Magic Mirror on PI 3
pi 3 magic mirror
7 Posts 3 Posters 3.2k Views 3 Watching
    akrishnan.j
    i am new to MM, after executing curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash,
    i am getting error on (image attached). I tried with npm update -g and the same is appearing.
    D 1 Reply Last reply Mar 27, 2017, 1:44 PM Reply Quote 0
      Davepre @akrishnan.j
      Hi Akrishnan.j ,
      I am very new to the MM as well. I had a similar error when I first installed but since its still a very early stage of the whole process I decided to start over and follow the complete setup tutorial provided by KirAsh4 step by step and suddenly it worked. Maybe just try to start over?
      here’s the link to the Tutorial.
      As said, I found it really helpful because it is very detailed and provides screenshots for every step.
      Best regards / Dave
      • Y Offline
        yawns Moderator
        I too would recommend following the complete tutorial. Especially the update part of your raspberry is very important, I see both node and npm versions are very outdated.
        A 1 Reply Last reply Mar 27, 2017, 3:18 PM Reply Quote 0
          akrishnan.j @yawns
          @yawns HI, Thank you. I assumed the latest PI3 Raspian had the Most recent node versions. Seems not. In the process of upgrade
          Y 1 Reply Last reply Mar 27, 2017, 3:19 PM Reply Quote 0
          • Y Offline
            yawns Moderator @akrishnan.j
            @akrishnan.j
            Right, I thought the same thing, that is very misleading.
            A 1 Reply Last reply Mar 28, 2017, 8:26 AM Reply Quote 0
              akrishnan.j @yawns
              @yawns After updating the Node atleast in my case to Ver 6 , it works now.
              Y 1 Reply Last reply Mar 28, 2017, 8:36 AM Reply Quote 0
              • Y Offline
                @akrishnan.j
                Great. Thanks for your feedback and enjoy your mirror :)
