    MMM-Wunderlist add / MM won't start
    5 Posts 3 Posters 2.8k Views 3 Watching
      svonbentzel
      Hello together,
      I added the Wunderlist-Module in config.js.
      But when I restart the MM, it shows please create a config file.
      What is wrong with my config.js?
      can please everyone check my file?
      /* Magic Mirror Config
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: 'de',
      	timeFormat: 24,
      	units: 'metric',
      			module: 'alert',
      			module: "updatenotification",
      			position: "top_bar"
      			module: 'clock',
      			position: 'top_left'
      		        module: 'MMM-Wunderlist',
      		        position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
      		        header: 'Shopping', // This is optional
      					lists: [“inbox”],
      					accessToken: '0ad48eb706f0xxxxxxxxxx8c4f8def79581'
      					clientID: '046xxxxxxxxxx6a8'
      					fade: false,
      					intervall: 60,
      		    module: 'MMM-Globe',
      		    position: 'lower_third',
      		        style: 'geoColor',
      		        imageSize: 800,
      		        ownImagePath:'',
      		        updateInterval: 10*60*1000
      			module: 'calendar',
      			header: 'Kalender',
      			position: 'top_left',
      						symbol: 'calendar-check-o ',
      						url: 'https://p36-calendars.icloud.com/published/2/xxxxxxxxX_p'
      			module: 'calendar',
      			header: 'Arbeits-Termine',
      						url: 'http://kerioxxxxxxx/Calendar'
      			module: 'compliments',
      			module: 'currentweather',
      				locationID: '2844988',  //ID from http://www.openweathermap.org
      				appid: '46c0147xxxxxxb7eeb0'
      			module: 'weatherforecast',
      			header: 'Wettervorhersage',
      				appid: '46c0147xxxxxx44b7eeb0'
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "Tagesschau",
      						url: "http://www.tagesschau.de/xml/rss2"
      				showSourceTitle: true,
      				showPublishDate: true
      • yawnsY
        yawns Moderator
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: 'de',
        	timeFormat: 24,
        	units: 'metric',
        			module: 'alert',
        			position: "top_bar"
        			module: 'clock',
        					lists: ["inbox"],							// wrong "" signs
        					accessToken: '0ad48eb706f0xxxxxxxxxx8c4f8def79581',			// MISSING COMMA
        					clientID: '046xxxxxxxxxx6a8',						// MISSING COMMA
        					fade: false,
        					intervall: 60,
        		    },												// MISSING COMMA
        		        style: 'geoColor',
        		        imageSize: 800,
        		        ownImagePath:'',
        			module: 'calendar',
        			header: 'Kalender',
        			module: 'calendar',
        			module: 'newsfeed',
        				feeds: [
        some commas were missing and you used wrong ", maybe a copy error … I marked these lines
          mortenbirkelund
          for future reference, http://jshint.com/ as suggested in the faq, is a very good tool for finding errors in the config.js
            svonbentzel
            ok thank you I try your changes and will report asap ;-)
              svonbentzel
              you the best! Thank you!
              it runs,
              Made my Day!!
