    Button / modul
    12 Posts 3 Posters 7.4k Views 2 Watching
      Marko
      i have add a button on magicmirror main screen. Problem is that i can’t start button (it is not interactive), i cant click on him. What i want to do is have button that can link me to some site or local path on pc. Is thare solution for this? Please help someone!
      Thank you,
      P.S. Michael, i just want to say that the project is great. Just ahead with development. Regards!
      • romainR Offline
        romain
        How did you add your button ? if you added it by using the document.createElement(“button”) from a js file, I beleive you can use the following syntax to add an action to it
        var newButton = document.createElement("button");
        newButton.addEventListener("click", function (event) {
           //your instructions here
        But in order to press it, I guess you would have to show your mouse right ? or maybe you have a touchscreen.
          Marko
          Thank you for help,
          but i didn’t get the click in function, i tray to add it like my own module and put it in index.html, but both doesn’t work. I have it on screen but it is not operational, in my test html it works. I remove hidden mouse cursor in css, so i can move it ower screen for testing but it will fit behind touchscreen. I’m begginer in javascript, so this is my first time meet with node and electron. Is modul requires certain writing rules to be active?
          Thank you
          romainR 1 Reply Last reply Reply Quote 0
          • romainR Offline
            romain @Marko
            @Marko Can you copy past what you did exactly ?
              Marko
              No problem,
              i add this in head in html:```
              function myFunction() {
              var newButton = “Click me!”;
              var result = newButton.link(“https://www.google.com”);
              document.getElementById(“btn”).innerHTML = result;
              This works great in my html file.
              Thank you Romain
              • brobergB Offline
                broberg Project Sponsor @Marko
                @Marko it’s better if you don’t alter the index.html file and instead write a module to display the button. Use the default hello world module as a base.
                  Marko @broberg
                  @broberg i modify helloworld just like you sead, but still not active. Is thare function that can call it?
                  Thank you again! ```
                  //your code here
                   	getDom: function() {
                  		var wrapper = document.createElement("a");
                  		wrapper.innerHTML = "<a href="https://www.google.hr">" + this.config.text + "</a>";
                  		return wrapper;
                  • brobergB Offline
                    @Marko well, you really can’t open links in that manner inside the MM, either you have to open a seperate browser or maybe if it’s possible to run google within an iframe (can’t remember the latest verdict on this subject).
                    And, what version of the mirror are you running?
                      Marko @broberg
                      @broberg i’m running MM ver. 2.1.0 on Win 10 and Node.js 7.9.0 installed
                      • brobergB Offline
                        @Marko aahh okey. To be able to click on anything on the 2.1.0 and prevoius versions you need to change the fullcreen region property.
                        So either update to 2.1.1 or add
                        .region.fullscreen {
                          pointer-events: none;
                        .region.fullscreen * {
                          pointer-events: auto;
                        To your custom.css file
                          Marko @broberg
                          @broberg thank you so much, i did it finally. I can’t upgrade to v.2.1.1 (i tray it on Linux and Respberry pi3) but it wont launch on Windows, becuse he use sh to launch the app (MM). I will tray to add sh to Environment Varibale… But this is good for now.
                          Thx again
                            Marko
                            External sites works good. Is someone familiar with error “Cannot GET *.html”, allways get this error when i tray to link to local site (html). If someone know how to solve the problem can please respond?
