    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 391.3k Views 23 Watching
      savage_gr1nd @joanaz
      @joanaz so no idea on the YouTube problem? Like I said. I know it’s hitting the api. It has a success message in Google console. Just nothing pops up in MagicMirror itself except the text.
        joanaz @savage_gr1nd
        @savage_gr1nd ok, so there are few places you can check.
        1. the skill should console log the api response, so check it in Lambda. see whether ‘items[0].id.videoId’ is still the right way to get the video ID
        2. use AWS IoT to check whether that video ID is published to channel “MagicMirror:new-video”
        3. check your mirror module, see whether it received that video ID.
          @joanaz awesome. I’ll check that when I get home. At least I have a starting point.
          Thank you.
            Journeytojah
            Well, i get the same error when entering a sample utterance:
            The remote endpoint could not be called, or the response it returned was invalid.
            and in Lambda when i test:
            START RequestId: a70ecb9c-efe6-11e6-b979-693b99b365f9 Version: $LATEST
            END RequestId: a70ecb9c-efe6-11e6-b979-693b99b365f9
            REPORT RequestId: a70ecb9c-efe6-11e6-b979-693b99b365f9	Duration: 3003.26 ms	Billed Duration: 3000 ms 	Memory Size: 128 MB	Max Memory Used: 15 MB
            2017-02-10T23:14:23.605Z a70ecb9c-efe6-11e6-b979-693b99b365f9 Task timed out after 3.00 seconds
            any help would be welcomed, its keeping me awake at night, would love to get it working :)
            Interesting enough, when i run it locally it connects…
            http://imgur.com/aecZ8af
            Still playing around, no luck…
            Saw this in the log now…
            Unable to import module 'index': Error
            at Function.Module._resolveFilename (module.js:325:15)
            at Function.Module._load (module.js:276:25)
            at Module.require (module.js:353:17)
            at require (internal/module.js:12:17)
            at Object.<anonymous> (/var/task/index.js:27:17)
            at Module._compile (module.js:409:26)
            at Object.Module._extensions..js (module.js:416:10)
            at Module.load (module.js:343:32)
            at Function.Module._load (module.js:300:12)
            Much later edit: so i notice that Lambda runs NodeJS 4.3, i am running 7.5 on the RPi, could that be it?
              savage_gr1nd
              @joanaz I finally got it perfected. And I love it. Minus the fact that we can’t essentially go home on the mirror. I posted it onto github. Is this something doable?
              Edit - I’m dumb and didn’t see the part where you said add a timeout to the module. How do I do this? Once I’m done with that I can finally build my actual mirror onto it :)
              One more edit - looking though files (only on github atm) I can’t find where to change font of text displayed. Is this in a node or am I missing something? Smaller and cleaner is what I’m shooting for lol
              And again. Thank you for writing this. When I saw smart mirrors about a year ago I’ve been dying to do this exact thing. Just didn’t have your brains to get it done:)
              J richland007R 2 Replies Last reply Reply Quote 0
                savage_gr1nd @Journeytojah
                @Journeytojah my big fail with lambda was the overall simplicity. I tried to make it too complicated.
                Start fresh with a new git skill clone. Create a new project on lambda and follow @Joanaz instructions to the letter. When running npm install make sure you’re in /mirrormirroronthewallskill/src before installing dependencies.
                Don’t sudo anything. And node version should be fine. Lambda test never comes out perfect. Check skill test for success connections.
                Also. For youtube and Google APIs make sure billing is enabled for safe measure.
                  @savage_gr1nd that’s awesome!!! I’ll try to add a timeout on the module, it’s just that videos have different lengths, but I’m sure it can be done. To change font, you can add some css in MMM-MirrorMirrorOnTheWall.css.
                    @joanaz if the video runs through youtube-node, maybe adding into the skill “close video - stop youtube_node”? Or is it not that simple since you tube node is actually inside of the mmm module itself?
                      @joanaz okay so font check. Adding it’s own module in the module list hides it so that’s a temp fix. But I’ll need your help with maybe adding a lamda function for stopping the video and closing it. I think if you could get those two to work this mod would be perfect.
                        jdiggity
                        Alright, I’ve tried setting up the skill from scratch 3 times, following the directions to a T. I still hit the same issue, the skill times out with the following error:
                        at Object. (/var/task/index.js:27:17)
                        I’ve seen this error mentioned a few times in this thread, but no resolution has come up. Any ideas on where to start next? I’m really interested in this idea, but I’m a bit stumped as I don’t have experience with AWS.
                          Journeytojah @jdiggity
                          @jdiggity I have the same problem. Started over again at least 5 times, even on a fresh install of Raspbian.
                          The index.js and mirrormirror.js are not missing any commas or brackets, would have to wait for @joanaz to get back to us …
                            savage_gr1nd
                            It sounds like you guys are zipping the src folder itself also.
                            In terminal navigate to INSIDE the src folder then
                            zip -r code certs index.js package.json node_modules MirrorMirror.js
                              Journeytojah @savage_gr1nd
                              @savage_gr1nd i think its pretty clear that we’re not zipping the src folder but the contents. I did it form terminal as well as selecting everything inside of it and using right click, compress…
                              tried names like import.zip export.zip package.json.zip index.zip indexjs.zip nothing worked…
                                savage_gr1nd
                                Is the error code your getting from the lambda test?
                                  joanaz @Journeytojah
                                  @Journeytojah that’s weird, like @savage_gr1nd said, the problem is usually on how you zip the files and folders inside src folder. It has nothing to do with RPi, or your zip file name, mine is the default ‘Archive.zip’. Assume you didn’t change the handler setting in Lambda, which should be ‘index.handler’. So you have to recreate the problem for me, show me how you do it step by step.
                                    @joanaz @Journeytojah well also the index calls for cert keys. For safe measure I had my keys come in as MagicMirror so that cert path was perfect and I didn’t have to change it at all. (You don’t put the full path, just edit your personal name on the file inside MirrorMirror.js) and also make sure you have the skill Id inside index.js correct also.
                                      @joanaz did you see the alexa module that runs inside magic mirror? I just noticed it. Right now I’m running alexa-avs-sample-app but I was curious if you’ve tested the other to see if it works with no additional booting outside the MagicMirror file
                                      • Z Offline
                                        zman3
                                        That’s the error I always get also. I have the the contents of the folder zipped not the folder I left the keys as MagicMirror also and have index.handler selected.
                                          @savage_gr1nd yeah, but it requires a physical pushbutton. I’m using AlexaPi with my own wake word, so I can activate Alexa by saying “Mirror mirror”.
                                            @joanaz ahhhh. That sucks. I’m running wake word also. I just liked the idea of not having to run it in terminal. Then run mirror. Would have made rebooting simple and flawless. Lol
                                            • 10
                                            • 6 / 10
