    [SOLVED] Display stays dark after enabling HDMI output via commandline
    hdmidisplayoutputstays darkblankwakeupproblemcommand
    3 Posts 2 Posters 2.8k Views 3 Watching
      Projekt95
      Hey guys!
      I’ve a problem with my display, where it stays dark after I enable the HDMI output via commandline like this:
      First I disable the output with /opt/vc/nin/tvservice -o and the display goes in standby after some seconds like it should be.
      But when I want to activate it again /opt/vc/nin/tvservice -p the display wakes up and gets a bit brighter but stays blank/dark after that.
      Does anyone know that problem and may have a solution for this?
      • Y Offline
        yawns Moderator
        Please take a look at the solution from DirkS:
        https://forum.magicmirror.builders/topic/490/motion-detector/108
          Projekt95 @yawns
          @yawns Thank you!
          vcgencmd display_power 0
          and
          vcgencmd display_power 1
          worked for me!
