    Does anyone know how to make the iFrame module refresh periodically?
    28 Posts 6 Posters 25.3k Views 6 Watching
    • K
      kevsfastz @Mitch1138
      @Mitch1138
      I see what you mean with the URL, any variables you add at the end even a ? will result in displaying all zeros on the output. You can get around this by using a site such asTHIS to refresh this URL for you instead of using iFrame to call a refresh. Of course all these sites will have advertisments which you do not want displayed on your mirror… so what you COULD do is reposition the iframe so the advertisment is hidden in one of the top corners. For example you can add margins with negative values to the iframe style:
      iframe.style = “border:0;margin-bottom:-110px;margin-left:-10px;;width:500px;height:450px;filter:invert(100%);”
      Of course this is not the best nor the most clean solution… maybe someone else has some ideas?
      • F
        fox @kevsfastz
        @kevsfastz said in Does anyone know how to make the iFrame module refresh periodically?:
        @fox
        The simple answer is yes it is possible. What is your goal specifically?
        I have another raspberry who gets temperatures with one-wire-sensors.
        This i provide in a simple homepage:
            <div>
              <div>
            <h2>...</h2>
        	<p><b>Temperaturen:</b></p>
            <p>Luft:............ -3.5°</p>
        	<p>Dach:........... -2.5°</p>
        	<p>Pool: ............3.5°</p>
        	<p><b>Status: </b></p>
        	<p>Pumpe:........... <b>Aus</b></p>
            <p>Solarheizung:...<b>Aus</b></p>
            <br />
        	<p><b>Meta: </b></p>
            <p>System:...........Linux 4.1.19+ armv6l</p>
        	<p>CPU Temp:....14.260°</p>
        	<p>Sensors...........3 x DS18B20 @ 5V </p>
            <p>Last Update:......Mon 13-02-2017, 19:40:05 Uhr</p>
        	</div>
        	<p>....</p>
            </div>
        how to show this, or parts of it?
        edit:(the html header will not be shown in this forum framework :walking:
        • K
          kevsfastz @fox
          @fox
          This depends on the output of your other Pi. If you already have this output displayed in say HTML format ( I assume that’s what you mean when you say simple homepage?) you can easily place this in iFrame via local URL. The best way would be to create its own page so you can control the output, then you can use CSS styles to adjust colors, size, placement etc.
          • F
            fox @kevsfastz
            @fox
            Thank you for your answer. I tried of course, but I got only a white line on the screen.
            • K
              kevsfastz @fox
              @fox
              Can you show a sample of your code? I assume the URL is working fine in a web browser?
              • F
                fox @kevsfastz
                @kevsfastz
                Above is a sample of the code(the weird forum framework removed the headd of the html )
                Yes it is working very fine in the web browser
                Does this help you?
                Thank you in advance !
                • F
                  fox
                  • F
                    fox
                    created new thread because this one is solved with the original issue
