    Adding new region positions top_center1 and top_center2
    5 Posts 3 Posters 5.3k Views 5 Watching
      sindbad6
      I use my magic mirror in landscape format. And I two place four modules side by side. My idea was to divide the top_center position in two.
      Therefore I added new region definitions in the custom.css:
      .region.top.center1 {
        left: 33%;
        -moz-transform: translateX(-33%);
        -o-transform: translateX(-33%);
        -webkit-transform: translateX(-33%);
        -ms-transform: translateX(-33%);
      .region.top.center2 {
        left: 60%;
      .region.top.center1,
        top: 100%;
      And use in the config.js
      module: 'MMM-Fuel',
      position: 'top_center1',
      Of course, this doesn’t work. I read something, about a region class definition. But I didn’t found, what else I have to do. Any ideas what is missing?
      • yawnsY
        yawns Moderator
        I never tried, but I guess you need to edit index.html located in MagicMirror root folder to define the new regions
        Reply Quote 2
          sindbad6 @yawns
          @yawns : Thanks a lot, that’s it. Now it works.
          zeularZ 1 Reply Last reply
          • zeularZ
            zeular @sindbad6
            @sindbad6 said in Adding new region positions top_center1 and top_center2:
            Hi
            I can’t get it to work, what did you do in the index.html? My modules shows up and then dissapears…
            EDIT: Got it! If someone else want to know:
            		div class="region top center"><div class="container"></div></div>
            		div class="region top center1"><div class="container"></div></div>
            		div class="region top center2"><div class="container"></div></div>
            		div class="region top right"><div class="container"></div></div>
            Reply Quote 3
              sindbad6 @zeular
              @zeular Yeah, that’s the way I did it too.
