Mirror mirror on the wall alexa skill
20 Posts 8 Posters 13.2k Views 7 Watching
  • K Offline
    KMH0
    Im following the setup of an AWS IoT device, and I can’t figure out how to get past step (7)
    7.Download credentials and run the start.sh script, wich will generate a root-CA.crt
    I have downloaded it, but when i press the start.sh file it just opens in leafpad :( How do i run it?
    B 1 Reply Last reply Feb 21, 2017, 12:29 PM Reply Quote 0
      broberg Project Sponsor @KMH0
      @KMH0 you have to make it executable, in the terminal find your start.sh file : and type chmod +x start.sh
      K 1 Reply Last reply Feb 21, 2017, 9:31 PM Reply Quote 1
      • K Offline
        KMH0 @broberg
        @broberg How do I navigate to my documents in Terminal? :)
        B 1 Reply Last reply Feb 21, 2017, 10:39 PM Reply Quote 0
          @KMH0 type dir to see where you are. Then type cd the folder you want to open until you get there.
          As default you should start in your home directory
          K 1 Reply Last reply Feb 22, 2017, 12:37 PM Reply Quote 1
          • K Offline
            KMH0 @broberg
            @broberg Ive found the folder, but when I type chmod +x start.sh nothing happens
            B 1 Reply Last reply Feb 22, 2017, 1:03 PM Reply Quote 0
              @KMH0 Nothing will happen, but now the script will start when you click it instead of opening in leafpad, right?
              K 2 Replies Last reply Feb 22, 2017, 3:36 PM Reply Quote 1
              • K Offline
                KMH0 @broberg
                @broberg You are a hero mate! :) Thanks
                • K Offline
                  KMH0 @broberg
                  @broberg Wy did I start this journey, haha. You mind explaining the next steps? :)
                  1. go to your local copy of this repo, create a folder called certs inside the src folder
                  2. place all the credentials in the certs folder
                  3. open MirrorMirror.js, replace the keyPath, certPath, and caPath with your own credentials’ paths
                  B 1 Reply Last reply Feb 22, 2017, 4:01 PM Reply Quote 0
                    @KMH0 That I better leave to someone else that have installed Alexa, Haven’t done that part :)
                    K 1 Reply Last reply Feb 22, 2017, 5:53 PM Reply Quote 1
                    • K Offline
                      KMH0 @broberg
                      @broberg thanks, anyway! :)
                      J 1 Reply Last reply Feb 22, 2017, 10:12 PM Reply Quote 0
