    MMM-SoccerLiveScore
    187 Posts 37 Posters 327.6k Views 35 Watching
      ps-logic @djbosman
      @djbosman
      It seems that this error occurs only with the latest version of MM.
      We found no solution yet.
      I’ll keep you updated!
        bminer1
        I started this module again because its high tide on the Cup races. I do have one issue on the logos. The Euro League Cub shows no icons (picture below). I am also getting some red scores on future dated games (picture below). I thought red scores were for current games. Is it possible to have the whole league name at the top instead of an abbreviation? Example; CL = Champions League. FA Cup shows as “FA Cup”. PR. League = British Premier League. If this is something i can edit on my own, please point me in that direction and ill make the changes.
        Maybe a quick alert when a goal is scored? I cant watch them all.
        L L 2 Replies Last reply Reply Quote 0
          bminer1
          Having an issue with the module updating. None of the weekend games updated.
          L D N 3 Replies Last reply Reply Quote 0
          • L Offline
            LukeCodewalker Module Developer @bminer1
            @bminer1 the league names are provided by the api, so you can’t edit them :( also the info if a game is running or not is provided by the api, so maybe they had a problem with their informations.
            I’ll put alerts on my todo list
            • L Offline
              @bminer1 maybe no one scored a goal :D have you tried to restart the complete magic mirror process?
                d3r @bminer1
                @bminer1 I installed the module on Sunday and the premier league games did get updated on mine.
                  bminer1
                  I had to restart and it refreshed with the latest data. Kind of defeats the purpose of a “Live Score” functionality. I also noticed the icons are the kit colors and not the actual team logo. Any idea of maybe adding the logos instead? Otherwise, ill turn it off.
                  • L Offline
                    @bminer1 the logos are provided by the api. but you could add them manually for the league you’re interested in. I don’t have enough time in the moment to do it. maybe the real logos will be added in the future to the api. German clubs already get real logos.
                      bminer1 @LukeCodewalker
                      @LukeCodewalker There was a link shared in another module that has every team, cup, flag and league logo. Pretty nutz how much is in this Zip. Could be useful. If i knew how to implement this, I’d help.
                      (http://www.vmlogic.net/Downloads/Files/public/dfs_media_2016-09-07.zip)
                        janner6
                        Where do you get the league id’s from I’m after league two in England if you have it available?
                        Cheers
                        • N Offline
                          nem1 @bminer1
                          @bminer1 said in MMM-SoccerLiveScore:
                          I’ve the same problem! The module is not up2date. F.e. at the moment the results of the CL matches of Thuesday & Wednesday are not shown. It looks like the module got freezed. I’ve seen this problem often in the past. After restarting the whole mirror, the module is back again. Last restart was on monday. Any ideas? I did not install or change anything in the last weeks.
                          • H Offline
                            headhunter
                            • L Offline
                              leer0ybr0wn @bminer1
                              @bminer1 I had the same issue so I made a function to overwrite the headings. It’s done client-side post load so not ideal but it’s a start :-)
                              You can change the time interval at which it refreshes (it needs to keep doing this if you cycle through leagues).
                              setInterval (changePrem,10000);
                              function changePrem() {
                                  var prem = document.querySelector("#module_6_MMM-SoccerLiveScore div.module-content header").innerHTML;
                                  var premchange = prem.replace("Pr. League", "Premier League");
                                  document.querySelector("#module_6_MMM-SoccerLiveScore div.module-content header").innerHTML = premchange;
                              Make a js file out of this and load it at the bottom of the main index.html file
                              • O Offline
                                oliveimo
                                Hey Guys,
                                I just set it up and the scores and blank. Im assuming if no games are on nothing will show? I saw talk about a table but is it live? Thanks! Great work BTW.
                                here is my code. I wanna see Spain first and see how it goes. Let me know if there is anything I need to upload for some help. Thanks!
                                module: ‘MMM-SoccerLiveScore’,
                                position: ‘top_right’,
                                header:‘Live-Scores’,
                                			leagues : [8],
                                		showNames: true,
                                		showLogos: true,
                                		displaytime: 60 * 1000,
                                		showTables: true
                                  smkr
                                  Hey LukeCodewalker
                                  Thank you for the MMM-SoccerLiveScore.
                                  I would love if You could expand the module to only show the teams I choose and for X days.
                                  I follow Bayern, Juventus, Roma, and so on. something like this:
                                  20-5-2017 15.30:
                                  Bayern 1 - 0 Freiburg
                                  18.00
                                  Chievo - Roma
                                  21-5-2017 15.00
                                  Juventus - Crotone
                                  16.00
                                  Watford FC - Manchester City
                                  Hull City - Tottenham Hotspurs
                                  20.00
                                  FC Barcelona - SD Eibar
                                  The idea is from the FORZA App at Android.
                                  BR.
                                  Sten
                                  • N Offline
                                    nem1
                                    Hey, what about the Confed Cup? Is it possible to show? If its still in, what ID do I need to add?
                                      McSorley
                                      Where does it pull the fixtures from? There is currently a new draw for Europa and Champions League Qualifiers. Europa games are today.
                                      • ArzegA Offline
                                        Arzeg
                                        Hey Guys
                                        i think i solved the problem for now with the blank table.
                                        The problem is in the config.js the leagues command, if u put only one ID in this command like
                                        leagues: [35], // it doesnt work
                                        but
                                        leagues: [35, 999], // it works. dont know why im not a programmer^^
                                        but i have a question too,
                                        where can i configure that my header and the scores are not going from the left side to my right side cause i have the clock on the left side and the weather on my right side
                                          JoeFranz
                                          I have a problem when switching from the results to the table. At the beginning everything runs as it should. After about an hour there is when switching misfires. Attached to the link of a video of the error, hope it works.
                                          Does somebody has any idea?
                                          Greeting Jörg
                                          Video
                                          EDIT:
                                          For me this is probably the “blank screen problem”
                                          With only one league, it only comes to an interruption and then nothing will be displayed. With two leagues, everything works as it should.
                                          The tip of Arzeg with the entry [35, 999] unfortunately does not work.
                                            JoeFranz
                                            Here is another error. If the table is displayed without names, the line with teams etc. is moved about it, does not fit properly.
                                            • 10
                                            • 2 / 10
