mm-music-player errors
13 Posts 5 Posters 5.9k Views 5 Watching
    robertoOk
    after i update magic mirror i had this topic:
    pi@raspberrypi:~/MagicMirror2 $ npm start
    magicmirror@2.1.1 start /home/pi/MagicMirror
    sh run-start.sh
    Starting MagicMirror: v2.1.1
    Loading config …
    Loading module helpers …
    Initializing mm-music-player module helper …
    WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: m.loaded is not a function
    App threw an error during load
    at loadModule (/home/pi/MagicMirror2/js/app.js:144:6)
    at loadNextModule (/home/pi/MagicMirror2/js/app.js:161:5)
    at /home/pi/MagicMirror2/js/app.js:163:6
    at loadModule (/home/pi/MagicMirror2/js/app.js:146:4)
    Whoops! There was an uncaught exception…
    Launching application.
    i tried to understand what could be the problem and it is the mm player
    by commenting the code of the module, the mirror starts withouth errors…
    so … what i can do to resolve this problem??
    J 1 Reply Last reply Apr 11, 2017, 4:33 PM Reply Quote 0
      johnnyboy @robertoOk
        robertoOk
        /* Magic Mirror
        • The Core App (Server)
        • MIT Licensed.
        var fs = require(“fs”);
        var Server = require(__dirname + “/server.js”);
        var defaultModules = require(__dirname + “/…/modules/default/defaultmodules.js”);
        var path = require(“path”);
        // Get version number.
        global.version = JSON.parse(fs.readFileSync(“package.json”, “utf8”)).version;
        console.log(“Starting MagicMirror: v” + global.version);
        // global absolute root path
        global.root_path = path.resolve(__dirname + “/…/”);
        // The next part is here to prevent a major exception when there
        // is no internet connection. This could probable be solved better.
        process.on(“uncaughtException”, function (err) {
        console.log(“Whoops! There was an uncaught exception…”);
        console.error(err);
        console.log(“MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?”);
        console.log(“If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues”);
        /* App - The core app.
        var App = function() {
        var nodeHelpers = [];
        /* loadConfig(callback)
         * Loads the config file. combines it with the defaults,
         * and runs the callback with the found config as argument.
         * argument callback function - The callback function.
        var loadConfig = function(callback) {
        	console.log("Loading config ...");
        	var defaults = require(__dirname + "/defaults.js");
        	var configFilename = path.resolve(global.root_path + "/config/config.js");
        	try {
        		fs.accessSync(configFilename, fs.F_OK);
        		var c = require(configFilename);
        		var config = Object.assign(defaults, c);
        		callback(config);
        	} catch (e) {
        		if (e.code == "ENOENT") {
        			console.error("WARNING! Could not find config file. Please create one. Starting with default configuration.");
        			callback(defaults);
        		} else if (e instanceof ReferenceError || e instanceof SyntaxError) {
        			console.error("WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.");
        			callback(defaults);
        		} else {
        			console.error("WARNING! Could not load config file. Starting with default configuration. Error found: " + e);
        			callback(defaults);
        /* loadModule(module)
         * Loads a specific module.
         * argument module string - The name of the module (including subpath).
        var loadModule = function(module) {
        	var elements = module.split("/");
        	var moduleName = elements[elements.length - 1];
        	var moduleFolder =  __dirname + "/../modules/" + module;
        	if (defaultModules.indexOf(moduleName) !== -1) {
        		moduleFolder =  __dirname + "/../modules/default/" + module;
        	var helperPath = moduleFolder + "/node_helper.js";
        	var loadModule = true;
        	try {
        		fs.accessSync(helperPath, fs.R_OK);
        	} catch (e) {
        		loadModule = false;
        		console.log("No helper found for module: " + moduleName + ".");
        	if (loadModule) {
        		var Module = require(helperPath);
        		var m = new Module();
        		if (m.requiresVersion) {
        			console.log("Check MagicMirror version for node helper '" + moduleName + "' - Minimum version:  " + m.requiresVersion + " - Current version: " + global.version);
        			if (cmpVersions(global.version, m.requiresVersion) >= 0) {
        				console.log("Version is ok!");
        			} else {
        				console.log("Version is incorrect. Skip module: '" + moduleName + "'");
        				return;
        		m.setName(moduleName);
        		m.setPath(path.resolve(moduleFolder));
        		nodeHelpers.push(m);
        /* loadModules(modules)
         * Loads all modules.
