    MagicMirror on Pi Zero W
    46 Posts 19 Posters 69.2k Views 21 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Hawking
      @Hawking said in MagicMirror on Pi Zero W:
      /home/pi/MagicMirror/node_modules/moment
      it should look like this /home/pi/MagicMirror/vendor/node_modules/moment do you have a package.json file in /home/pi/MagicMirror/vendor?
      • H Offline
        Hawking
        @strawberry-3.141 said in MagicMirror on Pi Zero W:
        I have a directory /home/pi/MagicMirror/vendor containing
        package.json and vendor.js but noting more.
        I now used npn version 2.14.7 (checked by npm -version) to
        cd ~/MagicMirror/vendor
        npm install
        This gave
        npm WARN package.json magicmirror-vendors@ No README data
        font-awesome@4.7.0 node_modules/font-awesome
        moment-timezone@0.5.13 node_modules/moment-timezone
        weathericons@2.1.0 node_modules/weathericons
        moment@2.18.1 node_modules/moment
        and the folder /home/pi/MagicMirror/vendor/node_modules/moment that you mentioned before was created.
        I then rebootet (not sure if necessary) and it seems to work (I see the date and time, holidays,quote…). I’ll now set everything up but it looks way better then before.
        So thanks a lot for your help!! I hope that your fix also works for the other people who have the same problem.
        Just to understand the fix a bit better:
        Is there a reason that one seem to have to do run
        sudo npm install once in /home/pi/MagicMirror/ (this is already included in the initial post) and once npm install in /home/pi/MagicMirror/vendor/? (this is not mentioned in the initial post and also not directly done by the standard installer (that does not work for the pi-Zero) located in /home/pi/MagicMirror/installers/raspberry.sh (at least I don’t see it therein).
        strawberry 3.141S 1 Reply Last reply Reply Quote 1
          @Hawking the command npm install in the directory /home/pi/MagicMirror/ has a hook in the package.json file which automatically runs npm install in /home/pi/MagicMirror/vendor as well, so there is no need to mention this because it’s done automatically ;)
          • H Offline
            Hawking @strawberry 3.141
            I now did a installation on a fresh image and used node version 6.6.1 which automatically includes npm 3.10.8. So instead of
            sudo wget http://node-arm.herokuapp.com/node_latest_armhf.deb
            sudo dpkg -i node_latest_armhf.deb
            sudo apt-get install npm
            I did
            wget -O - https://raw.githubusercontent.com/sdesalas/node-pi-zero/master/install-node-v6.9.1.sh | bash
            Then I got later on no warnings about to old or insecure version any more but just
            npm WARN prefer global coffee-script@1.10.0 should be installed with -g
            npm WARN prefer global jsonlint@1.6.2 should be installed with -g
            npm WARN prefer global colorguard@1.2.0 should be installed with -g
            > electron-chromedriver@1.6.0 install /home/hawking/MagicMirror/node_modules/electron-chromedriver
            > node ./download-chromedriver.js
            > electron@1.6.5 postinstall /home/hawking/MagicMirror/node_modules/electron
            > node install.js
            npm WARN lifecycle magicmirror@2.1.1~install: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 cd vendor && npm install /home/hawking/MagicMirror
            npm WARN lifecycle magicmirror@2.1.1~postinstall: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 sh installers/postinstall/postinstall.sh /home/hawking/MagicMirror
            (in this installation I did not use the pi user, but I had the same problem when I used the default pi user).
            If one knows the solution for the blank screen it is obvious that this is a strong hint that one should run
            cd ~/MagicMirror/vendor/ && npm install
            cd ~/MagicMirror/ && sh installers/postinstall/postinstall.sh
            (the later at the moment just prints a success message and is therefore not really needed)
            I don’t know why these commands did not work automatically, maybe an issue with some directories that are not set (I assume in the error instead of %s the directory should be displayed).
            • I Offline
              Iseknutz
              I installed the image from https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/84 , updated the System to use the onboard wifi and this works for me.
              kylelmartinK 2 Replies Last reply Reply Quote 0
                Mitchfarino Module Developer @Hawking
                @Hawking Thanks for all your help and comments, I’ve managed to get it up and running now!
                Now I just need to get the whitelist sorted :grimacing:
                • H Offline
                  Hawking @Mitchfarino
                  @Mitchfarino said in MagicMirror on Pi Zero W:
                  No problem.
                  This worked fine for me, I just added the IP of my regular PC (e.g 192.168.2.185) to the list in the config file so that it looked like
                  ipWhitelist: ["192.168.2.185", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                  If I then typed the ip:port (the port is also defined in the MM config, default is 8080) of my raspi (e.g.
                  http://192.168.2.170:8080/
                  ) in the browser bar of my regular PC I could see the page also on my regular PC (took 1-2 seconds to load).
                  If this does not work for you, just open a new thread and provide details.
