    MagicMirror on Pi Zero W
    46 Posts 19 Posters 70.7k Views 21 Watching
      Mitchfarino Module Developer @Hawking
      @Hawking
      I saw errors stating that MM requires a higher version of node, but I couldn’t figure out how to do it.
      Could you provide the command you used? Then I’ll try it on mine too and will feed back
        McSorley
        I am getting an issue with sudo npm install getting the following error.
        npm WARN cannot run in wd magicmirror@2.1.1 cd vendor && npm install (wd=/home/pi/MagicMirror)
        npm WARN cannot run in wd magicmirror@2.1.1 sh installers/postinstall/postinstall.sh (wd=/home/pi/MagicMirror)
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @McSorley
          @McSorley try npm install --unsafe-perm
            I think if someone can get this up and running, they should host the image somewhere for people to download.
            Don’t load any modules, just go with the default.
            Then people can install the ones that they need.
            • H Offline
              Hawking @strawberry 3.141
              @strawberry-3.141 said in MagicMirror on Pi Zero W:
              @Hawking you should check if moment weas installed properly it sits in the vendor directory in node_modules, if it isnt there run npm install in the vendor directory
              With “vendor directory” you refer to “~/MagicMirror”?
              I have a folder
              /home/pi/MagicMirror/node_modules/moment with several files (including moment.js) and subfolders. Is this enough indication for a proper installation or should I check other details?
              @Mitchfarino said in MagicMirror on Pi Zero W:
              @Hawking
              Yes, I got the same error/warnings, that’s why I tried to use a more recent version of node. I used the scripts available here
              https://github.com/sdesalas/node-pi-zero
              I tested it for v6 (don’t remember which subversion) and v7.7.1. Both was without success (no error/warning about old node version, instead other issues and finally still a blank screen). But maybe I made something wrong. Please try your self and let us know about the results (and post the error you get, I don’t remember them in detail).
              I would strongly prefer to know the commands that worked. An image is a huge file that gets outdated (replacement of jessie…), has to be stored on some external server (the free one are usually slow…) The commands on the other hand are hopefully only a small modification of the tutorial writen above, can easily be used and even adapted more easy.
                strawberry 3.141 Project Sponsor Module Developer @Hawking
                @Hawking said in MagicMirror on Pi Zero W:
                it should look like this /home/pi/MagicMirror/vendor/node_modules/moment do you have a package.json file in /home/pi/MagicMirror/vendor?
                • H Offline
                  Hawking
                  I have a directory /home/pi/MagicMirror/vendor containing
                  package.json and vendor.js but noting more.
                  I now used npn version 2.14.7 (checked by npm -version) to
                  cd ~/MagicMirror/vendor
                  npm install
                  This gave
                  npm WARN package.json magicmirror-vendors@ No README data
                  font-awesome@4.7.0 node_modules/font-awesome
                  moment-timezone@0.5.13 node_modules/moment-timezone
                  weathericons@2.1.0 node_modules/weathericons
                  moment@2.18.1 node_modules/moment
                  and the folder /home/pi/MagicMirror/vendor/node_modules/moment that you mentioned before was created.
                  I then rebootet (not sure if necessary) and it seems to work (I see the date and time, holidays,quote…). I’ll now set everything up but it looks way better then before.
                  So thanks a lot for your help!! I hope that your fix also works for the other people who have the same problem.
                  Just to understand the fix a bit better:
                  Is there a reason that one seem to have to do run
                  sudo npm install once in /home/pi/MagicMirror/ (this is already included in the initial post) and once npm install in /home/pi/MagicMirror/vendor/? (this is not mentioned in the initial post and also not directly done by the standard installer (that does not work for the pi-Zero) located in /home/pi/MagicMirror/installers/raspberry.sh (at least I don’t see it therein).
                  strawberry 3.141S 1 Reply Last reply Reply Quote 1
                    @Hawking the command npm install in the directory /home/pi/MagicMirror/ has a hook in the package.json file which automatically runs npm install in /home/pi/MagicMirror/vendor as well, so there is no need to mention this because it’s done automatically ;)
                    • H Offline
                      I now did a installation on a fresh image and used node version 6.6.1 which automatically includes npm 3.10.8. So instead of
                      sudo wget http://node-arm.herokuapp.com/node_latest_armhf.deb
                      sudo dpkg -i node_latest_armhf.deb
                      sudo apt-get install npm
                      I did
                      wget -O - https://raw.githubusercontent.com/sdesalas/node-pi-zero/master/install-node-v6.9.1.sh | bash
                      Then I got later on no warnings about to old or insecure version any more but just
                      npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                      npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                      npm WARN prefer global colorguard@1.2.0 should be installed with -g
                      > electron-chromedriver@1.6.0 install /home/hawking/MagicMirror/node_modules/electron-chromedriver
                      > node ./download-chromedriver.js
                      > electron@1.6.5 postinstall /home/hawking/MagicMirror/node_modules/electron
                      > node install.js
                      npm WARN lifecycle magicmirror@2.1.1~install: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 cd vendor && npm install /home/hawking/MagicMirror
                      npm WARN lifecycle magicmirror@2.1.1~postinstall: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 sh installers/postinstall/postinstall.sh /home/hawking/MagicMirror
                      (in this installation I did not use the pi user, but I had the same problem when I used the default pi user).
