Absolute date
I am trying to get the calendar module display my calendar in absolute date. I want appointments to read the actual time of the appointment, e.g. “3PM”
This is what my MM is doing:
Appointment today: in an hour
Appointment tomorrow: Tomorrow at 11 AM
Appointment 2 days from now: Tuesday at 12PM
Appointment 4 days from now: In 4 daysHere’s the calendar part of my config.js: (apologies, I know I’m supposed to post this in markdown but am not sure how)
module: ‘calendar’,
header: ‘Calendar’,
position: ‘top_left’,
symbol: 'calendar-check-o ',
url: ‘redacted’,},{
symbol: ‘rocket’,
url: ‘redacted’
}]Here’s what the top part of my calendar.js file looks like:
Module.register(“calendar”,{
// Define module defaults defaults: { maximumEntries: 10, // Total Maximum Entries maximumNumberOfDays: 365, displaySymbol: true, defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/ displayRepeatingCountTitle: false, defaultRepeatingCountTitle: '', maxTitleLength: 15, fetchInterval: 5 * 60 * 1000, // Update every 5 minutes. animationSpeed: 2000, fade: false, urgency: 7, timeFormat: "absolute", fadePoint: 0.25, // Start on 1/4th of the list. calendars: [ { symbol: "calendar", url: "http://www.calendarlabs.com/templates/ical/US-Holidays.ics", }, ], titleReplace: { "De verjaardag van ": "", "'s birthday": "" }, },Any help is appreciated.
Nathan
Anyone? Does anyone have absolute date working as I describe? Can someone post the relevant portion of their config file so I can see what you’ve done?
Thanks.
Any word on this? I’m using a 7" raspberry pi display and that ‘Tomorrow at 10:00 AM’ eats up a lot of real estate.
Here’s my config:
{ module: 'calendar', header: 'My Calendar', position: 'top_right', config: { calendars: [ { symbol: 'calendar-check-o ', url: '[redacted]' } ], maximumEntries: 10, maxTitleLength: 12, titleReplace: {'Appointment':'Appt'}, displaySymbol: false, timeFormat: 'relative' } }, -
… and by
timeFormat: ‘relative’
}I mean
timeFormat: ‘absolute’
ugh. -
This post is deleted! -
Turns out my problem came down mostly to not really understanding the difference between ‘absolute’ and ‘relative’… I fixed my problem by modifying the code in calendar.js slightly.
// Otherwise just say 'Today/Tomorrow at such-n-such time' timeWrapper.innerHTML = moment(event.startDate, "x").calendar(null, { sameDay: 'H:mm', nextDay: '[Tomorrow] H:mm', nextWeek: 'dddd', lastDay: '[Yesterday]', lastWeek: '[Last] dddd', sameElse: 'DD/MM/YYYY' });I sort of hijacked this thread. Sorry (but I think my solution might help out the OP ).
@mjtice What lines did you implement that code on?
@mjtice Thanks man, that solved my problem too. Except I added NextWeek: ‘dddd DD/MM/YYYY’
Cheers!
@daikaiju it’s on line 245 in the current release. Keep in mind that if you upgrade you’ll lose those changes (as I did exactly 2 days after I made that post…).
