    Display modules in a carousel
    29 Posts 8 Posters 31.6k Views 8 Watching
    • F
      frog @PointPubMedia
      @PointPubMedia Don’t you need to just put the ones you don’t want to rotate in IgnoreModules? I haven’t installed it, but that looks like the intent…
      • A
        amanzimdwini @PointPubMedia
        @PointPubMedia
        Once I get home, i can post MY CRUDE hack for that…
        I am on pacific time, though. So give me at least 10 hours
        A 1 Reply Last reply
          barnabycolby
          Yep, @frog is correct. Include the name of all modules in the ignoreModules configuration option EXCEPT from the two modules you wish to rotate.
          • A
            amanzimdwini @amanzimdwini
            @PointPubMedia
            I like @barnabycolby 's version (ie exempting all but the ones you want to rotate) a lot.
            But here is something KirAsh4 made for me a while ago
            https://forum.magicmirror.builders/topic/373/alternating-modules-to-save-on-real-estate/3
            that will do the job too - and it will let you learn a bit java along the way
            Enjoy
            PointPubMediaP 1 Reply Last reply
            • PointPubMediaP
              PointPubMedia @amanzimdwini
              @amanzimdwini Really like the version of @KirAsh4 …
              But how to rotate the “same” module ? I’m using the iframe module more than one time, and I would like to rotate all of them…
              • A
                @PointPubMedia
                Sorry - what are you trying to ask me? I can send you “my” module (basically hacked KirAsh’s a bit - works like a charm). I’m actually trying to use the “Carousel” right now…
                • PointPubMediaP
                  PointPubMedia
                  I’m saying that i’m using the swap code from the URL you gave me! But this works like a charm for different module at the same location! What I’m trying to do it’s to rotate the same module with different configuration at the same place!
                  I’m using the iFrame module to display some graphic from Grafana and I would need to “rotate” a couple of them on MM at the same location! So instead of having 3-4 iFrame at the same time, I will alternate all of them at the same location to save on space!
                  C I 2 Replies Last reply
                    cnelso24 @PointPubMedia
                    @PointPubMedia
                    Did you ever figure this out? I’m interested in the same thing
                    • I
                      izanbard @PointPubMedia
                      @PointPubMedia @cnelso24 Hey, I have just had a PR accepted that adds several config options that should help you
                      C 1 Reply Last reply
                      • I
                        izanbard @amanzimdwini
                        @amanzimdwini have a look at the latest version, I think it will have some of the features you are looking for
                        • PointPubMediaP
                          PointPubMedia
                          Thanks!
                          Is it possible to rotate multiple module definition of the same name ? I mean I’m using MMM-iFrame couple of time on the screen but would like to have only 1 place with multiple iFrame rotating…
                          I 1 Reply Last reply
                          • I
                            @PointPubMedia yes, if all your iframes are in the same “position” (say top_left)on the page then this config should do it:
                                        module: 'MMM-Carousel',
                                            transitionInterval: 10000,
                                            mode: 'positional',
                                            top_left: {enabled: true, ignoreModules: [], overrideTransitionInterval: 10000},
                              cnelso24 @izanbard
                              @izanbard
                              works great, thank you!
                              • PointPubMediaP
                                PointPubMedia
                                @izanbard But with positional I can’t ignore module ?
                                • I
                                  @PointPubMedia yes you can, but you do it by position. Read the config above and see if you can work out in the positional settings you ignore modules per position. Hint it is between enabled and overrideTransitionInterval.
                                  • PointPubMediaP
                                    PointPubMedia @izanbard
                                    @izanbard said in Display modules in a carousel:
                                    Working fine ;)
                                    That’s perfect!
                                    thanks mate!
