    24h weather forecast graph
    13 Posts 7 Posters 11.1k Views 9 Watching
    • F
      feedparakeet @yawns
      @yawns said in 24h weather forecast graph:
      I just started working on this, creating some functions to render graphs.
      Yawns, great to hear! Any updates with graphs render for the Magic Mirror ?
      What Im dreaming about is a universal graph render function which will take values from a text file, like, last 100 rows and will draw a graph. Or it can be a rss feed.
      PatexP 1 Reply Last reply Reply Quote 0
      • PatexP
        Patex @feedparakeet
        @feedparakeet For such a basic functionality we should not reinvent the wheel. There are a lot of javascript graphing libraries available which are far more sophisticated than anything we will be able to code for the mm in a reasonable manner. They usually render the result in a canvas which can simply be added to the mirror e.g. http://www.chartjs.org/
        Y F 2 Replies Last reply Reply Quote 1
        • Y
          yawns Moderator @Patex
          @Patex
          You are more than right and I tried to use chartjs and chartist, but I failed implementing them. If I recall correctly it was because the chart libraries require the id of a specific div to render in, but the call to this div fails because it was not yet created.
          I’m so short on time currently, but I have one week of vacation during carnival (end of February), hopefully I can pick up with my open tasks.
          • O
            ostfilinchen
            @RedNax: the weathericon in this screenshot would be very nice in the mmm-wunderground module :-)
            can you build this?
            • Y
              yawns Moderator @ostfilinchen
              @ostfilinchen said in 24h weather forecast graph:
              can you build this?
              These are png files, partially transparent, located here: https://github.com/thobach/MagicMirror2/tree/master/web/img/VCloudsWeatherIcons
              O 2 Replies Last reply Reply Quote 0
              • O
                ostfilinchen @yawns
                @yawns i know. but the MMM-WunderGround Module is build by @RedNax.
                If i had time this Weekend i will check to build it and make an pull request. Maybe is @RedNax faster to build it.
                • O
                  ostfilinchen @yawns
                  @RedNax: I’ve create a pull request on github.
                    Jayh391 @ostfilinchen
                    @ostfilinchen
                    AWESOME addition to this module! Looks great
                    • F
                      feedparakeet @Patex
                      @Patex said in 24h weather forecast graph:
                      Thank you for a reply! When I was talking about a function that will render a graph, I was talking about a module that will render a graph, my mistake. ChartJS looks amazing, still I never coded in javascript and that’s why Im dreaming about a complete module for mm.
                      And yes, I also thought about a transparent image with a graph that can be loaded into mm screen. For example, I can run a script which will create a graph image which will be available throw some url and show it on the mm screen with a https://github.com/diego-vieira/MMM-RandomPhoto module that will refresh it from time to time.
                      • T
                        thobach
                        @Jeff I ported my 24 hour weather forecast graphs module to https://magicmirror.builders, you can find it on https://github.com/thobach/MMM-WunderGround24Hours.
