    Problem MMM-syslog in Midori
    midorisyslog
    6 Posts 2 Posters 3.4k Views 2 Watching
    • gizmo90G Offline
      gizmo90
      i have a litte problem.
      Midori don’t show the Syslog module and i think it is a issue with the ECMA6 script or so.
      I had the same problem with MMM-Fuel but a manual fix is available (https://forum.magicmirror.builders/topic/922/modules-not-showing-up-on-kweb-or-midori)
      Only firefox and Chromium show the modul but on my rpi1 these browser needs to much resources.
      is a small fix for midori realistic or can I blow it into the wind?
      TypeError: Cannot read property 'push' of undefined
          at Class.module.exports.NodeHelper.create.start.storeLog (/var/www/mirror2/modules/MMM-syslog/node_helper.js:50:12)
          at /var/www/mirror2/modules/MMM-syslog/node_helper.js:36:10
          at Layer.handle [as handle_request] (/var/www/mirror2/node_modules/express/lib/router/layer.js:95:5)
          at next (/var/www/mirror2/node_modules/express/lib/router/route.js:131:13)
          at Route.dispatch (/var/www/mirror2/node_modules/express/lib/router/route.js:112:3)
          at /var/www/mirror2/node_modules/express/lib/router/index.js:277:22
          at Function.process_params (/var/www/mirror2/node_modules/express/lib/router/index.js:330:12)
          at Immediate.next (/var/www/mirror2/node_modules/express/lib/router/index.js:271:10)
          at Immediate.immediate._onImmediate (timers.js:423:18)
      • gizmo90G Offline
        gizmo90
        i have fix it.
        edit MMM-syslog.js
        replace line 44
        setInterval(() => {
        with
        setInterval(function(){
          astrakid @gizmo90
          @gizmo90
          i have the same issue, but the change you mention doesn’t fix it.
          any hints?
          but the http-request is sent successfully:
          {"status":"success","payload":{"type":"ALERT","message":"Testalert","silent":false,"timestamp":"2017-10-25T17:36:57.487Z"}}
          regards,
          astrakid
          • gizmo90G Offline
            gizmo90
            test this
            setInterval(function(){ this.updateDom(); }, 60000);
            instead of
            setInterval(() => {
            this.updateDom(60000);
              astrakid
              @gizmo90 said in Problem MMM-syslog in Midori:
              tried that already, but it doesn’t solve the issue.
                astrakid
                found the issue: if the module is set to “top_bar”, then it forces this error. “top_right” works fine.
