    mm-music-player errors
    13 Posts 5 Posters 7.2k Views 5 Watching
      robertoOk
      after i update magic mirror i had this topic:
      pi@raspberrypi:~/MagicMirror2 $ npm start
      magicmirror@2.1.1 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.1.1
      Loading config …
      Loading module helpers …
      Initializing mm-music-player module helper …
      WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: m.loaded is not a function
      App threw an error during load
      at loadModule (/home/pi/MagicMirror2/js/app.js:144:6)
      at loadNextModule (/home/pi/MagicMirror2/js/app.js:161:5)
      at /home/pi/MagicMirror2/js/app.js:163:6
      at loadModule (/home/pi/MagicMirror2/js/app.js:146:4)
      Whoops! There was an uncaught exception…
      Launching application.
      i tried to understand what could be the problem and it is the mm player
      by commenting the code of the module, the mirror starts withouth errors…
      so … what i can do to resolve this problem??
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @robertoOk
          robertoOk
          /* Magic Mirror
          • The Core App (Server)
          • MIT Licensed.
          var fs = require(“fs”);
          var Server = require(__dirname + “/server.js”);
          var defaultModules = require(__dirname + “/…/modules/default/defaultmodules.js”);
          var path = require(“path”);
          // Get version number.
          global.version = JSON.parse(fs.readFileSync(“package.json”, “utf8”)).version;
          console.log(“Starting MagicMirror: v” + global.version);
          // global absolute root path
          global.root_path = path.resolve(__dirname + “/…/”);
          // The next part is here to prevent a major exception when there
          // is no internet connection. This could probable be solved better.
          process.on(“uncaughtException”, function (err) {
          console.log(“Whoops! There was an uncaught exception…”);
          console.error(err);
          console.log(“MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?”);
          console.log(“If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues”);
          /* App - The core app.
          var App = function() {
          var nodeHelpers = [];
          /* loadConfig(callback)
           * Loads the config file. combines it with the defaults,
           * and runs the callback with the found config as argument.
           * argument callback function - The callback function.
          var loadConfig = function(callback) {
          	console.log("Loading config ...");
          	var defaults = require(__dirname + "/defaults.js");
          	var configFilename = path.resolve(global.root_path + "/config/config.js");
          	try {
          		fs.accessSync(configFilename, fs.F_OK);
          		var c = require(configFilename);
          		var config = Object.assign(defaults, c);
          		callback(config);
          	} catch (e) {
          		if (e.code == "ENOENT") {
          			console.error("WARNING! Could not find config file. Please create one. Starting with default configuration.");
          			callback(defaults);
          		} else if (e instanceof ReferenceError || e instanceof SyntaxError) {
          			console.error("WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.");
          			callback(defaults);
          		} else {
          			console.error("WARNING! Could not load config file. Starting with default configuration. Error found: " + e);
          			callback(defaults);
          /* loadModule(module)
           * Loads a specific module.
           * argument module string - The name of the module (including subpath).
          var loadModule = function(module) {
          	var elements = module.split("/");
          	var moduleName = elements[elements.length - 1];
          	var moduleFolder =  __dirname + "/../modules/" + module;
          	if (defaultModules.indexOf(moduleName) !== -1) {
          		moduleFolder =  __dirname + "/../modules/default/" + module;
          	var helperPath = moduleFolder + "/node_helper.js";
          	var loadModule = true;
          	try {
          		fs.accessSync(helperPath, fs.R_OK);
          	} catch (e) {
          		loadModule = false;
          		console.log("No helper found for module: " + moduleName + ".");
          	if (loadModule) {
          		var Module = require(helperPath);
          		var m = new Module();
          		if (m.requiresVersion) {
          			console.log("Check MagicMirror version for node helper '" + moduleName + "' - Minimum version:  " + m.requiresVersion + " - Current version: " + global.version);
          			if (cmpVersions(global.version, m.requiresVersion) >= 0) {
          				console.log("Version is ok!");
          			} else {
          				console.log("Version is incorrect. Skip module: '" + moduleName + "'");
          				return;
          		m.setName(moduleName);
          		m.setPath(path.resolve(moduleFolder));
          		nodeHelpers.push(m);
          /* loadModules(modules)
           * Loads all modules.
          var loadModules = function(modules) {
          	console.log("Loading module helpers ...");
          	for (var m in modules) {
          		loadModule(modules[m]);
          	console.log("All module helpers loaded.");
          /* cmpVersions(a,b)
           * Compare two symantic version numbers and return the difference.