                    CaptnJB
                    BLANK SCREEN, NO CLOCK/CALENDAR/MOMENTS solved and simplified from other topics and posts:
                    After you follow the instructions in the first post to #23 then jump to here:
                    24 cd ~/MagicMirror/vendor
                    25 npm install
                    26 sudo reboot
                    I’m not a linux expert, but I built this a few weeks back before the latest version of MM and it worked flawlessly. There should be a hook in the original package.json that kicks it into the vendor directory and runs “npm install” there but it doesn’t happen now (5/3/2017).
                    Also, for those of you who do not have a monitor, after you SSH into your Rpi Zero W:
                    sudo raspi-config
                    5 interfacing options
                    P3 VNC
                    YES you want to enable the VNC server
                    reboot when it asks.
                    Use VNC Viewer or whatever, connect to your rpi using either ip address or if you set it up in your DHCP table with a :0 (zero) to see your screen or :1 to have a desktop.
                    CaptnJB
                    • kylelmartinK Offline
                      kylelmartin @Iseknutz
                        @Iseknutz said in MagicMirror on Pi Zero W:
                        @Iseknutz
                        At least I can get this method up and running on my RPI0w, but what’s the trick to updating the system to use the onboard wifi? I’ve created the wpa_supplicant.conf and I’ve even jacked with the etc/network/interfaces - but no luck getting it to connect to the network.
                        Thx
                        C I 2 Replies Last reply Reply Quote 1
                          CaptnJB @kylelmartin
                          @kylelmartin can you post or pm your WPA_supplicant.conf file? Please remove your passwords and maybe change your wifi name if that makes you feel better.
                          How are you updating your wpa-supplicant through a terminal or by copying it onto your card? Windows or Mac?
                          CaptnJB
                          kylelmartinK 1 Reply Last reply Reply Quote 0
                            kylelmartin @CaptnJB
                            @CaptnJB
                            here is the wpa_supplicant.conf file - or at least the latest rendition of it.
                            country=US
                            ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
                            update_config=1
                            network={
                                ssid="KLM-Guest"
                                key_mgmt=NONE
                                priority=1
                                id_str="guest"
                            network={
                                ssid="mywebsite.com"
                                psk="oldasspw"
                                priority=2
                                id_str="klm"
                            My regular old wifi network name has a “.” in the name and I thought that might cause some problems. So, I set up a second guest wifi network so this device wouldn’t need a password.
                              @kylelmartin, I apologize for the delay just landed in Madrid. For starters I would take out the id lines. Keep it simple. Try this.
                              country=US
                              update_config=1
                              network={
                                  ssid="KLM-Guest"
                                  psk=""
                                  priority=1
                              network={
                                  ssid="KLM"
                                  psk="oldasspw"
                                  priority=2
                              Also, mywebsite.com should be be your router ssid. If you have it set to that “mywebsite.com” in the file you gave it is most likely “KLM”.
                              Why would you want the guest network to have priority?
                              CaptnJB
                              • I Offline
                                Iseknutz @kylelmartin
                                @kylelmartin after the Update to the actual OS, the Onboard-WiFi from my raspi0 was automatically enabled. Did you use the Desktop or console?
                                C kylelmartinK 2 Replies Last reply Reply Quote 0
                                  CaptnJB @Iseknutz
                                  @Iseknutz I use ssh and nano. I also am a Mac user.
                                  I’m glad it’s working
                                  CaptnJB
                                    @Iseknutz
                                    What do you mean by “after the Update to the actual OS”? I used the image linked above. I can’t do an update/upgrade as I have no internet connection. I’m using the console on the Pi and editing my conf in Mint Linux. I’m using Jessie Lite rather than the full install.
                                    @CaptnJB
                                    Thanks for the rewrite on the wpa_supplicant, but it still won’t connect to any provided wifi network.
                                    Thanks to all.
                                    • I Offline
                                      @kylelmartin I have connected an USB Wlan Dongle (Edimax, working without extra software) and do the update. Im using Jessie Lite and later I installed the desktop.
                                      Sorry for my bad english ;)
                                        CaptnJB @Iseknutz
                                        @Iseknutz
                                        Greetings from Toulouse. To do the update and upgrade, from the terminal type:
                                        sudo apt-get update
                                        sudo apt-get upgrade
                                        After the installation of the new updated packages, sudo shutdown. Wait. Remove the power and your edimax adapter and connect power. Now does it work?
                                        JB
                                          @CaptnJB @Iseknutz
                                          Silly me! I should have known that to get a wifi adapter to work I needed a wifi adapter!
                                          Fortunately I had a usb splitter with power supply and an edimax wifi lying around.
                                          After the update and upgrade its working well.
                                          Your help was greatly appreciated.
                                          Thanks from Texas!
                                          KLM
                                          • markbajajM Offline
                                            markbajaj @rootsudo
                                            @rootsudo Thank you!
                                            This along with post number 23 got my Pi Zero and Pi zero W working perfectly :)
                                            • 2 / 3
