    MagicMirror 2 only works with DISPLAY=:0 npm start command
    5 Posts 3 Posters 6.4k Views 2 Watching
      mihirjain
      I have installed raspbian jessie on my rpi2. I followed the howchoo.com website tutorial to do everything since I am a noob EXCEPT the part where magic mirror is to be installed. I followed the automatic method of Magicmirror’s github page.
      Then I put it in kiosk mode and did the last bits (more on that below) as per the howchoo site. End result? rpi boots and starts a web page with only the index visible. If I run the command DISPLAY=:0 npm start then it works.
      About the last bits after installing the MagicMirror in the automatic way: This is what I did:
      Turn Chromium into a kiosk
      Now we’ll configure Chromium to run in kiosk mode.
      Open the autostart config file in the Nano editor.
      Config file for Jessie:
      sudo nano ~/.config/lxsession/LXDE-pi/autostart
      Disable the screensaver
      For both Wheezy and Jessie, comment out the following line using a hash symbol (#):
      # @xscreensaver -no-splash
      Launch Chromium on startup in kiosk mode
      For Wheezy, add the following lines to the bottom of the file:
      @xset s off
      @xset -dpms
      @xset s noblank
      @unclutter -idle 1
      /usr/bin/chromium --kiosk --ignore-certificate-errors --disable-restore-session-state "http://localhost"
      For Jessie, add the following lines to the bottom of the file:
      @xset s off
      @xset -dpms
      @xset s noblank
      @unclutter -idle 1
      @chromium-browser --incognito --kiosk http://localhost/
      To exit, press CTRL-X, type Y and press enter.
      Next, we need to modify the Pi’s BIOS settings for a little extra awesomeness.
      Open BIOS config:
      sudo nano /boot/config.txt
      Use portrait monitor orientation
      Add the following line to rate the display 90 degrees:
      display_rotate=1
      To rotate in the other direction (270 degrees), use the following line instead:
      display_rotate=3
      Enable HDMI hotplugging
      Uncomment the following line:
      hdmi_force_hotplug=1
      Save and exit. Finally, reboot your Pi once more:
      sudo reboot
      Please help.
      thanks,
      Mir
      Note from admin: Please use Markdown on code and shell snippets!
      Wilco89W 1 Reply Last reply Reply Quote 0
      • Wilco89W Offline
        Wilco89 @mihirjain
        @mihirjain that tut is outdated, beter install Version 2.
        It is beter to start with Clean install of Jessy.
        Walk through the readme and wiki!
        https://github.com/MichMich/MagicMirror
        • KirAsh4K Offline
          KirAsh4 Moderator
          Or follow the extensive step by step tutorial here: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
            mihirjain @Wilco89
            @Wilco89 Thanks for the reply, though I didnt use the howchoo method for installation. I followed the github MagicMirror2 site method with the command
            curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
              mihirjain @KirAsh4
              @KirAsh4
              Thanks for the reply, I used the same command to install mm2 as per your detailed tutorial. Though some commands after installed mm2 were different so shall retry the whole thing.
              Thanks,
              Mihir
