MMM-PIR-Sensor off delay
6 Posts 2 Posters 2.8k Views 2 Watching
    svonbentzel
    Hello together,
    it is possible to add a off delay to the module?
    PAVIRO-MMM-PIR
    if true ? --> Where? ;-)
    Thanks for answers
    Best Greets
    • Y Offline
      yawns Moderator
      There is a fork which is supposed to do exactly that:
      https://github.com/Patrick-Remy/MMM-PIR-Sensor
        svonbentzel
        sorry maybe i expressed wrong:
        this module is running perfectly but I need a OFF-DELAY (mirror turns on and stay a while on before switch off)
        like time.sleep(50)
        Y 1 Reply Last reply Mar 7, 2017, 2:28 PM Reply Quote 0
        • Y Offline
          yawns Moderator @svonbentzel
          @svonbentzel
          Understood. And the forked version added this configuration option:
          powerSavingDelay
          Additional software side delay (in seconds) before the monitor will be turned off. Possible values: int, default value: 0
            svonbentzel
            ahh, -ok thank you,
            i have used the old configuration options.
            Thank You
              svonbentzel
              on this site is the git clone command false:
              MMM-PIR
              the correct clone command is:
              git clone https://github.com/**Patrick-Remy**/MMM-PIR-Sensor.git
