    Jenkins RSS feed
    15 Posts 2 Posters 16.4k Views 2 Watching
      roramirez Core Contributors
      I found a public RSS, its can be help for test
      Can you test the follow URL?
      https://hub.spigotmc.org/jenkins/rssAll
        Also, A rssFailed http://jenkins.movingblocks.net/rssFailed
          BeatIdo
          Retrieving MovinBlocks feed worked fine :)
          On the other hand, SpigotMC feed prompted a certificate error. I’m not sure this may be caused by my proxy.
          Of course I still got a parsing error accessing my own Jenkins feed.
          Thanks for you quick answer.
          Regards,
          Fred.
          Here is the error message I got from SpigotMC :
          Ready to go! Please point your browser to: http://localhost:8080
          Create new news fetcher for url: https://hub.spigotmc.org/jenkins/rssAll - Interval: 300000
          { Error: unable to get local issuer certificate
              at Error (native)
              at TLSSocket. (_tls_wrap.js:1079:38)
              at emitNone (events.js:86:13)
              at TLSSocket.emit (events.js:185:7)
              at TLSSocket._finishInit (_tls_wrap.js:603:8)
              at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:433:38) code: 'UNABLE_TO_GET_ISSUER_CERT_LOCALLY' }
          { Error: socket hang up
              at createHangUpError (_http_client.js:254:15)
              at TLSSocket.socketCloseListener (_http_client.js:286:23)
              at emitOne (events.js:101:20)
              at TLSSocket.emit (events.js:188:7)
              at _handle.close (net.js:498:12)
              at Socket.done (_tls_wrap.js:325:7)
              at Socket.g (events.js:291:16)
              at emitOne (events.js:96:13)
              at Socket.emit (events.js:188:7)
              at TCP._handle.close [as _onclose] (net.js:498:12) code: 'ECONNRESET' }
          fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Failed to connect to github.com port 443: Connection timed out
          Here is also the configuration I used, commenting alternatively each feed :
                              module: 'newsfeed',
                              position: 'top_bar',
                                      feeds: [
                                      //        title: "Jenkins SpigotMC RSS All",
                                      //        url: "https://hub.spigotmc.org/jenkins/rssAll",
                                      //        title: "Jenkins MovingBlocks RSS Failed",
                                      //        url: "http://jenkins.movingblocks.net/rssFailed",
                                              title: "Jenkins RSS Failed",
                                              url: "http://10.195.154.232:8080/rssFailed",
          R 1 Reply Last reply
            BeatIdo
            I’m wondering if the problem could be some entries have no content field ?
            [Edit]
            Actually is does not MovingBlocks feed has both entries with and without content field and all of them are well displayed.
              BeatIdo
              Eventually “link” markups are formatted in a different order between terasology server and mine but I doubt that would be the problem …
              alternate field at the end or the beginning …
              link rel=“alternate” type=“text/html” href=“http://jenkins.terasology.org/”/
              link type=“text/html” href=“http://xxx.xxx.xxx.xxx:8080/” rel=“alternate”/
              also my URL contains an IP and not a server name …
              B 1 Reply Last reply
                BeatIdo @BeatIdo
                So it seems I have proxy problems, sometimes I can access my local Jenkins sometimes I can access public MovingBlocks but not both … I have to look into that.
                Thansk a lot for your support, I’ll come back to you whan I’m done :)
                  roramirez Core Contributors @BeatIdo
                  @BeatIdo said in Jenkins RSS feed:
                  at Error (native)
                  at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:433:38) code: ‘UNABLE_TO_GET_ISSUER_CERT_LOCALLY’ }
                  That’s interesting.
                  What happens when you run?
                  curl -Iv https://hub.spigotmc.org/jenkins/rssAll
                    BeatIdo @roramirez
                    @roramirez nice test, it seems it confirms my proxy problem.
                    When I run this command directly on my RPi which lacks proper proxy configuration I got a “Network unreachable” error.
                    Interestingly enough if I connect though SSH to the same RPi from my PC whcih has proxy configured the command gets proxy authorization and get answers from http server.
                    I’ll try to configure proxy accordingly and got through this.
                    HEAD /jenkins/rssAll HTTP/1.1
                    User-Agent: curl/7.38.0
                    Host: hub.spigotmc.org
                    Accept: /
                    < HTTP/1.1 200 OK
                    HTTP/1.1 200 OK
                    < Date: Fri, 24 Feb 2017 08:06:31 GMT
                    < Content-Type: application/atom+xml;charset=UTF-8
                    < Connection: close
                    Connection: close
                    < Set-Cookie: __cfduid=de5c9bf89dbae2ffefd003694243d657a1487923591; expires=Sat, 24-Feb-18 08:06:31 GMT; path=/; domain=.spigotmc.org; HttpOnly
                    < X-Content-Type-Options: nosniff
                    • Server cloudflare-nginx is not blacklisted
                      < Server: cloudflare-nginx
                      < CF-RAY: 33616b2f2e483c5f-CDG
                    • Closing connection 0
                    • SSLv3, TLS alert, Client hello (1):
                      BeatIdo
                      Everything I tested this morning about proxy configuration did not work while starting MM through SSH connection using “node serveronly” command. Even accessing my local Jenkins server did not work …
                      Afterwards I tried starting MM directly from MM GUI using “npm start” command this worked for local servers access …
                        BeatIdo
                        I can confirm now my problem came from proxy configuration, module just didn’t handle error response which was not feed formatted.
