    PM2 Error
    7 Posts 4 Posters 3.9k Views 4 Watching
      Preve @KnottyCord
      @KnottyCord Don’t you have to add your mm.sh in the start command? I’m also new at this, so I could be very wrong at this.
      • K Offline
        KnottyCord @Preve
        @Preve I don’t think so so because if you follow the step on the guide this step of adding the mm.sh is after.
        • yawnsY Offline
          yawns Moderator
          KnottyCord is right. pm2 startup is not used to start the mm2 process but to start and initialize pm2 itself.
          Just to be sure … you ran pm2 startup and that told you to run the command your screenshot shows? There are other users with similar problems: https://github.com/Unitech/pm2/issues/2574
          • K Offline
            KnottyCord
            Yes that’s what i did. Run the command pm2 startup. It gave me a command to enter. When I pressed enter it was not working I keep giving me an error!
            • K Offline
              KnottyCord
              Changing the command form this:
              sudo su -c "env PATH=$PATH:/usr/bin pm2 startup linux -u pi --hp /home/pi" to this:
              sudo su -c "env PATH=$PATH:/usr/bin pm2 startup systemd -u pi --hp /home/pi"
              seem to work!
                amanzimdwini @KnottyCord
                @KnottyCord You are correct - you are running systemd (not plain old linux). PM2 does not seem to “realize” that.
                Note that there is ANOTHER problem with PM2 that is now reported as a bug - read all about it here:
                https://forum.magicmirror.builders/topic/2065/solved-pm2-does-not-start-on-reboot/10
                Best of luck - and don’t hesitate to ask for help!
