    Add data from another Pi
    9 Posts 3 Posters 4.0k Views 3 Watching
    • yawnsY Offline
      yawns Moderator
      Okay, one step back …
      Your data is stored in your mysql database, right? How is this data stored there? Did you program a script? Or are you using a script/system from the internet? Maybe there already is some kind of a backend you could use?
        Richard238
        @yawns said in Add data from another Pi:
        Yes, correct
        It’s a couple of temperature sensors which are written to the MySQL DB via a .py script.
        • I Offline
          izanbard
          @Richard238
          serving it up via Apache/MySQL/PHP.
          I can help modify the scrip that servers up the data for viewing and instead of returning HTML it could easily return JSON. That would be step one. To help I would need to see your php files and know what url you are using to access the PHP page. either PM them to me, or point me at a repo.
          Step two would be writing a MM module that gets the JSON and displays it right. I may be able help here too.
          • I Offline
            izanbard @izanbard
            @izanbard Of course if you already have a webpage with exactly the right stuff on it, then you could use the iframe module.
            • I Offline
              izanbard
              Have emailed you with some instructions, but check:
              [card:izanbard/MMM-MyTemps]
              for the full source
                Richard238
                Thanks for all your work on this, it’s working great!
