hacked KirAsh’s a bit - works like a charm). I’m actually trying to use the “Carousel” right now… -
I’m saying that i’m using the swap code from the URL you gave me! But this works like a charm for different module at the same location! What I’m trying to do it’s to rotate the same module with different configuration at the same place!
I’m using the iFrame module to display some graphic from Grafana and I would need to “rotate” a couple of them on MM at the same location! So instead of having 3-4 iFrame at the same time, I will alternate all of them at the same location to save on space!
Did you ever figure this out? I’m interested in the same thing
@PointPubMedia @cnelso24 Hey, I have just had a PR accepted that adds several config options that should help you
@amanzimdwini have a look at the latest version, I think it will have some of the features you are looking for
Thanks!
Is it possible to rotate multiple module definition of the same name ? I mean I’m using MMM-iFrame couple of time on the screen but would like to have only 1 place with multiple iFrame rotating…
@PointPubMedia yes, if all your iframes are in the same “position” (say top_left)on the page then this config should do it:
{ module: 'MMM-Carousel', config: { transitionInterval: 10000, mode: 'positional', top_left: {enabled: true, ignoreModules: [], overrideTransitionInterval: 10000}, } },
works great, thank you!
