    Pulse-Eight
    8 Posts 2 Posters 3.9k Views 2 Watching
      Desertswing
      I got it working but only for turning the tv on with my pir sensor,
      But, standby command isen`t working…
      Any tips??
      • yawnsY Offline
        yawns Moderator @Desertswing
        @Desertswing
        What command are you sending?
        Display on: echo "on 0" | cec-client -s -d 1
        Display off: echo "standby 0" | cec-client -s -d 1
        Show status: echo "pow 0" | cec-client -s -d 1
          Desertswing
          Second command u refer
          I used it with my pir sensor and seprate
            Desertswing @yawns
            @yawns said in Pulse-Eight:
            @Desertswing
            Do u got an solution?
            • yawnsY Offline
              @Desertswing
              Oh sorry, I missed your reply :-/
              I use these 3 commands and they work perfectly fine for my TV.
              What happens if you run the “display off” command on command line?
              Try echo scan | cec-client -s -d 1 to see the hdmi devices, maybe it is not device 1 ?
                Desertswing @yawns
                @yawns
                But the: Display on: echo “on 0” | cec-client -s -d 1 command works fine.
                only the off command isen`t working?
                  Desertswing @yawns
                  @yawns
                  Disply off command does nothing
