    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 124.8k Views 25 Watching
      done
        done
        (repost - too many spelling mistakes - couldn’t edit - don’t know which mistakes I’ve been missing now ;) )
        I guess this is a “problem” of the rest api.
        I live in an area where I have different stations to choose.
        There is an underground station about 500 m away. A bus station also about 500 m and two other underground stations within 1 km.
        I tried another module that uses the google api and it offered more than one station but only for a specific route/destination.
        What I want is a module that shows all reachable stations in my area (let’s say within 1 km) with the next departure times without a specific destination.
        If you want to check: I live in the area of Hohenstaufenstraße/Heilbronner Straße. Possible underground stations are Bayerischer Platz, Viktoria-Luise-Platz and Spichernstraße. Additionally there are 2-3 bus lines in that area I which use.
        I think, there is no solution. :)
        Cheers
        done
        • BehB
          Beh
          Hey @done,
          I’ll look into this tomorrow night. maybe this issue can be solved… I’ve got some ideas… I’ll keep you updated!
          • BehB
            Beh @dbahn25
            Hey, @dbahn25
            @olexs forked my module and added a fetcher for the whole DB transportation net to it. So you can use the whole DB net with the look of my module. ;)
            Here it is:
            https://github.com/olexs/MMM-PublicTransportDB
            • JayJ
              Jay
              First of all, I really appreciate these transport modules, great job.
              With the new MMM-PublicTransportDB module, a nationwide transport checking is possible in theory, but I might have some problems with this.
              After getting my station ID of interest from a csv-file of the Deutsche Bahn (http://download-data.deutschebahn.com/static/datasets/haltestellen/D_Bahnhof_2016_01_alle.csv), and implementing the module in the MagicMirror config file, either the module displays a loading string “lade…” or that no transport connection is found for this station…
              I tried several stationIDs, the ones in the Github-example included, but none seem to work for me.
              Any more ideas how to get it working?
              Below my current config-file:
                  module: 'MMM-PublicTransportDB',
                  position: 'top_left',
                     stationId: 8079125,
              If I got this right only one parameter is necessary -> stationID, the rest is not required for now.
              BehB 1 Reply Last reply
              • BehB
                Beh @Jay
                Hey @Jay, what Node.js version are you running?
                JayJ 1 Reply Last reply
                • T
                  TobiasAlw
                  Is it possible to add “express” to the TransportationTypes/excludedTransportationTypes? I just want to show IC/ICE/EC trains. The API from vbb-rest is supporting this feature.
                  BehB 2 Replies Last reply
                  • BehB
                    Beh @TobiasAlw
                    @TobiasAlw could you please provide a link for me? Where can I find this feature in the vbb-rest documentation?
                    • BehB
                      Beh @TobiasAlw
                      @TobiasAlw Ahh, I see. Yeah, this should work. Just add all the transportation types you don’t want to see to the excludedTransportationTypes string in your configuration.
                      All transportation types are listed here under “other parameters”.
                        Photon2000
                        Hi Beh, great module! Thanks!
                        It works on a standard browser (firefox, Win10) with node.js server side on a raspberry pi zero. But on midori installed on the pi zero it doesn’t appear on the screen.
                        node -v : v7.7.1
                        npm -v : 4.1.2
                        Do you have any idea?
                        • BehB
                          Beh @Photon2000
                          @Photon2000 Yeah, the problem is, that midori doesn’t support ECMAScript 6 (ES6) features. But the module is using some of them.
                          Unfortunately I don’t have much time in the near future to convert the module to vanilla JavaScript in ES5 for you. You could try to convert the code with a compiler like Babel. Then it should work with midori.
                            Photon2000
                            @Beh Thanks for pointing me in the right direction! So I have two choices: finding a browser for th pi zero that supports ES6 or switch to PI2/3. Fair enough. I guess that other modules use ES6 too.
                              Photon2000
                              Hi all,
                              good news for Pi Zero users:
                              The new image “Raspbian Jessie with PIXEL” comes bundled with the chromium browser. I’ve installed it tonight and chromium works on the Pi Zero (W). If I connect to a serveronly installation of MagicMirror the “ES6-problematic” modules (im my case: compliments, MMM-PublicTransportBerlin) comes up.
                              It’s not that fluently; CPU is 100% but it work’s.
                              • JayJ
                                Jay @Beh
                                @Beh
                                I did a sudo apt-get dist-upgrade recently, so it has to be the latest version
                                • JayJ
                                  Jay
                                  Does anybody have a working stationID in order to test the module itself, so others can verify if the module is working?
                                  D 1 Reply Last reply
                                    done @Jay
                                    @Jay
                                    There is an ID mentioned in the readme
                                    • JayJ
                                      Jay @done
                                      @done
                                      the station ID in the readme of Berlin-Alexanderplatz indicates a “There are currently no departures.” message.
                                      I think the readme is a bit deprecated, the modulename had to be reconfigered in the config as well.
                                      All I need to know is, where can I get a list with the stationIDs? As I posted above, my source could be wrong for this task.
                                      Any experience?
                                        done
                                        @Jay
                                        Have you checked “How to get the stationId” in the readme?
                                        I have no installation right now. Otherwise you could have my ID.
                                        But as far as I remember it was pretty easy to get an id.
                                        If it’s missing station names:
                                        Zoologischer Garten
                                        Osloer Straße
                                        Ostkreuz
                                        Westkreuz
                                        Hope this helps.
                                        • BehB
                                          Beh @Jay
                                          Hey @Jay,
                                          what did you have to change for the module name in the config?! o_O
                                          I didn’t make any changes according this…
                                          You can get valid station IDs via an easy cURL command as mentioned in the readme like this (you can do it from the mirror’s command line):
                                          curl 'https://transport.rest/stations?query=alexanderplatz'
                                          You just have to switch ‘alexanderplatz’ with your nearest station. This command will return all station fitting the search term.
                                          • JayJ
                                            Jay @Beh
                                            @Beh
                                            After the recent update from olexs (2-3 days ago), the module works like a charm.
                                            • 1 / 5