           * argument a string - Version number a.
           * argument a string - Version number b.
          function cmpVersions(a, b) {
          	var i, diff;
          	var regExStrip0 = /(\.0+)+$/;
          	var segmentsA = a.replace(regExStrip0, "").split(".");
          	var segmentsB = b.replace(regExStrip0, "").split(".");
          	var l = Math.min(segmentsA.length, segmentsB.length);
          	for (i = 0; i < l; i++) {
          		diff = parseInt(segmentsA[i], 10) - parseInt(segmentsB[i], 10);
          		if (diff) {
          			return diff;
          	return segmentsA.length - segmentsB.length;
          /* start(callback)
           * This methods starts the core app.
           * It loads the config, then it loads all modules.
           * When it"s done it executs the callback with the config as argument.
          this.start = function(callback) {
          	loadConfig(function(c) {
          		config = c;
          		var modules = [];
          		for (var m in config.modules) {
          			var module = config.modules[m];
          			if (modules.indexOf(module.module) === -1 && !module.disabled) {
          				modules.push(module.module);
          		loadModules(modules);
          		var server = new Server(config, function(app, io) {
          			console.log("Server started ...");
          			for (var h in nodeHelpers) {
          				var nodeHelper = nodeHelpers[h];
          				nodeHelper.setExpressApp(app);
          				nodeHelper.setSocketIO(io);
          				nodeHelper.start();
          			console.log("Sockets connected & modules started ...");
          			if (typeof callback === "function") {
          				callback(config);/* Magic Mirror
          • MIT Licensed.
          console.error(err);
          	try {
          		callback(config);
          	} catch (e) {
          			callback(defaults);
          			callback(defaults);
          		} else {
          			callback(defaults);
          	try {
          	} catch (e) {
          		loadModule = false;
          	if (loadModule) {
          			} else {
          				return;
          /* cmpVersions(a,b)
          	var i, diff;
          		if (diff) {
          			return diff;
          /* start(callback)
          		config = c;
          		var modules = [];
          module.exports = new App();
          i sobstitute this file that is in the js directory, the file is app.js, this is from the older version of magic mirror that casually i have saved but with this it works…
          i don’t know why but with the newer version of this file modules arent recognised…
            robertoOk @robertoOk
            i don’t know why but code is divided into blocks , copy all the text i have written minus my last comments at the end
              • G Offline
                gismo2006
                Hey, @robertoOk or anybody other. I got today exact the same problem. After updating to 2.1.1 my mm start whit a black screen. And npm write the same like @robertoOk write in his first post. If I cut this module out at the config.js. mm starts correctly.
                Greets gismo
                • G Offline
                  gismo2006
                  Ok, now I give up… :-D
                  Can maybe someone whit some more coding experince help me to solve this problem??
                  Greets gismo
                  • F Offline
                    fabrang
                    I have the same problem since two days. I tried some stuff but nothing worked.
                      Berto1998 @fabrang
                      @fabrang i sobstitute the app.js file code with the older version and works
                        Berto1998 @gismo2006
                        @gismo2006 i sobstitute the app.js file code with the older version and works
                        • G Offline
                          gismo2006
                          @Berto1998 said in mm-music-player errors:
                          sobstitute
                          Hi @Berto1998 Perfect!!! But where do you find an older version??
                          greets gismo
                            @gismo2006 I’ll send u
                            • F Offline
                              fabrang
                              Here you got the old Version:
                              https://github.com/MichMich/MagicMirror/tree/v2.1.0/js
                              It worked perfectely @gismo2006 :)