        var loadModules = function(modules) {
        	console.log("Loading module helpers ...");
        	for (var m in modules) {
        		loadModule(modules[m]);
        	console.log("All module helpers loaded.");
        /* cmpVersions(a,b)
         * Compare two symantic version numbers and return the difference.
         * argument a string - Version number a.
         * argument a string - Version number b.
        function cmpVersions(a, b) {
        	var i, diff;
        	var regExStrip0 = /(\.0+)+$/;
        	var segmentsA = a.replace(regExStrip0, "").split(".");
        	var segmentsB = b.replace(regExStrip0, "").split(".");
        	var l = Math.min(segmentsA.length, segmentsB.length);
        	for (i = 0; i < l; i++) {
        		diff = parseInt(segmentsA[i], 10) - parseInt(segmentsB[i], 10);
        		if (diff) {
        			return diff;
        	return segmentsA.length - segmentsB.length;
        /* start(callback)
         * This methods starts the core app.
         * It loads the config, then it loads all modules.
         * When it"s done it executs the callback with the config as argument.
        this.start = function(callback) {
        	loadConfig(function(c) {
        		config = c;
        		var modules = [];
        		for (var m in config.modules) {
        			var module = config.modules[m];
        			if (modules.indexOf(module.module) === -1 && !module.disabled) {
        				modules.push(module.module);
        		loadModules(modules);
        		var server = new Server(config, function(app, io) {
        			console.log("Server started ...");
        			for (var h in nodeHelpers) {
        				var nodeHelper = nodeHelpers[h];
        				nodeHelper.setExpressApp(app);
        				nodeHelper.setSocketIO(io);
        				nodeHelper.start();
        			console.log("Sockets connected & modules started ...");
        			if (typeof callback === "function") {
        				callback(config);/* Magic Mirror
        • MIT Licensed.
        console.error(err);
        	try {
        		callback(config);
        	} catch (e) {
        			callback(defaults);
        			callback(defaults);
        		} else {
        			callback(defaults);
        	try {
        	} catch (e) {
        		loadModule = false;
        	if (loadModule) {
        			} else {
        				return;
        /* cmpVersions(a,b)
        	var i, diff;
        		if (diff) {
        			return diff;
        /* start(callback)
        		config = c;
        		var modules = [];
        module.exports = new App();
        i sobstitute this file that is in the js directory, the file is app.js, this is from the older version of magic mirror that casually i have saved but with this it works…
        i don’t know why but with the newer version of this file modules arent recognised…
        R 1 Reply Last reply Apr 12, 2017, 2:54 PM Reply Quote 0
          robertoOk @robertoOk
          i don’t know why but code is divided into blocks , copy all the text i have written minus my last comments at the end
          J 1 Reply Last reply Apr 12, 2017, 3:17 PM Reply Quote 0
            • G Offline
              gismo2006
              Hey, @robertoOk or anybody other. I got today exact the same problem. After updating to 2.1.1 my mm start whit a black screen. And npm write the same like @robertoOk write in his first post. If I cut this module out at the config.js. mm starts correctly.
              Greets gismo
              • G Offline
                gismo2006
                Ok, now I give up… :-D
                Can maybe someone whit some more coding experince help me to solve this problem??
                Greets gismo
                B 1 Reply Last reply Jun 12, 2017, 9:35 AM Reply Quote 0
                • F Offline
                  fabrang
                  I have the same problem since two days. I tried some stuff but nothing worked.
                  B 1 Reply Last reply Jun 12, 2017, 9:32 AM Reply Quote 0
                    Berto1998 @fabrang
                    @fabrang i sobstitute the app.js file code with the older version and works
                      Berto1998 @gismo2006
                      @gismo2006 i sobstitute the app.js file code with the older version and works
