Updating modules
4 Posts 2 Posters 4.8k Views 2 Watching
  • K Offline
    kurt
    Hi
    I tried to update the MMM-Fuelwith the MMM Remote Control modul, but got an error message.
    So I did it by VNC and got the message to remove a file manually, but don’t know where to find this file to remove it…
    pi@raspberrypi:~/MagicMirror/modules/MMM-Fuel $ git pull
    Aktualisiere b973f7a..3b84d47
    fatal: Unable to create '/home/pi/MagicMirror/modules/MMM-Fuel/.git/index.lock': Die Datei existiert bereits.
    If no other git process is currently running, this probably means a
    git process crashed in this repository earlier. Make sure no other git
    process is running and remove the file manually to continue.
    Thank you
    • T Offline
      tosti007 Module Developer
      Hello @kurt,
      It’s an error that shouldn’t be happening often, but luckily the solution is simple.
      First go to the module folder. Then type rm -f .git/index.lock, this removes the file that causes problems. After that you should be able to do your git pull without a problem :D
      If there is anything don't hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      K 1 Reply Last reply May 1, 2017, 5:33 PM Reply Quote 3
      • K Offline
        kurt @tosti007
        @tosti007
        Thank you for the quick help, problem removed, git pull done.
        T 1 Reply Last reply May 1, 2017, 10:26 PM Reply Quote 1
        • T Offline
          tosti007 Module Developer @kurt
          @kurt Good to hear!
