    MagicMirror on Pi Zero W
    46 Posts 19 Posters 71.9k Views 21 Watching
    • kylelmartinK
      kylelmartin @Iseknutz
      • kylelmartinK
        @Iseknutz said in MagicMirror on Pi Zero W:
        I installed the image from https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/84 , updated the System to use the onboard wifi and this works for me.
        @Iseknutz
        At least I can get this method up and running on my RPI0w, but what’s the trick to updating the system to use the onboard wifi? I’ve created the wpa_supplicant.conf and I’ve even jacked with the etc/network/interfaces - but no luck getting it to connect to the network.
        Thx
        C I 2 Replies Last reply
          CaptnJB @kylelmartin
          @kylelmartin can you post or pm your WPA_supplicant.conf file? Please remove your passwords and maybe change your wifi name if that makes you feel better.
          How are you updating your wpa-supplicant through a terminal or by copying it onto your card? Windows or Mac?
          CaptnJB
          kylelmartinK 1 Reply Last reply
          • kylelmartinK
            kylelmartin @CaptnJB
            @CaptnJB
            here is the wpa_supplicant.conf file - or at least the latest rendition of it.
            country=US
            ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
            update_config=1
            network={
                ssid="KLM-Guest"
                key_mgmt=NONE
                priority=1
                id_str="guest"
            network={
                ssid="mywebsite.com"
                psk="oldasspw"
                priority=2
                id_str="klm"
            My regular old wifi network name has a “.” in the name and I thought that might cause some problems. So, I set up a second guest wifi network so this device wouldn’t need a password.
            C 1 Reply Last reply
              @kylelmartin, I apologize for the delay just landed in Madrid. For starters I would take out the id lines. Keep it simple. Try this.
              country=US
              update_config=1
              network={
                  ssid="KLM-Guest"
                  psk=""
                  priority=1
              network={
                  ssid="KLM"
                  psk="oldasspw"
                  priority=2
              Also, mywebsite.com should be be your router ssid. If you have it set to that “mywebsite.com” in the file you gave it is most likely “KLM”.
              Why would you want the guest network to have priority?
              CaptnJB
              • I
                Iseknutz @kylelmartin
                @kylelmartin after the Update to the actual OS, the Onboard-WiFi from my raspi0 was automatically enabled. Did you use the Desktop or console?
                C kylelmartinK 2 Replies Last reply
                  CaptnJB @Iseknutz
                  @Iseknutz I use ssh and nano. I also am a Mac user.
                  I’m glad it’s working
                  CaptnJB
                  • kylelmartinK
                    @Iseknutz
                    What do you mean by “after the Update to the actual OS”? I used the image linked above. I can’t do an update/upgrade as I have no internet connection. I’m using the console on the Pi and editing my conf in Mint Linux. I’m using Jessie Lite rather than the full install.
                    @CaptnJB
                    Thanks for the rewrite on the wpa_supplicant, but it still won’t connect to any provided wifi network.
                    Thanks to all.
                    I 1 Reply Last reply
                    • I
                      @kylelmartin I have connected an USB Wlan Dongle (Edimax, working without extra software) and do the update. Im using Jessie Lite and later I installed the desktop.
                      Sorry for my bad english ;)
                        CaptnJB @Iseknutz
                        @Iseknutz
                        Greetings from Toulouse. To do the update and upgrade, from the terminal type:
                        sudo apt-get update
                        sudo apt-get upgrade
                        After the installation of the new updated packages, sudo shutdown. Wait. Remove the power and your edimax adapter and connect power. Now does it work?
                        JB
                        • kylelmartinK
                          @CaptnJB @Iseknutz
                          Silly me! I should have known that to get a wifi adapter to work I needed a wifi adapter!
                          Fortunately I had a usb splitter with power supply and an edimax wifi lying around.
                          After the update and upgrade its working well.
                          Your help was greatly appreciated.
                          Thanks from Texas!
                          KLM
                          • markbajajM
                            markbajaj @rootsudo
                            @rootsudo Thank you!
