mm-music-player errors
This post is deleted! -
Hey, @robertoOk or anybody other. I got today exact the same problem. After updating to 2.1.1 my mm start whit a black screen. And npm write the same like @robertoOk write in his first post. If I cut this module out at the config.js. mm starts correctly.
Greets gismo
Ok, now I give up… :-D
Can maybe someone whit some more coding experince help me to solve this problem??
Greets gismo
I have the same problem since two days. I tried some stuff but nothing worked.
@fabrang i sobstitute the app.js file code with the older version and works
@gismo2006 i sobstitute the app.js file code with the older version and works
@Berto1998 said in mm-music-player errors:
sobstitute
Hi @Berto1998 Perfect!!! But where do you find an older version??
greets gismo
@gismo2006 I’ll send u
Here you got the old Version:
https://github.com/MichMich/MagicMirror/tree/v2.1.0/js
It worked perfectely @gismo2006 :)
