    [SOLVED] Autoinstall failed at script node download-chromedriver.js
    installing dependeciesinstallationautoinstallelectron-chromedriverelectron
    3 Posts 2 Posters 4.0k Views 3 Watching
      Projekt95
      Hi there!
      I’m currently trying to install MM with the autoinstaller on my Pi 3 with the newest Raspbian version with Pixel, but the install fails at
      electron-chromedriver@1.6.0 install `node ./download-chromedriver.js
      Node.JS (v6.10.2) and npm (v4.5.0) are installed
      Here’s some code from the log:
      87045 silly install electron-chromedriver@1.6.0
      87046 info lifecycle electron-chromedriver@1.6.0~install: electron-chromedriver@1.6.0
      87047 verbose lifecycle electron-chromedriver@1.6.0~install: unsafe-perm in lifecycle false
      87048 verbose lifecycle electron-chromedriver@1.6.0~install: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/root/MagicMirror/node_modules/electron-chromedriver/node_modules/.bin:/root/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
      87049 verbose lifecycle electron-chromedriver@1.6.0~install: CWD: /root/MagicMirror/node_modules/electron-chromedriver
      87050 silly lifecycle electron-chromedriver@1.6.0~install: Args: [ '-c', 'node ./download-chromedriver.js' ]
      87051 silly lifecycle electron-chromedriver@1.6.0~install: Returned: code: 1  signal: null
      87052 info lifecycle electron-chromedriver@1.6.0~install: Failed to exec install script
      Does anyone know hot to fix this? :)
      Greets /me
        joachimt
        Sorry, no solution, I have the same problem !
          Projekt95
          With the help of another User on Github we found out what was causing the error!
          It was the sudo, that I mistakenly used to execute the script. Running the install as pi was the solution.
          Hope this will help someone with the same problem. :)
