    Safe shutdown on unplug
    2 Posts 2 Posters 2.4k Views 2 Watching
    • E
      eliddell
      So I know how to create a switch to turn off a pi safely, but with this mirror and the tendencies of my fiance to just unplug things, I was thinking of using something like that adafruit power boost 500 to basically have a small lipo battery supply that charges when plugged in to the wall, but then sends a power down command when unplugged while supplying power via the lipo. Problem is the powerboost isn’t really designed for that… it can be used to send a soft shutdown when the battery but is low, but I really want it to shutdown when not charging.
      Has anyone else implemented something like this… really just looking for a good hardware solution.
      Erik
      • Y
        yawns Moderator
        So you want a UPS for your pi :)
        1. https://www.modmypi.com/raspberry-pi/breakout-boards/pi-modules/ups-pico
        2. https://www.tindie.com/stores/xorbit/
        3. https://www.pi-supply.com/product/pi-ups-uninterrupted-power-supply-raspberry-pi/
