    Sachin's Mirror
    30 Posts 5 Posters 30.2k Views 7 Watching
      Sachin
      Apologies for the belated response, I’ve been traveling for work. Here’s a list of the modules…
      • All default modules (current weather, weather forecast, calendar, compliments, RSS Newsfeed, Traffic.)
      3rd Party modules
      • PIR Sensor
      • Scrobbler
      • iCloud client (For birthday calendar)
      • Nest
      • Wunderlist (For ToDo’s)
      • System Temp
      Wilco89W 1 Reply Last reply Reply Quote 0
        adamsidelsky
        Sachin,
        Thanks very much for the info, the mirror looks great. Would you be able to share a more clear image of the mirror screen and the source code? I would like to make something very similar. If not publicly, I can PM you my email address and such.
        Regards,
        -Adam
        S 3 Replies Last reply Reply Quote 0
        • Wilco89W Offline
          Wilco89 @Sachin
          @Sachin where did you put the PIR sensor?
            Sachin @adamsidelsky
            @adamsidelsky Thanks. I’ll take a clearer picture tonight when I get home and post it.
              @adamsidelsky I can post the full image of the SD card somewhere I suppose? Part of the fun however is to play with the code.
                Sachin @Wilco89
                @Wilco89 It is in the bottom right hand corner. I’ll make sure to include it when I take a clearer picture tonight.
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  @Sachin, use 'scrot' to take a screen shot of the display itself. 'scrot /home/pi/screenshot.png' will get you an image of the screen that you can then post here. (if you’re loged in remotely, you need to tell it which display to use: 'DISPLAY=:0 scrot /home/pi/screenshot.png')
                  As for the source code, you don’t have to post a full image, just the modules folder (assuming everything you have on there is in modules.) You can simply zip it up (you’d have to install zip first if you don’t already have it, 'sudo apt-get install zip'):
                  $ cd ~/MagicMirror
                  $ zip -9 -r modules.zip modules
                  Then you can post that 'modules.zip' file somewhere.
                  OR, alternatively, you can push your code up to a Github repository so others can download them selectively instead of grabbing the entire modules folder. It’s also easier to maintain your code that way.
                    Sachin
                    @KirAsh4 Thanks for the tips, I learn something new every day!
                        adamsidelsky
                        Sanchin,
                        Looks great! I’d love a copy of the code please and thank you.
                        Regards,
                        -Adam