                            This along with post number 23 got my Pi Zero and Pi zero W working perfectly :)
                            • A
                              andreas-becker
                              @rootsudo said in MagicMirror on Pi Zero W:
                              The Beginnings:
                              1. Place wpa_supplicant.conf in Boot folder of SD card
                              2. Boot SD card and login
                              3. Enable SSH: sudo raspi-config -> Select Interfacing Options -> select SSH -> select Enable -> select Finish
                              After step 4 i recommend creating an empty file called “ssh” and also put it in the Boot folder of the SD card.
                              So you don’t have to do step 6, cause ssh is started on boot with the default credentials (user: pi, password: raspberry)
                              After boot, it did not open the browser, instead it just showed the console window.
                              Problem was solved by installing x-server with sudo apt-get install xserver-xorg
                                12wsx
                                my I please someone to make an image of sd card with installed and working MM? i’m trying about week to run MM on piZero and nothing… all the time diffrent errors which i don’t understand.
                                Andrius okA 1 Reply Last reply
                                • G
                                  geeklimit @rootsudo
                                  • Andrius okA
                                    Andrius ok @12wsx
                                    Hi @12wsx try this thread https://forum.magicmirror.builders/post/32731
                                      bmarofsky
                                      tried on stretch lite and got this
                                      pi@raspberrypi:~/MagicMirror $ sudo npm install
                                      npm WARN engine http-auth@3.2.3: wanted: {"node":">=4.6.1"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                      npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                      npm WARN engine apache-crypt@1.2.1: wanted: {"node":">=4.6.1"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                      npm WARN engine apache-md5@1.1.2: wanted: {"node":">=4.6.1"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                      npm WARN engine hawk@6.0.2: wanted: {"node":">=4.5.0"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                      Mykle1M 1 Reply Last reply
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @bmarofsky
                                        @bmarofsky
                                        Warnings don’t necessarily mean that your mirror won’t work. Have you tried to run it after?
                                        One thing to note: Installation of dependencies using sudo can, and often does, cause problems. So, in the future, simply use npm install without sudo
                                        Updating your node should clear 4 of those 5 warnings
                                          patoberli
                                          I’m currently trying to do this with Debian Stretch, but the noobs image.
                                          Anyway, the update.rc (command 18) doesn’t work here correctly, because they switched to systemd instead of system-V. There is no error, but the command doesn’t get added to the startup.
                                          Replace the file content from step 14 to:
                                          #! /bin/bash
                                          ### BEGIN INIT INFO
                                          # Provides:          startMagicMirror
                                          # Required-Start:    $all
                                          # Required-Stop:
                                          # Default-Start:     2 3 4 5
                                          # Default-Stop:
                                          # Short-Description: Start MagicMirror software
                                          ### END INIT INFO
                                          cd /home/pi/MagicMirror
                                          node serveronly &
                                          sleep 45
                                          sudo xinit /home/pi/startMidori.sh
                                          After this, replace the command 18 with:
                                          sudo systemctl enable startMagicMirror.sh
                                          This should lead to the following output:
                                          startMagicMirror.sh.service is not a native service, redirecting to systemd-sysv-install.
                                          Executing: /lib/systemd/systemd-sysv-install enable startMagicMirror.sh
                                          After this continue with the manual.
                                          It currently only shows a white screen in my case, but I have just started and maybe that’s even normal, haven’t gotten that far yet in the manual.
                                          P 1 Reply Last reply
                                            patoberli @patoberli
                                            Update1:
                                            In my case the webserver was not accessible over the network, even after adding my client IP address to the /home/pi/MagicMirror/config/config.js file. This file is in the beginning not there, so first create a copy of the sample file:
                                            cp /home/pi/MagicMirror/config/config.js.sample /home/pi/MagicMirror/config/config.js
                                            After that, edit the file and replace the word localhost with 0.0.0.0. Also don’t forget to edit the ipWhitelist.
                                            Found here: https://forum.magicmirror.builders/topic/5446/ipwhitelist-still-not-working/4
                                            Still having just a white blank screen on my PI, but with the web browser from another pc it’s working :)
                                            • 2 / 3