                      If one knows the solution for the blank screen it is obvious that this is a strong hint that one should run
                      cd ~/MagicMirror/vendor/ && npm install
                      cd ~/MagicMirror/ && sh installers/postinstall/postinstall.sh
                      (the later at the moment just prints a success message and is therefore not really needed)
                      I don’t know why these commands did not work automatically, maybe an issue with some directories that are not set (I assume in the error instead of %s the directory should be displayed).
                      • I Offline
                        Iseknutz
                        I installed the image from https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/84 , updated the System to use the onboard wifi and this works for me.
                        kylelmartinK 2 Replies Last reply Reply Quote 0
                          @Hawking Thanks for all your help and comments, I’ve managed to get it up and running now!
                          Now I just need to get the whitelist sorted :grimacing:
                          • H Offline
                            Hawking @Mitchfarino
                            No problem.
                            This worked fine for me, I just added the IP of my regular PC (e.g 192.168.2.185) to the list in the config file so that it looked like
                            ipWhitelist: ["192.168.2.185", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                            If I then typed the ip:port (the port is also defined in the MM config, default is 8080) of my raspi (e.g.
                            http://192.168.2.170:8080/
                            ) in the browser bar of my regular PC I could see the page also on my regular PC (took 1-2 seconds to load).
                            If this does not work for you, just open a new thread and provide details.
                              CaptnJB
                              BLANK SCREEN, NO CLOCK/CALENDAR/MOMENTS solved and simplified from other topics and posts:
                              After you follow the instructions in the first post to #23 then jump to here:
                              24 cd ~/MagicMirror/vendor
                              25 npm install
                              26 sudo reboot
                              I’m not a linux expert, but I built this a few weeks back before the latest version of MM and it worked flawlessly. There should be a hook in the original package.json that kicks it into the vendor directory and runs “npm install” there but it doesn’t happen now (5/3/2017).
                              Also, for those of you who do not have a monitor, after you SSH into your Rpi Zero W:
                              sudo raspi-config
                              5 interfacing options
                              P3 VNC
                              YES you want to enable the VNC server
                              reboot when it asks.
                              Use VNC Viewer or whatever, connect to your rpi using either ip address or if you set it up in your DHCP table with a :0 (zero) to see your screen or :1 to have a desktop.
                              CaptnJB
                              • kylelmartinK Offline
                                kylelmartin @Iseknutz
                                  @Iseknutz said in MagicMirror on Pi Zero W:
                                  @Iseknutz
                                  At least I can get this method up and running on my RPI0w, but what’s the trick to updating the system to use the onboard wifi? I’ve created the wpa_supplicant.conf and I’ve even jacked with the etc/network/interfaces - but no luck getting it to connect to the network.
                                  Thx
                                  C I 2 Replies Last reply Reply Quote 1
                                    CaptnJB @kylelmartin
                                    @kylelmartin can you post or pm your WPA_supplicant.conf file? Please remove your passwords and maybe change your wifi name if that makes you feel better.
                                    How are you updating your wpa-supplicant through a terminal or by copying it onto your card? Windows or Mac?
                                    CaptnJB
                                    kylelmartinK 1 Reply Last reply Reply Quote 0
                                      kylelmartin @CaptnJB
                                      @CaptnJB
                                      here is the wpa_supplicant.conf file - or at least the latest rendition of it.
                                      country=US
                                      ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
                                      update_config=1
                                      network={
                                          ssid="KLM-Guest"
                                          key_mgmt=NONE
                                          priority=1
                                          id_str="guest"
                                      network={
                                          ssid="mywebsite.com"
                                          psk="oldasspw"
                                          priority=2
                                          id_str="klm"
                                      My regular old wifi network name has a “.” in the name and I thought that might cause some problems. So, I set up a second guest wifi network so this device wouldn’t need a password.
                                        @kylelmartin, I apologize for the delay just landed in Madrid. For starters I would take out the id lines. Keep it simple. Try this.
                                        country=US
                                        update_config=1
                                        network={
                                            ssid="KLM-Guest"
                                            psk=""
                                            priority=1
                                        network={
                                            ssid="KLM"
                                            psk="oldasspw"
                                            priority=2
                                        Also, mywebsite.com should be be your router ssid. If you have it set to that “mywebsite.com” in the file you gave it is most likely “KLM”.
                                        Why would you want the guest network to have priority?
                                        CaptnJB
                                        • I Offline
                                          Iseknutz @kylelmartin
                                          @kylelmartin after the Update to the actual OS, the Onboard-WiFi from my raspi0 was automatically enabled. Did you use the Desktop or console?
                                          C kylelmartinK 2 Replies Last reply Reply Quote 0
                                            CaptnJB @Iseknutz
                                            @Iseknutz I use ssh and nano. I also am a Mac user.
                                            I’m glad it’s working
                                            CaptnJB
